Configuring UART_1 for nRF9160
Hi Dev Team,
I was working with the nRF9160 and started off with the basic UART sample found here : https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160/uart
I wanted to configure the UART_1 to connect to an external sensor, and I followed some links : https://devzone.nordicsemi.com/f/nordic-q-a/45476/connecting-uart1-to-a-periph-on-nrf9160-dk/178988#178988, https://devzone.nordicsemi.com/f/nordic-q-a/57199/using-the-nrf9160-to-send-and-receive-data-over-rs485-using-uart and changed the prj.conf file and the overlays file.
prj.conf:
CONFIG_NEWLIB_LIBC=y
CONFIG_LIBLIGHTMODBUS=y
CONFIG_SERIAL=y
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_COMPILER_OPT="-DNRFX_UARTE_ENABLED=1 -DNRFX_UARTE0_ENABLED=1"
CONFIG_UART_1_NRF_UARTE=y
CONFIG_UART_1_NRF_FLOW_CONTROL=y
#CONFIG_BOARD_NRF9160DK_UART0_ARDUINO=y
#CONFIG_BOARD_NRF9160DK_UART0_VCOM=n
nrf9160dk_nrf9160ns.overlay:
/* Needed to get NRF_PWMn defined. */
&pwm1 {
	status = "okay";
&pwm2 {
	status = "okay";
&pwm3 {
	status = "okay";
&uart1 {
	current-speed = <9600>;
	status = "okay";
	tx-pin = <1>;
	rx-pin = <0>;
	rts-pin = <14>;
	cts-pin = <15>;
&uart0 {
	status = "ok";
	tx-pin = <10>;
	rx-pin = <11>;
	rts-pin = <12>;
	cts-pin = <13>;
The same is defined as an nrf9160dk_nrf9160.overlay file in the SPM folder.
When I try to build my application, I get a Kconfig error regarding the CONFIG_UART_1_NRF_UARTE=y. Could you help me understand what more could be required to change for it to work for UART_0.
Adeel.
  • Try to set RE high using nrf_gpio_pin_set() as well. As you can see here, setting RE high will disable the receiver (RE is LOW enable whle DE is high enable).
    Do you have a logic analyzer? Try attaching it to the lines to see what's actually going on.
    Simon
  • Hi Simon,
    I did that as well. I tried to set both the pins (RE-DE) to high before transmission so that DE is enabled and RE is disabled. Then after the transmission, I tried to give a bit of a delay and then cleared both the pins to low so that DE is disabled and RE gets enabled.
    I dont have a logic analyzer right now but will try to manage it.
    Are there any examples of RS485 communication for nRF9160DK that I could refer to for more info.
    Adeel.
  • Hi Simon,
    As I understood from the RS-485 transmit and receive logic, I tried to implement it in the following way:
    #include <zephyr.h>
    #include <sys/printk.h>
    #include <zephyr.h>
    #include <string.h>
    #include <drivers/uart.h>
    #include "nrf.h"
    #include <hal/nrf_gpio.h>
    #include <drivers/gpio.h>
    #define GPIO_PORT "GPIO_0"
    #define RS485_TRANSMIT       1
    #define RS485_RECEIVE        0
    #define RS485_SWITCH_PIN1    10  // Tx
    #define RS485_SWITCH_PIN2    11  // Rx
    #define MAX485_DE      12    // DE pin (rts)
    #define MAX485_RE_NEG  13    // RE pin (cts)
    static u8_t uart_buf[1024];
    static struct device *uart_dev;
    void uart_cb(struct device *_uart)
    	uart_irq_update(_uart); // Start processing interrupts in ISR.
    	int data_length = 0;
    	if (uart_irq_rx_ready(_uart)) { // Check if UART RX buffer has a received char.
    		data_length = uart_fifo_read(_uart, uart_buf, sizeof(uart_buf)); // Read data from FIFO.
