Device Name changing with nRF52840 using sd_ble_gap_device_name_set in Python
I'm trying to make a script in Python using the nRF52840 dongle, to make some BLE advertising.
I'm using:
- Python 3.7.2 (32 bit)
- pc_ble_driver_py library
- Windows 10
- Visual Code
- nRF52840 dongle with USB CDC ACM FW
Now I would like to set a name to my device as I can see it through nRF APP on my mobile phone.
Searching through similar issues in other posts, I've found this function sd_ble_gap_device_name_set, which defined as follow:
def sd_ble_gap_device_name_set(adapter, p_write_perm, p_dev_name, len):
 return _nrf_ble_driver_sd_api_v2.sd_ble_gap_device_name_set(adapter, p_write_perm, p_dev_name, len)
To figure out how to use it, I've searched in some tutorials and found Bluetooth low energy Advertising, a beginner's tutorial which are written in C;
The function in C is declared as follow:
uint32_t sd_ble_gap_device_name_set	(	ble_gap_conn_sec_mode_t const * 	p_write_perm,
                                        uint8_t const * 	p_dev_name,
                                        uint16_t 	len
In my script, the function is used as follow:
    # Device Name Change
    device_name = split_str(DEVICE_NAME)
    gap_device_name = [hex(ord(x)) for x in device_name]
    str_length = len(DEVICE_NAME.encode(encoding='utf_8'))
    driver.sd_ble_gap_device_name_set(
            peripheral.adapter.driver.rpc_adapter,
            None,
            DEVICE_NAME.encode(encoding='utf_8'),
            str_length
when in Debug mode with Visual Code, I receive this message:
Can anyone help me to solve this issue?
Thanx,
Fabio
  • Hello Karl,
    I finally solved it in a simpler and more reliable way, without any conversion:
        # Device Name and Dara Set
        adv_complete_local_name = 'HelloWorld!'
        adv_manuf_data  =  [0xFF, 0xFF, 0x01, 0x02, 0x03, 0x04]
        adv_data = BLEAdvData(
            complete_local_name=adv_complete_local_name,
            manufacturer_specific_data=adv_manuf_data
    which gives this result:
    I've notice only one thing: the more bytes you insert in manufacturer_specific_data, the shorter adv_complete_local_name must be;if not, (in OS Windows) something happens on the USB port, just like if the nRF52840 dongle is unlink and then link again.
    Thank you,
    Fabio
  • Hello again Fabio,
    Great, I am glad to hear that! This is exactly how the pc-ble-driver-py is intended to be used - no need to look into the C functions running behind the scenes.
    I hope my explanation of this in my last comment was helpful to you.
    Yes, the advertising packet length is indeed limited to 31 bytes ( including overheard ).
    The SoftDevice will shorten the device length if it exceeds this limit.
    How long is the packet length when you notice this behavior?
    I am not sure I understand what you mean by this part. Does the serial port close when you attempt to exceed the advertising length limit, is this what you are saying?
    I am happy to hear that you are now able to dynamically change the name as intended.
    Karl
  • Hi Karl,
    Yes, it was: Thank you!
    OK, 31 bytes is what I've noticed; making the count:
    if advertising data has 21 bytes payload (+ 2 bytes for type and length) and flags has 3 bytes(type, length and value), local name can have only 3 bytes with 2 bytes for type and length, so you can display 'Hi!';
    if you remove flags for example, you can assign more bytes to local name and display 'Hello!'
    Is there a possibility to increase the number of bytes for advertising data?
    Yes, it is! Suppose you have, as above, 21 bytes payload and assign to local name 'Hello !' (7 chars), running the script you'll hear a disconnect sound and then a riconnect sound.
    Fabio
  • Hello Fabio.
    I am happy to hear that, no problem at all!
    I do not think you should remove the flags as they are required to conform to the BLE protocol.
    You may also make use of the Scan response feature, in which you may place an additional 31 bytes.
    You can read more about the Scan response data in the Service's tutorial.
    Thank you for clarifying - I was not certain whether you were referring to BLE or USB when you said 'disconnect'.
    I suppose the disconnect and connecting USB sound in windows might play if the device is reset.
    Are you seeing any error written to your logger output when this occurs?
    Karl
  • Hi Karl,
    Ok, sounds good. I'll read it.
    Yes, from the output logger the following message:
      File "..\Python\Python37-32\lib\site-packages\pc_ble_driver_py\ble_driver.py", line 107, in wrapper
        error_code=err_code,
    pc_ble_driver_py.exceptions.NordicSemiException: Failed to ble_gap_adv_data_set. Error code: NRF_ERROR_SD_RPC_SEND
    Fabio
