SES CMAKE ERROR
I have installed the latest SDK 1.3.0 using the Toolchain Manager.
I would now like to open nRF Connect SDK Projekt and get the follwoing error:
I have added the CXX environment variable, but it did not help Disappointed
  • dhandzic said:
    The zephyr map for the 1.3.1 has no boards subdirectory. It only contains module.yml.
     Are you sure you checked <your NCS folder>/v1.3.1/zephyr, and not <your NCS folder>/v1.3.1/nrf/zephyr?
    dhandzic said:
    What is in the secure partition?
     The secure partition is used by the bootloader (MCUBoot) and/or the Secure Partition Manager (SPM).
    dhandzic said:
    The lwm2m_client takes 169.8k Code and 111.2k Data
     Where do you get those numbers from?
    You should also note that in NCS, the flash partitioning is not decided by the device tree, but by the Partiion Manager script: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.3.0/nrf/scripts/partition_manager/partition_manager.html
    But the actual amount of flash and RAM available is also dependent on if you enable DFU or not.
  • The lwm2m_client code and data size I get from the SES after the build process, but I am not sure. They are shown in the project explorer pane but memory usage pane does not have any information. If you have other numbers it would be intresting.
  • That does not seem right.
    The v1.3.1 folder should look like this:
    Can you try to "Update SDK"?
    If that does not work, you can try to "Open bash", and run "west update"?
    If you get any errors, please send them to me.
    Looking at the partition scheme creted by the partition manager, the app partition is 0x6ae00 bytes, or 437,760.
    When I build from the comman line, I get the following report:
               FLASH:      210832 B     437760 B     48.16%
                SRAM:       79160 B       128 KB     60.39%
            IDT_LIST:         136 B         2 KB      6.64%
    (it should also be available in the "output" window in SES.
    EMPTY_0:
      address: 0xc000
      placement:
        before:
        - mcuboot_pad
      region: flash_primary
    app:
      address: 0x1c200
    mcuboot:
      address: 0x0
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x10000
      placement:
        align:
          start: 0x8000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0x10000
      orig_span: &id001
      - spm
      - app
      - mcuboot_pad
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0x10200
      orig_span: &id002
      - app
      - spm
      span: *id002
    mcuboot_secondary:
      address: 0x87000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x1000
      share_size:
      - mcuboot_primary
    otp:
      address: 0xff8108
      region: otp
    settings_storage:
      address: 0xfe000
      placement:
        before:
        - end
    spm:
      address: 0x10200
      inside:
      placement:
        before:
        - app
  • Hi Didrik,
    I have tried Update SDK for 1.3.1 from Toolchain Manager without success. I have tried from BASH  west update and also ncsmgr init-ncs but I get errors:
    The Output pane in SES does not show memeory usage information after building either.
  • Hi Didrik,
    today I received my nRF9160 DK board and I have the asset tracker running using nrf9160dk_asset_tracker_ltem_2020-04-29_bc7ade8b.hex. Works fine except GPS position even with external antenna and SW12 in CON position and patch antenna near window I dont get GPS readings. Is this part of the LTE-M implementation?
