MPU6050 connected with nrf52840dk : not showing anything on terminal
mpu6050 connections
vcc-->vdd
gnd-->gnd
scl-->pin 27
sda-->pin 26
Main.c
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "mpu6050.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
// main code
// initialize the logger
// create arrays which will hold x,y & z co-ordinates values of acc and gyro
    static int16_t AccValue[3], GyroValue[3];
    bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS); // initialize the leds and buttons
    twi_master_init(); // initialize the twi
    nrf_delay_ms(1000); // give some delay
    while(mpu6050_init() == false) // wait until MPU6050 sensor is successfully initialized
      NRF_LOG_INFO("MPU_6050 initialization failed!!!"); // if it failed to initialize then print a message
      nrf_delay_ms(1000);
   NRF_LOG_INFO("MPU6050 Init Successfully!!!");
   NRF_LOG_INFO("Reading Values from ACC & GYRO"); // display a message to let the user know that the device is starting to read the values
   nrf_delay_ms(2000);
    while (true)
        if(MPU6050_ReadAcc(&AccValue[0], &AccValue[1], &AccValue[2]) == true) // Read acc value from mpu6050 internal registers and save them in the array
          NRF_LOG_INFO("ACC Values:  x = %d  y = %d  z = %d", AccValue[0], AccValue[1], AccValue[2]); // display the read values
          NRF_LOG_INFO("Reading ACC values Failed!!!"); // if reading was unsuccessful then let the user know about it
        if(MPU6050_ReadGyro(&GyroValue[0], &GyroValue[1], &GyroValue[2]) == true) // read the gyro values from mpu6050's internal registers and save them in another array
          NRF_LOG_INFO("GYRO Values: x = %d  y = %d  z = %d", GyroValue[0], GyroValue[1], GyroValue[2]); // display then values
          NRF_LOG_INFO("Reading GYRO values Failed!!!");
       nrf_delay_ms(100); // give some delay
mpu6050.h
#ifndef AT24C02_H__
#define AT24C02_H__
#include "nrf_delay.h"
//I2C Pins Settings, you change them to any other pins
#define TWI_SCL_M           27         //I2C SCL Pin
#define TWI_SDA_M           26         //I2C SDA Pin
#define MPU6050_ADDRESS_LEN  1         //MPU6050
#define MPU6050_ADDRESS     (0xD0>>1)  //MPU6050 Device Address
#define MPU6050_WHO_AM_I     0x68U     //MPU6050 ID
#define MPU6050_GYRO_OUT        0x43
#define MPU6050_ACC_OUT         0x3B
#define ADDRESS_WHO_AM_I          (0x75U) //  WHO_AM_I register identifies the device. Expected value is 0x68.
#define ADDRESS_SIGNAL_PATH_RESET (0x68U) //
//MPU6050 Registers addresses, see datasheet for more info and each register's function
#define MPU_SELF_TESTX_REG		0x0D
#define MPU_SELF_TESTY_REG		0x0E
#define MPU_SELF_TESTZ_REG		0x0F
#define MPU_SELF_TESTA_REG		0x10
#define MPU_SAMPLE_RATE_REG		0x19
#define MPU_CFG_REG                     0x1A
#define MPU_GYRO_CFG_REG		0x1B
#define MPU_ACCEL_CFG_REG		0x1C
#define MPU_MOTION_DET_REG		0x1F
#define MPU_FIFO_EN_REG			0x23
#define MPU_I2CMST_CTRL_REG		0x24
#define MPU_I2CSLV0_ADDR_REG            0x25
#define MPU_I2CSLV0_REG			0x26
#define MPU_I2CSLV0_CTRL_REG            0x27
#define MPU_I2CSLV1_ADDR_REG            0x28
#define MPU_I2CSLV1_REG			0x29
#define MPU_I2CSLV1_CTRL_REG            0x2A
#define MPU_I2CSLV2_ADDR_REG            0x2B
#define MPU_I2CSLV2_REG			0x2C
#define MPU_I2CSLV2_CTRL_REG            0x2D
#define MPU_I2CSLV3_ADDR_REG            0x2E
#define MPU_I2CSLV3_REG			0x2F
#define MPU_I2CSLV3_CTRL_REG            0x30
#define MPU_I2CSLV4_ADDR_REG            0x31
#define MPU_I2CSLV4_REG			0x32
#define MPU_I2CSLV4_DO_REG		0x33
#define MPU_I2CSLV4_CTRL_REG            0x34
#define MPU_I2CSLV4_DI_REG		0x35
#define MPU_PWR_MGMT1_REG		0x6B
#define MPU_PWR_MGMT2_REG		0x6C
#define MPU_I2CMST_STA_REG		0x36
#define MPU_INTBP_CFG_REG		0x37
#define MPU_INT_EN_REG			0x38
#define MPU_INT_STA_REG			0x3A
#define MPU_I2CMST_DELAY_REG            0x67
#define MPU_SIGPATH_RST_REG		0x68
#define MPU_MDETECT_CTRL_REG            0x69
#define MPU_USER_CTRL_REG		0x6A
#define MPU_FIFO_CNTH_REG		0x72
#define MPU_FIFO_CNTL_REG		0x73
#define MPU_FIFO_RW_REG			0x74
#define MPU_DEVICE_ID_REG		0x75
void twi_master_init(void); // initialize the twi communication
bool mpu6050_init(void);    // initialize the mpu6050
  @brief Function for writing a MPU6050 register contents over TWI.
