Custom NRF52832 + LIS2DH12 accelerometer but always get '0'
I got a nrf52832 custom board to communicate with LIS2DH12 accelerometer by I2C(TWI).
I edited part of the code from "twi_sensor" project in NRF5_SDK version 17.0.
I tried to read the "x_out_low " byte from LIS2DH12, but always get zero.
Here's my schematic diagram:
Here's my code:
 * Copyright (c) 2015 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup tw_sensor_example main.c
 * @ingroup nrf_twi_example
 * @brief TWI Sensor Example main file.
 * This file contains the source code for a sample application using TWI.
#include "app_error.h"
#include "boards.h"
#include "nrf_delay.h"
#include "nrf_drv_twi.h"
#include <stdio.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
#define ACC_ADDR (0x33U >> 1)
#define X_OUT_L 0x28
#define SCL_PIN 5
#define SDA_PIN 2
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
 * @brief Function for setting active mode on MMA7660 accelerometer.
void ACC_set_mode(void) {
    ret_code_t err_code;
    // set data rate to 100 Hz
    uint8_t CTRL_REG1[] = {0x20, 0x5F};
    // set full-scale to +/- 2g
    uint8_t CTRL_REG4[] = {0x23, 0x80};
    // set FIFO to stream mode
    uint8_t FIFO_CTRL[] = {0x2E, 0x80};
    err_code = nrf_drv_twi_tx(&m_twi, ACC_ADDR, CTRL_REG1, sizeof(CTRL_REG1), false);
    while (m_xfer_done == false);
    err_code = nrf_drv_twi_tx(&m_twi, ACC_ADDR, CTRL_REG4, sizeof(CTRL_REG4), false);
    err_code = nrf_drv_twi_tx(&m_twi, ACC_ADDR, FIFO_CTRL, sizeof(FIFO_CTRL), false);
 * @brief Function for handling data from temperature sensor.
 * @param[in] temp          Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp) {
    printf("data: %d\n", temp);
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const *p_event, void *p_context) {
    switch (p_event->type) {
    case NRF_DRV_TWI_EVT_DONE:
        if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX) {
            data_handler(m_sample);
        m_xfer_done = true;
 * @brief UART initialization.
void twi_init(void) {
    const nrf_drv_twi_config_t twi_acc_config = {
        .scl = SCL_PIN,
        .sda = SDA_PIN,
        .frequency = NRF_DRV_TWI_FREQ_100K,
        .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
        .clear_bus_init = false};
    err_code = nrf_drv_twi_init(&m_twi, &twi_acc_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data() {
    printf("READING......\n");
    uint8_t addr8 = X_OUT_L;
    ret_code_t err_code = nrf_drv_twi_tx(&m_twi, ACC_ADDR, &addr8, 1, true);
    err_code = nrf_drv_twi_rx(&m_twi, ACC_ADDR, &m_sample, sizeof(m_sample));
    if(m_sample != 0){
        nrf_gpio_pin_toggle(LED_1);
        printf("read: %d\n", m_sample);
int main(void) {
    twi_init();
    nrf_gpio_cfg_input(3, NRF_GPIO_PIN_PULLUP);
    nrf_gpio_cfg_output(4);
    nrf_gpio_pin_write(4, 1);
    nrf_gpio_cfg_output(8);
    nrf_gpio_pin_write(8, 1);
    nrf_gpio_cfg_output(LED_1);
    ACC_set_mode();
    while (true) {
        nrf_delay_ms(500);
        do {
            __WFE();
        } while (m_xfer_done == false);
        // to confirm everything is still working
        read_sensor_data();
Feel free to tell me if you need more information.
Any recommendation will be highly appreciated. Thank you very much!!
  • Finally, I figured it out. I forgot to set the FIFO enable bit in CTRL_REG5....
  • Hello Leo. Can you please share your code for the lis2hh12 and your nrf52 please?
  • Hi, kbk. I basically use "twi_master_using_nrf_twi_mngr" project, and only edit some registers and values in "mma7660.h" and "mma7660.c" to init lis2dh12. I called these file "lis2dh12.h" and "lis2dh12.c".
    Here's the code:
    lis2dh12.h
    #ifndef LIS2DH12_H_
    #define LIS2DH12_H_
    #include "nrf_twi_mngr.h"
    #ifdef __cplusplus
    extern "C" {
    #define SCL_PIN 5
    #define SDA_PIN 2
    /** I2C Device Address 8 bit format if SA0=0 -> 31 if SA0=1 -> 33 **/
    #define LIS2DH12_ADDR 0x19U
    #define LIS2DH12_I2C_ADD_L 0x31U
    #define LIS2DH12_I2C_ADD_H 0x33U
    #define LIS2DH12_OUT_X_L 0x28U
    #define LIS2DH12_OUT_X_H 0x29U
    #define LIS2DH12_OUT_Y_L 0x2AU
    #define LIS2DH12_OUT_Y_H 0x2BU
    #define LIS2DH12_OUT_Z_L 0x2CU
    #define LIS2DH12_OUT_Z_H 0x2DU
    #define LIS2DH12_FIFO_CTRL_REG 0x2EU
    #define LIS2DH12_NUMBER_OF_REGISTERS 11
    // The Alert bit (6) set signals that the register must be read again, since
    // its value may be inaccurate (it was read at the same time as the device was
    // attempting to update it).
