Modify pre shared OOB key for Legacy Connection
Hi !
I am working on SDK 15.2 and on a NRF52832.
The others devices I will interact with are on BLE 4, so I can use only Legacy Connection mode for security.
I would like to use Out of Band mode, with a pre shared key stored on my device. The other device, a BLE Gateway, will have a file with this key stored too.
First, I would like to know if there are examples to do that.
Second, i would like to know if it is possible to modify the value of the key and keep its value even if we switch off the device.
    It is possible to use pre-shared OOB keys yes. I made an example for nRF5 SDK v13 that show this, in principle it should be the same for more recent nRF5 SDK also. You will need to handle the BLE_GAP_EVT_AUTH_KEY_REQUEST in on_ble_evt() on both the central and peripheral device.
    \nRF5_SDK_13.0.0_04a0bfd\examples\ble_central\ble_app_hrs_c
    \nRF5_SDK_13.0.0_04a0bfd\examples\ble_peripheral\ble_app_hrs
    ble_app_hrs_c.zip
    ble_app_hrs.zip
    Here is a more updated message sequence chart:
    https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.s132.api.v7.2.0%2Fgroup___b_l_e___g_a_p___p_e_r_i_p_h___b_o_n_d_i_n_g___p_k___c_e_n_t_r_a_l___o_o_b___m_s_c.html
    https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.s132.api.v7.2.0%2Fgroup___b_l_e___g_a_p___c_e_n_t_r_a_l___b_o_n_d_i_n_g___p_k___p_e_r_i_p_h___o_o_b___m_s_c.html
    Kenneth
  • Hi Kenneth, sorry for the delay, finally it was not a priority for us 2 months ago. But now I need to come back to it.
    So I have read the ble_app_hrs example and have taken few pieces of program. I have added this code in my program :
    //AKR
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_disconnect_on_sec_failure(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start();
    //AKR
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        ret_code_t           err_code;
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 0;
        sec_param.kdist_own.id   = 0;
        sec_param.kdist_peer.enc = 0;
        sec_param.kdist_peer.id  = 0;
    I have called it in my main function.
    Here is how I handle the BLE_GAP_EVT_AUTH_KEY_REQUEST event:
            // Upon authentication key request, reply with the preshared key in the device. //AKR
            case BLE_GAP_EVT_AUTH_KEY_REQUEST:
                NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
                err_code = sd_ble_gap_auth_key_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                     BLE_GAP_AUTH_KEY_TYPE_OOB,
                                                     key_auth);
    Also I have activated few stuffs in sdk_config to correctly build
    #define PEER_MANAGER_ENABLED 1
    #define PM_SERVICE_CHANGED_ENABLED 1
    #define FDS_ENABLED 1
    #define NRF_FSTORAGE_ENABLED 1
    It builds correctly, but when I launch my application, I have a problem with the  ble_stack_init function:
    void ble_stack_init(void)
        extern uint8_t __data_start__;
        uint32_t app_ram_base = 0;
        err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &app_ram_base);
        // Enable BLE stack.
        err_code = nrf_sdh_ble_enable(&app_ram_base);
        // Check if we do memory allocation correctly.
        if (err_code == NRF_SUCCESS)
            // Verify that value provided in linked script (LD file) matches the SD calculations.
            if (app_ram_base == (uint32_t) &__data_start__)
                //NRF_LOG_INFO("Soft Device enabled, __data_start__ is set correctly.");
                printf("Soft Device enabled, __data_start__ is set correctly.\n");
                //NRF_LOG_INFO("Soft Device enabled, __data_start__ is set incorrectly (should be = 0x%08X instead of 0x%08X).", app_ram_base, (uint32_t) &__data_start__);
                printf("Soft Device enabled, __data_start__ is set incorrectly (should be = 0x%08X instead of 0x%08X).\n", app_ram_base, (uint32_t) &__data_start__);
                APP_ERROR_CHECK(NRF_ERROR_FORBIDDEN);
        else if (err_code == NRF_ERROR_NO_MEM)
            // Not enough memory for the Soft Device (value provided is too low).
            //NRF_LOG_INFO("Soft Device failed to enabled, __data_start__ is set incorrectly (should be = 0x%08X instead of 0x%08X).", app_ram_base, (uint32_t) &__data_start__);
    app_ram_base and __data_start are different, app_ram_base = 0x2000 38C0 and __data_start  = 0x200038D4.
    However, I have declared RAM_START = 0x2000 38C0. Do you know why I have this error and how i can handle it ?
    Thanks !
  • Assuming you are using SES:
    The actual ram required by the softdevice depends on the number of links and other configuration, so you typically need to update this during development.
  • Hi Kenneth
    Yeah I am on SES, and I have done it few times before when I added services. But it is not the same problem here, indeed usually in these cases I need to increase the ram allocated for the app. So the message printed will be " __data_start__ is set incorrectly (should be = a instead of b)" with a > b.
    But in my case it is : __data_start__ is set incorrectly (should be = 0x200038C0 instead of 0x200038D4), with a < b. Plus, I am already initialized at this value :
    I have tried to increase the ram_start, but I had the same results.
  • Also I have a question about the message sequence chart for the peripheral :
    I see that I have to handle to events, BLE_GAP_EVT_SEC_PARAMS_REQUEST, and BLE_GAP_EVT_AUTH_KEY_REQUEST.
    For the BLE_GAP_EVT_SEC_PARAMS_REQUEST event, the chart says that I have to call the sd_ble_gap_sec_params_reply function, and for this function it is said in the documentation that the last parameter is [in/out], but I don't know how to fill it. It is not indicated in the documentation, can you help me about that ?
