I have installed the latest SDK 1.3.0 using the Toolchain Manager.
I would now like to open nRF Connect SDK Projekt and get the follwoing error:
I have added the CXX environment variable, but it did not help
dhandzic said:The Output pane in SES does not show memeory usage information after building either.
If you change the right drop-down menu from "Tasks" to "Output", you should get the same output as from a terminal.
dhandzic said:today I received my nRF9160 DK board and I have the asset tracker running using nrf9160dk_asset_tracker_ltem_2020-04-29_bc7ade8b.hex. Works fine except GPS position even with external antenna and SW12 in CON position and patch antenna near window I dont get GPS readings. Is this part of the LTE-M implementation?
Are you using the iBasis SIM card that came with the DK? Those usually don't get PSM granted by the network. The nRF9160 is not able to use the GPS while also using the LTE radio, and there is usually not enough time for the GPS to get a fix in the intervals where the LTE radio is off unless eDRX or PSM is used.
dhandzic said:I have tried Update SDK for 1.3.1 from Toolchain Manager without success. I have tried from BASH west update and also ncsmgr init-ncs but I get errors:
Are you using VPN? If so, that might be the problem.
Also, have you tried to change the folder used by the Toolchain Manager?
Hi Didrik,
I have been out of office a couple of days. We use NordVPN and I had do uninstall the 1.3.1, turn off the VPN and reinstall 1.3.1 and now all sub directories are there and I can build the lwm2m_client from 1.3.1.
I am using the iBasis SIM while waiting for my Telia SIM to arrive. I will now look at the hardware design of our board. Is there any document containing reference design and layout guidelines?
Running the DK board today I get the LED1 and LED4 blinking and it does not show data in the NRFCLOUD:
The LTE Link Monitor shows the following today:
dhandzic said:I will now look at the hardware design of our board. Is there any document containing reference design and layout guidelines?
I am not a hardware expert, so if you have any hardware related questions, you should open a new ticket. But I was directed to this document by one of our hardware experts: https://infocenter.nordicsemi.com/topic/nwp_037/WP/nwp_037/nwp_037_intro.html
dhandzic said:I have been out of office a couple of days. We use NordVPN and I had do uninstall the 1.3.1, turn off the VPN and reinstall 1.3.1 and now all sub directories are there and I can build the lwm2m_client from 1.3.1.
Glad to hear that it now works.
dhandzic said:I am using the iBasis SIM while waiting for my Telia SIM to arrive
That probably explains why you could not get a GPS fix. If you want to test the GPS, you should also try the gps sample. As it does not use LTE (unless you have configured it to also use A-GPS), it should be able to get a fix. Note that you might not be able to get a fix indoors.
dhandzic said:Running the DK board today I get the LED1 and LED4 blinking and it does not show data in the NRFCLOUD:
Did only LED1 and 4 blink?
I can't find that combination in the documentation: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.3.0/nrf/applications/asset_tracker/README.html
If you open a serial terminal on your computer, you should see a log from the application on one of the COM ports. What does the log say?
Hi Didrik,
I posted the log above. It is the output from the LTE Link Monitor and it reports a SIM card problem. It is the iBasis SIM I have used last week without a problem.
