MPU6050 connected with nrf52840dk : not showing anything on terminal
mpu6050 connections
vcc-->vdd
gnd-->gnd
scl-->pin 27
sda-->pin 26
Main.c
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "mpu6050.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
// main code
// initialize the logger
// create arrays which will hold x,y & z co-ordinates values of acc and gyro
    static int16_t AccValue[3], GyroValue[3];
    bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS); // initialize the leds and buttons
    twi_master_init(); // initialize the twi
    nrf_delay_ms(1000); // give some delay
    while(mpu6050_init() == false) // wait until MPU6050 sensor is successfully initialized
      NRF_LOG_INFO("MPU_6050 initialization failed!!!"); // if it failed to initialize then print a message
      nrf_delay_ms(1000);
   NRF_LOG_INFO("MPU6050 Init Successfully!!!");
   NRF_LOG_INFO("Reading Values from ACC & GYRO"); // display a message to let the user know that the device is starting to read the values
   nrf_delay_ms(2000);
    while (true)
        if(MPU6050_ReadAcc(&AccValue[0], &AccValue[1], &AccValue[2]) == true) // Read acc value from mpu6050 internal registers and save them in the array
          NRF_LOG_INFO("ACC Values:  x = %d  y = %d  z = %d", AccValue[0], AccValue[1], AccValue[2]); // display the read values
          NRF_LOG_INFO("Reading ACC values Failed!!!"); // if reading was unsuccessful then let the user know about it
        if(MPU6050_ReadGyro(&GyroValue[0], &GyroValue[1], &GyroValue[2]) == true) // read the gyro values from mpu6050's internal registers and save them in another array
          NRF_LOG_INFO("GYRO Values: x = %d  y = %d  z = %d", GyroValue[0], GyroValue[1], GyroValue[2]); // display then values
          NRF_LOG_INFO("Reading GYRO values Failed!!!");
       nrf_delay_ms(100); // give some delay
mpu6050.h
#ifndef AT24C02_H__
#define AT24C02_H__
#include "nrf_delay.h"
//I2C Pins Settings, you change them to any other pins
#define TWI_SCL_M           27         //I2C SCL Pin
#define TWI_SDA_M           26         //I2C SDA Pin
#define MPU6050_ADDRESS_LEN  1         //MPU6050
#define MPU6050_ADDRESS     (0xD0>>1)  //MPU6050 Device Address
#define MPU6050_WHO_AM_I     0x68U     //MPU6050 ID
#define MPU6050_GYRO_OUT        0x43
#define MPU6050_ACC_OUT         0x3B
#define ADDRESS_WHO_AM_I          (0x75U) //  WHO_AM_I register identifies the device. Expected value is 0x68.
#define ADDRESS_SIGNAL_PATH_RESET (0x68U) //
//MPU6050 Registers addresses, see datasheet for more info and each register's function
#define MPU_SELF_TESTX_REG		0x0D
#define MPU_SELF_TESTY_REG		0x0E
#define MPU_SELF_TESTZ_REG		0x0F
#define MPU_SELF_TESTA_REG		0x10
#define MPU_SAMPLE_RATE_REG		0x19
#define MPU_CFG_REG                     0x1A
#define MPU_GYRO_CFG_REG		0x1B
#define MPU_ACCEL_CFG_REG		0x1C
#define MPU_MOTION_DET_REG		0x1F
#define MPU_FIFO_EN_REG			0x23
#define MPU_I2CMST_CTRL_REG		0x24
#define MPU_I2CSLV0_ADDR_REG            0x25
#define MPU_I2CSLV0_REG			0x26
#define MPU_I2CSLV0_CTRL_REG            0x27
#define MPU_I2CSLV1_ADDR_REG            0x28
#define MPU_I2CSLV1_REG			0x29
#define MPU_I2CSLV1_CTRL_REG            0x2A
#define MPU_I2CSLV2_ADDR_REG            0x2B
#define MPU_I2CSLV2_REG			0x2C
#define MPU_I2CSLV2_CTRL_REG            0x2D
#define MPU_I2CSLV3_ADDR_REG            0x2E
#define MPU_I2CSLV3_REG			0x2F
#define MPU_I2CSLV3_CTRL_REG            0x30
#define MPU_I2CSLV4_ADDR_REG            0x31
#define MPU_I2CSLV4_REG			0x32
#define MPU_I2CSLV4_DO_REG		0x33
#define MPU_I2CSLV4_CTRL_REG            0x34
#define MPU_I2CSLV4_DI_REG		0x35
#define MPU_PWR_MGMT1_REG		0x6B
#define MPU_PWR_MGMT2_REG		0x6C
#define MPU_I2CMST_STA_REG		0x36
#define MPU_INTBP_CFG_REG		0x37
#define MPU_INT_EN_REG			0x38
#define MPU_INT_STA_REG			0x3A
#define MPU_I2CMST_DELAY_REG            0x67
#define MPU_SIGPATH_RST_REG		0x68
#define MPU_MDETECT_CTRL_REG            0x69
#define MPU_USER_CTRL_REG		0x6A
#define MPU_FIFO_CNTH_REG		0x72
#define MPU_FIFO_CNTL_REG		0x73
#define MPU_FIFO_RW_REG			0x74
#define MPU_DEVICE_ID_REG		0x75
void twi_master_init(void); // initialize the twi communication
bool mpu6050_init(void);    // initialize the mpu6050
  @brief Function for writing a MPU6050 register contents over TWI.