  @param[in]  register_address Register address to start writing to
  @param[in] value Value to write to register
  @retval true Register write succeeded
  @retval false Register write failed
bool mpu6050_register_write(uint8_t register_address, const uint8_t value);
  @brief Function for reading MPU6050 register contents over TWI.
  Reads one or more consecutive registers.
  @param[in]  register_address Register address to start reading from
  @param[in]  number_of_bytes Number of bytes to read
  @param[out] destination Pointer to a data buffer where read data will be stored
  @retval true Register read succeeded
  @retval false Register read failed
bool mpu6050_register_read(uint8_t register_address, uint8_t *destination, uint8_t number_of_bytes);
  @brief Function for reading and verifying MPU6050 product ID.
  @retval true Product ID is what was expected
  @retval false Product ID was not what was expected
bool mpu6050_verify_product_id(void);
bool MPU6050_ReadGyro(int16_t *pGYRO_X , int16_t *pGYRO_Y , int16_t *pGYRO_Z );
bool MPU6050_ReadAcc( int16_t *pACC_X , int16_t *pACC_Y , int16_t *pACC_Z );
mpu6050.c
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
//Initializing TWI0 instance
#define TWI_INSTANCE_ID     0
// A flag to indicate the transfer state
static volatile bool m_xfer_done = false;
// Create a Handle for the twi communication
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
//Event Handler
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    //Check the event to see what type of event occurred
    switch (p_event->type)
        //If data transmission or receiving is finished
	case NRF_DRV_TWI_EVT_DONE:
        m_xfer_done = true;//Set the flag
        // do nothing
//Initialize the TWI as Master device
    ret_code_t err_code;
    // Configure the settings for twi communication
    const nrf_drv_twi_config_t twi_config = {
       .scl                = TWI_SCL_M,  //SCL Pin
       .sda                = TWI_SDA_M,  //SDA Pin
       .frequency          = NRF_DRV_TWI_FREQ_400K, //Communication Speed
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH, //Interrupt Priority(Note: if using Bluetooth then select priority carefully)
       .clear_bus_init     = false //automatically clear bus
    //A function to initialize the twi communication
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
    //Enable the TWI Communication
    nrf_drv_twi_enable(&m_twi);
   A function to write a Single Byte to MPU6050's internal Register
bool mpu6050_register_write(uint8_t register_address, uint8_t value)
    uint8_t tx_buf[MPU6050_ADDRESS_LEN+1];
    //Write the register address and data into transmit buffer
    tx_buf[0] = register_address;
    tx_buf[1] = value;
    //Set the flag to false to show the transmission is not yet completed
    //Transmit the data over TWI Bus
    err_code = nrf_drv_twi_tx(&m_twi, MPU6050_ADDRESS, tx_buf, MPU6050_ADDRESS_LEN+1, false);
    //Wait until the transmission of the data is finished
    while (m_xfer_done == false)
    // if there is no error then return true else return false
    if (NRF_SUCCESS != err_code)
        return false;
    return true;
  A Function to read data from the MPU6050
bool mpu6050_register_read(uint8_t register_address, uint8_t * destination, uint8_t number_of_bytes)
    //Set the flag to false to show the receiving is not yet completed
    // Send the Register address where we want to write the data
    err_code = nrf_drv_twi_tx(&m_twi, MPU6050_ADDRESS, &register_address, 1, true);
    //Wait for the transmission to get completed
    while (m_xfer_done == false){}
    // If transmission was not successful, exit the function with false as return value
        return false;
    //set the flag again so that we can read data from the MPU6050's internal register
    // Receive the data from the MPU6050
    err_code = nrf_drv_twi_rx(&m_twi, MPU6050_ADDRESS, destination, number_of_bytes);
    //wait until the transmission is completed
    // if data was successfully read, return true else return false
        return false;
    return true;
  A Function to verify the product id
  (its a basic test to check if we are communicating with the right slave, every type of I2C Device has
  a special WHO_AM_I register which holds a specific value, we can read it from the MPU6050 or any device
  to confirm we are communicating with the right device)
    uint8_t who_am_i; // create a variable to hold the who am i value
    // Note: All the register addresses including WHO_AM_I are declared in
    // MPU6050.h file, you can check these addresses and values from the
    // datasheet of your slave device.
