nrf51822 fix UART error Rate / SPI?
i am new to nRF Bluetooth. My Setup ist:
One Atmel atmega640 and one nrf51822 communication via UART (at the moment).
I am sending data from atmega640 to the nrf and i am experiencing an error-rate about 10% in incoming Data in the nrf when using a UARt Datarate of 38400 baud, which seems to be normal without using Hardware FlowControl. (devzone.nordicsemi.com/.../)
My Problem is at the moment, that i need a communication with less Errors and higher DataRate, but there is already a Hardware, which i have to use with only two traces (RX/TX) between both chips. Additionally there is no HWFW available on Atmel's Atmega.
I am thinking about switching to SPI, where i can use the two existing UART traces (can i assign any pin for SPI on the nRF51822, too?) and manually solder two additional cables für SPI's "clk" and "ce". The nRF51822 would act as SPI Slave.
Is this a good idea? Will this work better or do i have to expect similar or other Problems when using Softdevice S110 with SPI? Which maximum datarates can i expect with SPI and ATMega640 (with 16MHz external Clock) as SPI-Master?
