thingy:91 can't program
Hi, I just got my Thingy:91 and I'm trying to run through the getting started guide. On the nRF Connector v3.6.0 app, it doesn't change from "no devices available" to "select device". I hold down SW3 while powering on. When I don't hold SW3, the LEDs turn on and when I do hold SW3, the LEDs don't turn on, so it seems SW3 does make a difference. A window also pops up showing the contents of the USB drive, and I'm able to open and read the files, so it seems the USB connection is working (Config, README, etc.). The SIM card is in.
Any ideas? Thanks.
  • Hi eyss5,
    Which app in nRF Connect for Desktop are you testing?
    If you hold down the SW3 while powering the device ON (Setting the device in Serial boot mode) it is not seen in the "Programmer app"?
    What operating system do you have?
    br,
    martin
  • Which app in nRF Connect for Desktop are you testing?
    [ey] Programmer, v1.4.7
    [ey] Correct, but either with SW3 pressed or not, when I turn on the Thingy91, the USB window pops up and i can open the files correctly ("Zephyr USB")
    [ey] Win 8.1 64bit. Pretty old laptop, but I've been using it to do nRF52 development with SES/power profiler/etc. and I haven't run into any issues. Is there an incompatibility here?
    Thanks for the response.
  • Hi eyss5,
    Could you make sure the switch is set to "nrf91" and also try to do this on another computer?
    Could you also check if you get three new COM ports pop up in the Device Manager in windows when you connect the device?
    br,
    martin L
  • switch is set to "nrf91"
    I get 2 "Thingy:91 UART" devices that pop up under "Other devices" with a yellow ! and that's it. Have you seen that before?
    I'll try on another computer. Thanks!
  • Hi, I switched to a diff Win10 computer and it seems to work. I am now able to update the application firmware and modem firmware. I see 2 COM ports, not 3. Reading through other posts and the guide, this seems to be correct? I'm using Thingy:91 over USB, not the debug header.
    However, after updating these 2 items, the LEDs no longer turn on and it no longer connects to nRFcloud. This worked before the updates. I had a blue LED and I saw data on the dashboard. Any thoughts? Do I need to update the nrf52840?
    app firmware: nrf9160dk_asset_tracker_item_2020-10-30_5522ca2b.hex
    modem firmware: mfwnrf9160122.zip
    Both complete successfully, but I need to reboot my thingy91 after the app fw update, otherwise the modem fw update will give me the error "MCUboot DFU failed.. Please make sure .. mode try again". Rebooting the Thingy91 gets me through, for some reason.
