I am working on the ble_app_template project.
1-How can I enable simple pairing without NFC?
2-Also how can I set pairing code?
3-Is the write way to secure characteristics?
attr_md.rd_auth = 1;
attr_md.wr_auth = 1;
Thanks!
Thanks!
Thanks, Amanda Hsieh
I have uploaded the ble_app_hrs example and connected from the nRF app.
But I have not received/got pop up for pairing?
It won't pop up for pairing. You have to perform pairing as the Heart Rate Application documentation.
-Amanda H.
Hi Amanda Hsieh
I have to question.
1-If I made authentic/secured characteristics. Can I read/write data using this pairing method? Is this pairing method secure?
2-How can I get a paring request like this in the attached image? Any example code?
Thanks
Muqarrab said:1-If I made authentic/secured characteristics. Can I read/write data using this pairing method? Is this pairing method secure?
If you want to test that pairing is required but not Man In The Middle (MITM) protection, then I would suggest you try BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM() instead.
Muqarrab said:2-How can I get a paring request like this in the attached image? Any example code?
Please see Glucose Application.
-Amanda H.
I have already seen this example. It generates a pairing pin on UART but its mostly failed pairing when I enter that code.
So basically I want the pairing process without entering code that can read/ write authentic/secured characteristics.