  @param[in]  register_address Register address to start writing to
  @param[in] value Value to write to register
  @retval true Register write succeeded
  @retval false Register write failed
bool mpu6050_register_write(uint8_t register_address, const uint8_t value);
  @brief Function for reading MPU6050 register contents over TWI.
  Reads one or more consecutive registers.
  @param[in]  register_address Register address to start reading from
  @param[in]  number_of_bytes Number of bytes to read
  @param[out] destination Pointer to a data buffer where read data will be stored
  @retval true Register read succeeded
  @retval false Register read failed
bool mpu6050_register_read(uint8_t register_address, uint8_t *destination, uint8_t number_of_bytes);
  @brief Function for reading and verifying MPU6050 product ID.
  @retval true Product ID is what was expected
  @retval false Product ID was not what was expected
bool mpu6050_verify_product_id(void);
bool MPU6050_ReadGyro(int16_t *pGYRO_X , int16_t *pGYRO_Y , int16_t *pGYRO_Z );
bool MPU6050_ReadAcc( int16_t *pACC_X , int16_t *pACC_Y , int16_t *pACC_Z );
mpu6050.c
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
//Initializing TWI0 instance
#define TWI_INSTANCE_ID     0
// A flag to indicate the transfer state
static volatile bool m_xfer_done = false;
// Create a Handle for the twi communication
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
//Event Handler
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    //Check the event to see what type of event occurred
    switch (p_event->type)
        //If data transmission or receiving is finished
	case NRF_DRV_TWI_EVT_DONE:
        m_xfer_done = true;//Set the flag
        // do nothing
//Initialize the TWI as Master device
    ret_code_t err_code;
    // Configure the settings for twi communication
    const nrf_drv_twi_config_t twi_config = {
       .scl                = TWI_SCL_M,  //SCL Pin
       .sda                = TWI_SDA_M,  //SDA Pin
       .frequency          = NRF_DRV_TWI_FREQ_400K, //Communication Speed
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH, //Interrupt Priority(Note: if using Bluetooth then select priority carefully)
       .clear_bus_init     = false //automatically clear bus
    //A function to initialize the twi communication
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
    //Enable the TWI Communication
    nrf_drv_twi_enable(&m_twi);
   A function to write a Single Byte to MPU6050's internal Register
bool mpu6050_register_write(uint8_t register_address, uint8_t value)
    uint8_t tx_buf[MPU6050_ADDRESS_LEN+1];
    //Write the register address and data into transmit buffer
    tx_buf[0] = register_address;
    tx_buf[1] = value;
    //Set the flag to false to show the transmission is not yet completed
    //Transmit the data over TWI Bus
    err_code = nrf_drv_twi_tx(&m_twi, MPU6050_ADDRESS, tx_buf, MPU6050_ADDRESS_LEN+1, false);
    //Wait until the transmission of the data is finished
    while (m_xfer_done == false)
    // if there is no error then return true else return false
    if (NRF_SUCCESS != err_code)
        return false;
    return true;
  A Function to read data from the MPU6050
bool mpu6050_register_read(uint8_t register_address, uint8_t * destination, uint8_t number_of_bytes)
    //Set the flag to false to show the receiving is not yet completed
    // Send the Register address where we want to write the data
    err_code = nrf_drv_twi_tx(&m_twi, MPU6050_ADDRESS, &register_address, 1, true);
    //Wait for the transmission to get completed
    while (m_xfer_done == false){}
    // If transmission was not successful, exit the function with false as return value
        return false;
    //set the flag again so that we can read data from the MPU6050's internal register
    // Receive the data from the MPU6050
    err_code = nrf_drv_twi_rx(&m_twi, MPU6050_ADDRESS, destination, number_of_bytes);
    //wait until the transmission is completed
    // if data was successfully read, return true else return false
        return false;
    return true;
  A Function to verify the product id
  (its a basic test to check if we are communicating with the right slave, every type of I2C Device has
  a special WHO_AM_I register which holds a specific value, we can read it from the MPU6050 or any device
  to confirm we are communicating with the right device)
    uint8_t who_am_i; // create a variable to hold the who am i value
    // Note: All the register addresses including WHO_AM_I are declared in
    // MPU6050.h file, you can check these addresses and values from the
    // datasheet of your slave device.