    		uart_buf[data_length] = 0;
                    printk("Received data is:%s\r\n", uart_buf); // Output received here
    void uart_send_str(struct device *uart, char *str){
        printk("callback!\r\n");
        nrf_gpio_pin_set(MAX485_DE);   // Setting it High before Tx
        nrf_gpio_pin_set(MAX485_RE_NEG);  // Setting it low before Tx
        u32_t len = strlen(str);
        while (len--) {
            uart_poll_out(uart, *str++); // Transmission
            //uart_fifo_fill(uart, str, 2);
        k_sleep(K_MSEC(5000));   // Delay
        nrf_gpio_pin_clear(MAX485_DE);  // Setting low for reception
        nrf_gpio_pin_clear(MAX485_RE_NEG);  // Setting High for reception
    void main(void)
            char *command = "OKAZZZ";      // String to be transmitted out
            printk("Hello, World!\r\n");
            uart_dev = device_get_binding("UART_2");
            if (!uart_dev) {
    		printk("error\r\n");
            uart_irq_rx_disable(uart_dev);
            uart_irq_callback_set(uart_dev, uart_cb); // Set UART interrupt callback
            uart_irq_rx_enable(uart_dev);
            nrf_gpio_cfg_output(MAX485_DE); // Set DE as Output
            nrf_gpio_cfg_output(MAX485_RE_NEG); // Set RE as Output
    	while (1) {
                    printk("loop head\r\n");
                    uart_send_str(uart_dev, command); // Function to transmit the data
    My overlay file is as follows: nrf9160dk_nrf9160ns.overlay
    &uart2 {
    	status = "okay";
    	current-speed = <115200>;
    	tx-pin = <10>;
    	rx-pin = <11>;
    	rts-pin = <12>;
    	cts-pin = <13>;
    	hw-flow-control;
    &uart1 {
    	status = "disabled";
    Could you look at the logic to see if this is the right way to enable / disable the DE/RE pins. The hardware connections are as per the overlay file.
    The loopback works when I only connect Tx to Rx directly, so I guess the issue is only with the DE/RE pins. The loopback data is:
    I think I am close but just need some advice in enabling / disabling DE/RE pins in the code. Thanks for the help Slight smile.
    Adeel.
  • Hi Simon,
    I tried another example that looked much simpler and I just wanted to transmit things out of the UART.
    The code is pretty straight forward as well to understand.
    static K_FIFO_DEFINE(fifo_uart_tx_data);
    static K_FIFO_DEFINE(fifo_uart_rx_data);
    struct uart_data_t {
    	void  *fifo_reserved;
    	u8_t    data[1024];
    	u16_t   len;
    void uart_cb(struct device *x)
    	uart_irq_update(x); // Start processing interrupts in ISR.
    	if (uart_irq_rx_ready(x)) { // Check if UART RX buffer has a received char.
    		data_length = uart_fifo_read(x, uart_buf, sizeof(uart_buf)); // Read data from FIFO.
                if (uart_irq_tx_ready(x)) {
                    struct uart_data_t *buf =
                    k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
                  u16_t written = 0;
                  /* Nothing in the FIFO, nothing to send */
    		if (!buf) {
    			uart_irq_tx_disable(x);
    			return;
                    while (buf->len > written) {
    			written += uart_fifo_fill(x,
    						  &buf->data[written],
    						  buf->len - written);
                           uart_tx(uart_dev, buf, 5, 5000);
                    while (!uart_irq_tx_complete(x)) {
    			/* Wait for the last byte to get
    			 * shifted out of the module
    		if (k_fifo_is_empty(&fifo_uart_tx_data)) {
                    k_free(buf);
    void main(void)
            if (!uart_dev) {
            uart_irq_tx_enable(uart_dev);
            printk("Testing1: \n");
            uart_fifo_fill(uart_dev, "AB" ,sizeof("AB"));
            k_sleep(K_MSEC(100));
    	while (1) {
                      k_cpu_idle();
    Still, I don't see the data out on my analyzer. I have a serial interface analyzer where I view the string. I tried with Arduino and that worked just by a transmit signal.
    So, I am unsure as to what could be the causes for it. I can see the loopback data in this example as well when I connect my Tx to Rx.
    (1). I have the correct overlay files both in spm (nrf9160dk_nrf9160) as well as in my folder (nrf9160dk_nrf9160ns)
    &uart2 {
    	status = "okay";
    	tx-pin = <10>;
    	rx-pin = <11>;
    	rts-pin = <12>;
    	cts-pin = <13>;
    	hw-flow-control;
    &uart1 {
    I have also changed the configuration in the nrf9160dk_nrf9160_common.dts file in : C:\Users\adeel\ncs\v1.3.0\zephyr\boards\arm\nrf9160dk_nrf9160.
    My prj config file is :
    CONFIG_UART_ASYNC_API=y
    CONFIG_UART_2_NRF_FLOW_CONTROL=y
    I am unsure of what could be the issue ? The configuration or the code.
    I just want to transmit the string set in uart_fifo_fill() function in my code to check the UART connection.
    Adeel.
  • Sorry for the delay on this, I've been quite busy lately. I will look into it today. Have you made any progress?
    Simon
