TWI SDA SCL held low during reset when using TWIS
Hi to community!
I have a trouble with nRF52840 when using TWIS. I initialize the peripheral by below code. If the device is reset using default pin 18 by the external controller, SDA and SCL pins are held low, so the communication with other sensors on bus is broken. Is there a way for the mentioned signals to be in Hi-Z during reset?
nrf_gpio_cfg(26U, NRF_GPIO_PIN_DIR_INPUT, NRF_GPIO_PIN_INPUT_CONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_S0D1, NRF_GPIO_PIN_NOSENSE);
nrf_gpio_cfg(27U, NRF_GPIO_PIN_DIR_INPUT, NRF_GPIO_PIN_INPUT_CONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_S0D1, NRF_GPIO_PIN_NOSENSE);
const nrf_drv_twis_config_t config =
.addr = {0x0BU, 0U},
.scl = 27U,
.sda = 26U,
.scl_pull = NRF_GPIO_PIN_PULLUP,
.sda_pull = NRF_GPIO_PIN_PULLUP,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH
nrf_drv_twis_init(&f_i2c, &config, i2c_event_handler);
It behaves in same way if the first two lines (nrf_gpio_cfg) are omitted.
Thank in advance for any help with this problem.