    if (mpu6050_register_read(ADDRESS_WHO_AM_I, &who_am_i, 1))
        if (who_am_i != MPU6050_WHO_AM_I)
            return false;
            return true;
        return false;
  Function to initialize the mpu6050
  bool transfer_succeeded = true;
  //Check the id to confirm that we are communicating with the right device
  transfer_succeeded &= mpu6050_verify_product_id();
  if(mpu6050_verify_product_id() == false)
	return false;
  // Set the registers with the required values, see the datasheet to get a good idea of these values
  (void)mpu6050_register_write(MPU_PWR_MGMT1_REG , 0x00);
  (void)mpu6050_register_write(MPU_SAMPLE_RATE_REG , 0x07);
  (void)mpu6050_register_write(MPU_CFG_REG , 0x06);
  (void)mpu6050_register_write(MPU_INT_EN_REG, 0x00);
  (void)mpu6050_register_write(MPU_GYRO_CFG_REG , 0x18);
  (void)mpu6050_register_write(MPU_ACCEL_CFG_REG,0x00);
  return transfer_succeeded;
  Read the Gyro values from the MPU6050's internal Registers
  uint8_t buf[6];
  bool ret = false;
  if(mpu6050_register_read(MPU6050_GYRO_OUT,  buf, 6) == true)
    *pGYRO_X = (buf[0] << 8) | buf[1];
    if(*pGYRO_X & 0x8000) *pGYRO_X-=65536;
    *pGYRO_Y= (buf[2] << 8) | buf[3];
    if(*pGYRO_Y & 0x8000) *pGYRO_Y-=65536;
    *pGYRO_Z = (buf[4] << 8) | buf[5];
    if(*pGYRO_Z & 0x8000) *pGYRO_Z-=65536;
    ret = true;
  return ret;
  A Function to read accelerometer's values from the internal registers of MPU6050
  uint8_t buf[6];
  bool ret = false;
  if(mpu6050_register_read(MPU6050_ACC_OUT, buf, 6) == true)
    mpu6050_register_read(MPU6050_ACC_OUT, buf, 6);
    *pACC_X = (buf[0] << 8) | buf[1];
    if(*pACC_X & 0x8000) *pACC_X-=65536;
    *pACC_Y= (buf[2] << 8) | buf[3];
    if(*pACC_Y & 0x8000) *pACC_Y-=65536;
    *pACC_Z = (buf[4] << 8) | buf[5];
    if(*pACC_Z & 0x8000) *pACC_Z-=65536;
    ret = true;
  return ret;
i also tried in putty, but nothing is showing in the terminal
any answers, without hesitation ask any question.
  • Set RTT_BACKEND back to 0, and UART_BACKEND back to 1.
    Make sure NRF_LOG_ENABLED is defined to 1 also.
    i have done what you have said above.
    Make these changes, and let me know if you are seeing anything in your putty terminal following this.
    i have made the changes, but nothing is shown in putty terminal.
    i have only changed the pin numbers to 27 and 26 from 22,23 from the mpu6050.h, from the files in the video.
    putty terminal is just showing a blank screen,
    can you suggest me some solution
    Sorry for my late reply.
    Great. Could you share your sdk_config file, so I may take a look? I just want to rule out the possibility that we are overlooking a define here.
    Did you do as I suggested, and take a look at the code supplied with the tutorial you are following? The tutorial's author has included the source code in the video description, you should take a look at the authors sdk_config file, to see how it is different to your own.
    Looking forward to resolving this issue together!
    Karl
  • Great. Could you share your sdk_config file, so I may take a look? I just want to rule out the possibility that we are overlooking a define here.
    the sdk file
    https://drive.google.com/drive/folders/1jlCYiiSo4Ez7Fjs5j_bELG4sxPdK5bZf?usp=sharing
    the above link takes you to twi_mpu6050 folder pca10056--> ses file
    i put the same main.c file and followed all the instructions told in the video, there was no sdk file in the description of the video only main.c , mpu6050.c, mpu6050.h file.
  • saver said:
    the sdk file
    I see now that you are using the twi_scanner example as a base for your application. The example uses deferred logging, which means that you will need to call NRF_LOG_PROCESS() at some point, to have the logs be processed.
    Could you try to define NRF_LOG_DEFERRED to 0, and see if you then see the logger output in your putty terminal?
    Alternatively, you should call NRF_LOG_PROCESS at some point in your main loop.
    Let me know if this resolves your issue,
    Karl
  • Could you try to define NRF_LOG_DEFERRED to 0, and see if you then see the logger output in your putty terminal?
    Thanks, now it is showing the gyro meter values, very much Thank you!!!
    I don't understand what you mean by this, can you please elaborate.
    yes, but can you also tell me how to calibrate the sensor.