    // Applies to XOUT, YOUT, ZOUT registers.
    #define LIS2DH12_DATA_IS_VALID(reg_data) (!((reg_data) & (1U << 6)))
    // Gets acceleration (g) value (6-bit 2's complement) from register data.
    // [use "/ 4" instead of ">> 2", as the result of right-shifting of a signed
    //  type value is implementation-defined]
    #define LIS2DH12_GET_ACC(reg_data) ((int8_t)((reg_data) << 2) / 4)
    // Get orientation of the device (PoLa bits from the Tilt Status register).
    #define LIS2DH12_GET_ORIENTATION(tilt_status) (tilt_status & 0x1C)
    #define LIS2DH12_ORIENTATION_LEFT 0x04
    #define LIS2DH12_ORIENTATION_RIGHT 0x08
    #define LIS2DH12_ORIENTATION_DOWN 0x14
    #define LIS2DH12_ORIENTATION_UP 0x18
    #define LIS2DH12_TAP_DETECTED(tilt_status) (tilt_status & (1U << 5))
    #define LIS2DH12_SHAKE_DETECTED(tilt_status) (tilt_status & (1U << 7))
    extern uint8_t NRF_TWI_MNGR_BUFFER_LOC_IND lis2dh12_xout_reg_addr;
    #define LIS2DH12_READ(p_reg_addr, p_buffer, byte_cnt)                       \
        NRF_TWI_MNGR_WRITE(LIS2DH12_ADDR, p_reg_addr, 1, NRF_TWI_MNGR_NO_STOP), \
            NRF_TWI_MNGR_READ(LIS2DH12_ADDR, p_buffer, byte_cnt, 0)
    #define LIS2DH12_READ_XYZ(p_buffer) \
        LIS2DH12_READ(&lis2dh12_xout_reg_addr, p_buffer, 6)
    #define LIS2DH12_INIT_TRANSFER_COUNT 4
    extern nrf_twi_mngr_transfer_t const
        lis2dh12_init_transfers[LIS2DH12_INIT_TRANSFER_COUNT];
    #ifdef __cplusplus
    #endif // LIS2DH12_H_
    lis2dh12.c
    /** @file
     * @defgroup nrf_twi_master_example main.c
     * @brief TWI Example Application main file.
     * @image html example_board_setup_a.jpg "Use board setup A for this example."
    #include "lis2dh12.h"
    uint8_t NRF_TWI_MNGR_BUFFER_LOC_IND lis2dh12_xout_reg_addr = (LIS2DH12_OUT_X_L | 0x80);
    static uint8_t NRF_TWI_MNGR_BUFFER_LOC_IND CTRL_REG1[] = { 0x20, 0x57 };
    static uint8_t NRF_TWI_MNGR_BUFFER_LOC_IND CTRL_REG4[] = { 0x23, 0x04 };
    static uint8_t NRF_TWI_MNGR_BUFFER_LOC_IND CTRL_REG5[] = { 0x24, 0x40 };
    // set FIFO enable bit
    static uint8_t NRF_TWI_MNGR_BUFFER_LOC_IND FIFO_CTRL[] = { 0x2E, 0x80 };
    nrf_twi_mngr_transfer_t const lis2dh12_init_transfers[LIS2DH12_INIT_TRANSFER_COUNT] =
        NRF_TWI_MNGR_WRITE(LIS2DH12_ADDR, CTRL_REG1, sizeof(CTRL_REG1), 0),
        NRF_TWI_MNGR_WRITE(LIS2DH12_ADDR, CTRL_REG4, sizeof(CTRL_REG4), 0),
        NRF_TWI_MNGR_WRITE(LIS2DH12_ADDR, CTRL_REG5, sizeof(CTRL_REG5), 0),
        NRF_TWI_MNGR_WRITE(LIS2DH12_ADDR, FIFO_CTRL, sizeof(FIFO_CTRL), 0)
    and main.c
    void setup(void) {
        log_init();
        // bsp = Board Support Package
        // Start internal LFCLK XTAL oscillator - it is needed by BSP to handle
        // buttons with the use of APP_TIMER and for "read_all" ticks generation
        // (by RTC).
        lfclk_config();
        bsp_config();
        power_init();
        gpio_config();
        // Wait for LIS2D12 Turn-on time
        nrf_delay_ms(300);
    int main(void) {
        setup();
        twi_config();
        read_init();
        // Initialize sensor (lis2dh12 only).