    if (mpu6050_register_read(ADDRESS_WHO_AM_I, &who_am_i, 1))
        if (who_am_i != MPU6050_WHO_AM_I)
            return false;
            return true;
        return false;
  Function to initialize the mpu6050
  bool transfer_succeeded = true;
  //Check the id to confirm that we are communicating with the right device
  transfer_succeeded &= mpu6050_verify_product_id();
  if(mpu6050_verify_product_id() == false)
	return false;
  // Set the registers with the required values, see the datasheet to get a good idea of these values
  (void)mpu6050_register_write(MPU_PWR_MGMT1_REG , 0x00);
  (void)mpu6050_register_write(MPU_SAMPLE_RATE_REG , 0x07);
  (void)mpu6050_register_write(MPU_CFG_REG , 0x06);
  (void)mpu6050_register_write(MPU_INT_EN_REG, 0x00);
  (void)mpu6050_register_write(MPU_GYRO_CFG_REG , 0x18);
  (void)mpu6050_register_write(MPU_ACCEL_CFG_REG,0x00);
  return transfer_succeeded;
  Read the Gyro values from the MPU6050's internal Registers
  uint8_t buf[6];
  bool ret = false;
  if(mpu6050_register_read(MPU6050_GYRO_OUT,  buf, 6) == true)
    *pGYRO_X = (buf[0] << 8) | buf[1];
    if(*pGYRO_X & 0x8000) *pGYRO_X-=65536;
    *pGYRO_Y= (buf[2] << 8) | buf[3];
    if(*pGYRO_Y & 0x8000) *pGYRO_Y-=65536;
    *pGYRO_Z = (buf[4] << 8) | buf[5];
    if(*pGYRO_Z & 0x8000) *pGYRO_Z-=65536;
    ret = true;
  return ret;
  A Function to read accelerometer's values from the internal registers of MPU6050
  uint8_t buf[6];
  bool ret = false;
  if(mpu6050_register_read(MPU6050_ACC_OUT, buf, 6) == true)
    mpu6050_register_read(MPU6050_ACC_OUT, buf, 6);
    *pACC_X = (buf[0] << 8) | buf[1];
    if(*pACC_X & 0x8000) *pACC_X-=65536;
    *pACC_Y= (buf[2] << 8) | buf[3];
    if(*pACC_Y & 0x8000) *pACC_Y-=65536;
    *pACC_Z = (buf[4] << 8) | buf[5];
    if(*pACC_Z & 0x8000) *pACC_Z-=65536;
    ret = true;
  return ret;
i also tried in putty, but nothing is showing in the terminal
any answers, without hesitation ask any question.
  • saver said:
    Thanks, now it is showing the gyro meter values, very much Thank you!!!
    Fantastic! I am glad we were able to identify and resolve the issue.
    saver said:
    I don't understand what you mean by this, can you please elaborate.
    The logger module comes with a great feature called "deferred logging", you can read about this in its entirety in the logger documentation, but in essence, it allows you to defer logger processing until it is suitable for the application.
    Sometimes, you might want to write logs during timing-critical operations, adding a bunch of logging may then cause trouble for your timing sequences, and otherwise mess with your application. You may then instead use deferred logging, which lets you control when the processing ( and output ) of the log will take place.
    If you take a look through the examples, the NRF_LOG_PROCESS function is often called as a part of the idle_state_handler, i.e when the CPU has nothing more important to do, it can process its logs and go to sleep. This is a great way to use deferred logging, since it will minimize the logging effect on your application.
    Does this make the deferred logging option more clear? Please do not hesitate to ask, if anything still should be unclear.
    saver said:
    yes, but can you also tell me how to calibrate the sensor.
    Do you have the sensors datasheet? I am not familiar with the particular sensor you are working with, but I assume there should be a section in its datasheet regarding how to initiate and complete calibration.
    Please try to find this section, and let me know if there is anything in particular there that you would like me to take a look at. Please also bear in mind that since the sensor is not a Nordic product, you might have to take any issues up with its manufacturer directly.
    Karl
  • Thank you Karl for helping me!!!
    No problem at all, saver! I am happy to help! :)
    Please do not hesitate to open a new ticket if you should encounter any issues or questions in the future.
    Karl
