Why having "nRF Connect - Bluetooth Low Energy" open makes my connection faster
This topic follows devzone.nordicsemi.com/.../why-having-nrf-connect---bluetooth-low-energy-open-makes-my-connection-faster-and-more-stable which was partially fixed (with fix in SoftDevice, connection is more stable and does not freeze anymore, however, it remains slow).
I could reproduce the issue only with code delivered by Nordic:
* Board PCA10028 programmed with "Nordic_HRM" sample program
* pc-ble-driver's heart_rate_collector sample program with very few changes:
  • Added "#include <time.h>" and "clock_t start;" on top of the file
  • Added "start = clock();" after "printf("Discovering primary services\n");fflush(stdout);" in service_discovery_start()
  • Added "clock_t stop = clock();double diffticks=stop-start;double diffms=(diffticks)/(CLOCKS_PER_SEC/1000);printf("time taken %fms\n",diffms);" before "m_hrm_cccd_handle = p_ble_gattc_evt->params.desc_disc_rsp.descs[i].handle;" in on_descriptor_discovery_response
So now the program reports how long service discovery took
Now I ran the sample program:
  • Twice in a raw, without "nRF Connect - Bluetooth Low Energy" being opened, service discovery took around 200ms
  • Then, I open "nRF Connect - Bluetooth Low Energy"
  • Twice in a raw, service discovery took less than 50ms
  • Then, I close "nRF Connect - Bluetooth Low Energy"
  • Once again, service discovery took around 200ms
  • Then, I reopen "nRF Connect - Bluetooth Low Energy"
  • Once again, service discovery took less than 50ms
See the video:
So the fact that "nRF Connect - Bluetooth Low Energy" is opened apparently really makes device discovery faster. Later, for our devices, it also makes data acquisition faster, meaning that witout "nRF Connect - Bluetooth Low Energy" being installed and running on the computer, we cannot reach the throughpout we need for our applications.
Could you please help us understanding what is "nRF Connect - Bluetooth Low Energy" doing at Windows level (or elsewhere) that make the device communication be faster?
  • Hi Jean,
    If you rename the path of the Jlink driver, the error might be expected because of the setting. Do you mean that the service discovery will not run faster in that case?
    Could you also help to test if you open J-Link Commander? Does it also affect the time?
    -Amanda H.
    I could do some more testing, here is what we observe here:
    - When nor JLink, nor nRF Connect are opened, service discovery and data transmission is slow
    - When JLink.exe is opened, service discovery and data transmission is faster
    - When "nRF Connect - Bleototh Low Energy" is opened, service discovery and data transmission is faster
    So we could conclude that "nRF Connect - Bleototh Low Energy" may start JLink in the background making everything work fine. But:
    - If I rename "C:\Program Files (x86)\SEGGER", and open "nRF Connect - Bleototh Low Energy", I get an error and, surprisingly, service discovery and data transmission remain faster....while I would expect it to be slow again as "nRF Connect - Bleototh Low Energy" could not run JLink....
    Jean
  • Hi Jean,
    Thanks for the tests. I have reported to the internal for investigation.
    -Amanda H.
    Another information that could help. After upgrading nRF Connect (I was using 3.3.1), the behaviour changed. Having "nRF Connect/Bluetooth Low Energy" app will not make connection faster anymore, whereas opening JLink.exe still does the job.
    So I tested all intermediate releases:
    - Fo all releases from 3.3.1 to 3.6.0, I observe the same behaviour: Running JLink.exe OR opening "nRF Connect/Bluetooth Low Energy" makes device connection faster.
    - With 3.6.1 only, Running JLink.exe makes device connection faster, but opening "nRF Connect/Bluetooth Low Energy" does not have any effect, the connection remains slow.
    Looks like something related to this issue was changed in this last release.
    Jean
  • Hi Jean,
    I have updated to the internal. Thanks.
    -Amanda H.