        APP_ERROR_CHECK(nrf_twi_mngr_perform(&m_nrf_twi_mngr, NULL, lis2dh12_init_transfers,
            LIS2DH12_INIT_TRANSFER_COUNT, NULL));
  • Hello Leo
    Thank you very much for taking the time to post this for me. I understand adding the two lis2dh12.files and I assume what you have here in the main.c code above is what I add to the main.c for the "twi_master_using_nrf_twi_mngr" project. Is that correct so far? What I don't understand is what is it that will call anything in those two added files... (I'm a terrible programmer) if you can help me further it would be very much appreciated.
    Kevin
  • Hi, kbk
    I use SEGGER studio to program, right-click the variable => Go To Definition.
    It will be much more easier to trace code. : >
    Here's the functions I use:
    void read_all_cb(ret_code_t result, void *p_user_data) {
        if (result != NRF_SUCCESS) {
            NRF_LOG_WARNING("read_all_cb - error: %d", (int)result);
            return;
        if (DEBUG)
            NRF_LOG_RAW_INFO("Reading......\n");
        float x_gscale_val, y_gscale_val, z_gscale_val;
        x_gscale_val = (float)((int16_t)((((uint16_t)m_buffer[1]) << 8) | m_buffer[0])) / (16 * 1024) + 0.43;
        y_gscale_val = (float)((int16_t)((((uint16_t)m_buffer[3]) << 8) | m_buffer[2])) / (16 * 1024) + 0.4;
        z_gscale_val = (float)((int16_t)((((uint16_t)m_buffer[5]) << 8) | m_buffer[4])) / (16 * 1024) - 0.2;
        if (timer_counter < RECORDING_MAX_TIME_STEP) {
            NRF_LOG_RAW_INFO("%d: ", timer_counter);
            NRF_LOG_RAW_INFO(NRF_LOG_FLOAT_MARKER ", ", NRF_LOG_FLOAT(x_gscale_val));
            NRF_LOG_RAW_INFO(NRF_LOG_FLOAT_MARKER ", ", NRF_LOG_FLOAT(y_gscale_val));
            NRF_LOG_RAW_INFO(NRF_LOG_FLOAT_MARKER "\n", NRF_LOG_FLOAT(z_gscale_val));
        if(timer_counter != RECORDING_MAX_TIME_STEP){
            z_raw_val[timer_counter] = z_gscale_val;
            timer_counter += 1;
    static void read_all(void) {
        // [these structures have to be "static" - they cannot be placed on stack
        //  since the transaction is scheduled and these structures most likely
        //  will be referred after this function returns]
        static nrf_twi_mngr_transfer_t const transfers[] =
    #ifdef LIS2DH12
            {LIS2DH12_READ_XYZ(&m_buffer[0])};
    #else
            {ADXL345_READ_XYZ(&m_buffer[0])};
        static nrf_twi_mngr_transaction_t NRF_TWI_MNGR_BUFFER_LOC_IND transaction =
                .callback = read_all_cb,
                .p_user_data = NULL,
                .p_transfers = transfers,
                .number_of_transfers = sizeof(transfers) / sizeof(transfers[0])};
        APP_ERROR_CHECK(nrf_twi_mngr_schedule(&m_nrf_twi_mngr, &transaction));
        // Signal on LED that something is going on.
        // bsp_board_led_invert(READ_ALL_INDICATOR);
        if (DEBUG)
            NRF_LOG_RAW_INFO("Read end\n\n");
    static void bsp_config(void) {
        uint32_t err_code;
        err_code = app_timer_init();
    // TWI (with transaction manager) initialization.
    static void twi_config(void) {
        uint32_t err_code;
        nrf_drv_twi_config_t const config = {
            .scl = SCL_PIN,
            .sda = SDA_PIN,
            .interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
        err_code = nrf_twi_mngr_init(&m_nrf_twi_mngr, &config);
    static void lfclk_config(void) {
        uint32_t err_code;
        err_code = nrf_drv_clock_init();
    void timer_handler(void *p_context) {
        read_all();
    void read_init(void) {
        err_code = app_timer_create(&m_timer, APP_TIMER_MODE_REPEATED, timer_handler);
        err_code = app_timer_start(m_timer, APP_TIMER_TICKS(20), NULL);
    void log_init(void) {
        err_code = NRF_LOG_INIT(NULL);
    void power_init(void) {
    void gpio_config(void) {
        nrf_gpio_pin_set(8);
        nrf_delay_ms(30);
        nrf_gpio_pin_set(4);
    void setup(void) {
        log_init();
        // (by RTC).
        lfclk_config();
        bsp_config();
        power_init();
        gpio_config();
        nrf_delay_ms(300);
    Not all the functions in lis2dh12.h are used, I use LIS2DH12_READ_XYZ only.
    Regards
