nRF52840 Enable Pairing with Static Passkey
I am working on the ble_app_template project.
1-How can I enable simple pairing without NFC?
2-Also how can I set pairing code?
3-Is the write way to secure characteristics?
    attr_md.rd_auth    = 1;
    attr_md.wr_auth    = 1;
Thanks!
  • Hi, ,
    As per your instruction, I have added BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM().
    Now when I read/write characteristics device starts bonding.
    Now can you please confirm that without pairing anyone can't read/write characteristics?
    if you use BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM() a peer that pairs with Just Works will be able to access the characteristic value.
    Please see the documentation:
    Set sec_mode pointed to by ptr to require encryption, but no MITM protection.
    -Amanda H.
    Are you talking about this?
    /**@brief GAP connection security modes.
     * Security Mode 0 Level 0: No access permissions at all (this level is not defined by the Bluetooth Core specification).\n
     * Security Mode 1 Level 1: No security is needed (aka open link).\n
     * Security Mode 1 Level 2: Encrypted link required, MITM protection not necessary.\n
     * Security Mode 1 Level 3: MITM protected encrypted link required.\n
     * Security Mode 1 Level 4: LESC MITM protected encrypted link using a 128-bit strength encryption key required.\n
     * Security Mode 2 Level 1: Signing or encryption required, MITM protection not necessary.\n
     * Security Mode 2 Level 2: MITM protected signing required, unless link is MITM protected encrypted.\n
    typedef struct
      uint8_t sm : 4;                     /**< Security Mode (1 or 2), 0 for no permissions at all. */
      uint8_t lv : 4;                     /**< Level (1, 2, 3 or 4), 0 for no permissions at all. */
    } ble_gap_conn_sec_mode_t;
    I have tried this but getting error.
    uint32_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
        uint32_t            err_code;
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_md_t cccd_md;
        ble_gatts_attr_t    attr_char_value;
        ble_uuid_t          ble_uuid;
        ble_gatts_attr_md_t attr_md;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.read   = 1;
        char_md.char_props.write  = 1;
        char_md.char_props.notify = 0;
        char_md.p_char_user_desc  = NULL;
        char_md.p_char_pf         = NULL;
        char_md.p_user_desc_md    = NULL;
        char_md.p_cccd_md         = NULL;
        char_md.p_sccd_md         = NULL;
        memset(&attr_md, 0, sizeof(attr_md));
        attr_md.read_perm = p_cus_init->custom_value_char_attr_md.read_perm;
        attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
        attr_md.read_perm.lv = 2;
        attr_md.write_perm.sm = 2;
        attr_md.vloc       = BLE_GATTS_VLOC_STACK;
        attr_md.rd_auth    = 0;
        attr_md.wr_auth    = 0;
        attr_md.vlen       = 0;
     /* This code belongs in custom_value_char_add() in ble_cus.c*/
        ble_uuid.type = p_cus->uuid_type;
        ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid    = &ble_uuid;
        attr_char_value.p_attr_md = &attr_md;
        attr_char_value.init_len  = sizeof(uint8_t);
        attr_char_value.init_offs = 0;
        attr_char_value.max_len   = sizeof(uint8_t);
    err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
                                                   &attr_char_value,
                                                   &p_cus->custom_value_handles_2);
        if (err_code != NRF_SUCCESS)
            return err_code;
        return NRF_SUCCESS;
  • No. You can take a look at Heart Rate Application use Just Work pair and secure characteristics as
    static inline void set_security_req(security_req_t level, ble_gap_conn_sec_mode_t * p_perm)
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(p_perm);
        switch (level)
            case SEC_NO_ACCESS:
            case SEC_OPEN:
                BLE_GAP_CONN_SEC_MODE_SET_OPEN(p_perm);
            case SEC_JUST_WORKS:
                BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(p_perm);
            case SEC_MITM:
                BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(p_perm);
            case SEC_SIGNED:
                BLE_GAP_CONN_SEC_MODE_SET_SIGNED_NO_MITM(p_perm);
            case SEC_SIGNED_MITM:
                BLE_GAP_CONN_SEC_MODE_SET_SIGNED_WITH_MITM(p_perm);
        return;
    If you want the device to send the pairing request to mobile to allow pairing, you can add the code in the BLE_GAP_EVT_CONNECTED event. If the users cancel the pairing request from the peripheral on mobile, they cannot read/write characteristics.
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                // send a security request to the peer (master)
                ret_code_t err = pm_conn_secure(m_conn_handle, false);
                NRF_LOG_RAW_INFO("%s: send secure connection request - err %d\r\n", (int) __func__, err);
                if (err != NRF_ERROR_INVALID_STATE)
                    APP_ERROR_CHECK(err);
    -Amanda H.
  • Hi
    I have added in mentioned code in the main.c but getting an error
    (static declaration of 'set_security_req' follows non-static declaration).
    So I changed like this.
        ret_code_t              err_code;
        security_req_t level;
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        /* YOUR_JOB: Use an appearance value matching the application's use case.
           err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
           APP_ERROR_CHECK(err_code); */
        ble_gap_conn_sec_mode_t * p_perm;
        p_perm->lv=2;
        p_perm->sm=2;
        set_security_req_1(SEC_JUST_WORKS,p_perm);
    void set_security_req_1(security_req_t level, ble_gap_conn_sec_mode_t * p_perm)
        switch (level)
            case SEC_NO_ACCESS:
            case SEC_OPEN:
            case SEC_MITM:
            case SEC_SIGNED:
        return;
    Is this the correct way to call set_security_req?
    When I connect the device I get the following error.
