I got a nrf52832 custom board to communicate with LIS2DH12 accelerometer by I2C(TWI).
I edited part of the code from "twi_sensor" project in NRF5_SDK version 17.0.
I tried to read the "x_out_low " byte from LIS2DH12, but always get zero.
Here's my schematic diagram:
Here's my code:
* Copyright (c) 2015 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup tw_sensor_example main.c
* @ingroup nrf_twi_example
* @brief TWI Sensor Example main file.
* This file contains the source code for a sample application using TWI.
#include "app_error.h"
#include "boards.h"
#include "nrf_delay.h"
#include "nrf_drv_twi.h"
#include <stdio.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
#define ACC_ADDR (0x33U >> 1)
#define X_OUT_L 0x28
#define SCL_PIN 5
#define SDA_PIN 2
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
* @brief Function for setting active mode on MMA7660 accelerometer.
void ACC_set_mode(void) {
ret_code_t err_code;
// set data rate to 100 Hz
uint8_t CTRL_REG1[] = {0x20, 0x5F};
// set full-scale to +/- 2g
uint8_t CTRL_REG4[] = {0x23, 0x80};
// set FIFO to stream mode
uint8_t FIFO_CTRL[] = {0x2E, 0x80};
err_code = nrf_drv_twi_tx(&m_twi, ACC_ADDR, CTRL_REG1, sizeof(CTRL_REG1), false);
while (m_xfer_done == false);
err_code = nrf_drv_twi_tx(&m_twi, ACC_ADDR, CTRL_REG4, sizeof(CTRL_REG4), false);
err_code = nrf_drv_twi_tx(&m_twi, ACC_ADDR, FIFO_CTRL, sizeof(FIFO_CTRL), false);
* @brief Function for handling data from temperature sensor.
* @param[in] temp Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp) {
printf("data: %d\n", temp);
* @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const *p_event, void *p_context) {
switch (p_event->type) {
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX) {
data_handler(m_sample);
m_xfer_done = true;
* @brief UART initialization.
void twi_init(void) {
const nrf_drv_twi_config_t twi_acc_config = {
.scl = SCL_PIN,
.sda = SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false};
err_code = nrf_drv_twi_init(&m_twi, &twi_acc_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
* @brief Function for reading data from temperature sensor.
static void read_sensor_data() {
printf("READING......\n");
uint8_t addr8 = X_OUT_L;
ret_code_t err_code = nrf_drv_twi_tx(&m_twi, ACC_ADDR, &addr8, 1, true);
err_code = nrf_drv_twi_rx(&m_twi, ACC_ADDR, &m_sample, sizeof(m_sample));
if(m_sample != 0){
nrf_gpio_pin_toggle(LED_1);
printf("read: %d\n", m_sample);
int main(void) {
twi_init();
nrf_gpio_cfg_input(3, NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_output(4);
nrf_gpio_pin_write(4, 1);
nrf_gpio_cfg_output(8);
nrf_gpio_pin_write(8, 1);
nrf_gpio_cfg_output(LED_1);
ACC_set_mode();
while (true) {
nrf_delay_ms(500);
do {
__WFE();
} while (m_xfer_done == false);
// to confirm everything is still working
read_sensor_data();
Feel free to tell me if you need more information.
Any recommendation will be highly appreciated. Thank you very much!!
