I can see in Segger Embedded Studio v4.52 under the Build Tab, there are two methods to build the project.
1- Build > Build zephyr/zephyr.elf
2- Build > Build solution
What is the difference between the two methods?
Kind regards
Kind regards
Learner said:The link above shows spi-dev-a@0 has a chip select line defined in the parent node, yet 0 is used as index."An index representing the peripheral’s chip select line number. (If there is no chip select line, 0 is used.)
Yes, the SPI controller, which is the parent node, has a chip. But the SPI device, the child node, does not have a chip select. Therefore the unit-address is 0.
So, if there is no chip select line in that specific node 0 is used.
I would have accepted your answer if it was not for the definition of node b just below node a. Node b has no chip select line but the index used is NOT 0 but 1. See below an extract from spi.h.
* @brief Does a SPI device have a chip select line configured?
* Example devicetree fragment:
* spi1: spi@... {
* compatible = "vnd,spi";
* cs-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>,
* <&gpio2 20 GPIO_ACTIVE_LOW>;
* a: spi-dev-a@0 {
* reg = <0>;
* b: spi-dev-b@1 {
* reg = <1>;
* spi2: spi@... {
* c: spi-dev-c@0 {
* reg = <0>;
* Example usage:
* DT_SPI_DEV_HAS_CS_GPIOS(DT_NODELABEL(a)) // 1
* DT_SPI_DEV_HAS_CS_GPIOS(DT_NODELABEL(b)) // 1
* DT_SPI_DEV_HAS_CS_GPIOS(DT_NODELABEL(c)) // 0
* @param spi_dev a SPI device node identifier
* @return 1 if spi_dev's bus node DT_BUS(spi_dev) has a chip select
* pin at index DT_REG_ADDR(spi_dev), 0 otherwise
Okay, so for the node for AIN_5, you can use the voltage-divider compatible property.
Great news!
So, how would the overlay file look? and where must I store the .yaml file? Can I put it in the same folder as the prj.conf file?
Kind regards
Mohamed
Please ignore my question about the yaml file.
I have had an attempt at creating this overlay file. Would this overlay file do the job?
&adc {
compatible = "voltage-divider";
adc5: {
label = "AIN_5";
adc7: {
label = "AIN_7";
n: node {
io-channels = <&adc5 26>, <&adc7 28>;
io-channel-names = "FOIL", "STRAP";
Looking at the yaml file, line 21 is referring to Resistance of the lower leg of the voltage divider. But in our case the lower is not a resistance but a capacitance. Is this ok?
Assuming I can use the "voltage-divider"compatible property, I can do the binding using this
adc_dev_5 = device_get_binding("AIN_5"); adc_dev_7 = device_get_binding("AIN_7");
Please confirm if I am on the right path...
Kind regards
Mohamed
The numbers 26 and 28 refer to the pin numbers on PORT0 used for AIN5 and AIN7.
Hi Heidi,
I give up. I tried few flavours of the overlay file and none worked. The project always fail to load.
# Method 1:
&adc {
# compatible = "nordic,nrf-saadc";
adc5:adc@... {
label = "AIN_5";
adc7:adc@... {
label = "AIN_5";
n: node {
# Method 2:
adc0: adc@4000E000 {
# compatible = "voltage-divider";
label = "ADC_0";
n: node {
io-channels = <&adc0 4>;
io-channel-names = "AIN_0";
Kind regards
Mohamed
Hi again!
So, first of all, to answer your questions about SPI:
You are right, I did not catch that part. I have sent a message to the Nordic developer that has written this, but since they are based in LA I won't have an answer on this until tomorrow.
I just received an answer about this.
"An index representing the peripheral’s chip select line number. (If there is no chip select line, 0 is used.)"
The spi1 node has a cs-gpios property, which means that the unit addresses for node a and b (0 and 1 respectively) are indexes into the cs-gpios array (an index representing the peripheral's chip select line number). The spi1 node has no cs-gpios, so node c has no chip select configured in the device tree, and therefore its unit address is left at 0 (if there is no chip select line, 0 is used).
In all your overlay examples you're still instantiating the ADC peripheral, which we don't want to do.
This is the template you want to follow:
n: node {
compatible = " ";
io-channels = <&adc 4>;
label = "AIN_0";
The forward slash indicates the root node and is very important to include.
To include multiple ADC io-channels, just refer to the adc-node each time like this (not &adc5 and &adc7):
io-channels = <&adc 26>, <&adc 28>;
and if you want to use a different compatible property for the two nodes, you need to create two separate nodes like this:
n: node_a {
compatible = " ";
io-channels = <&adc 26>;
label = "AIN_5";
n: node_b {
compatible = " ";
io-channels = <&adc 28>;
label = "AIN_7";
For you question about voltage-divider
The lower leg is not a resistor, but the other one is a resistor? Or are you using a capacitive divider where both elements are capacitors?
For your binding question, yes this is the correct way to do it, using the label you defined in the node.
To do the binding for the two analog inputs, this is how to do it for AIN_5 and AIN_7 respectively.
device_get_binding(DT_IO_CHANNELS_LABEL_BY_IDX(DT_NODELABEL(n),0))
device_get_binding(DT_IO_CHANNELS_LABEL_BY_IDX(DT_NODELABEL(n),1))
Heidi
