trying to usenRF Connect SDK for the first time.
Could be because of recent upgrades to MacOS.
(I have used gcc with nRF SDKs before)
Paul
Paul
Thx but ...
If you look further up this post you will see that I have indeed set those correctly
Ah, sorry. I did not remember that. But now I spotted another issue, which would also give you this error. You have specified the wrong board. You ned to use nrf9160dk_nrf9160ns. It is not possible to run sample projects that use the modem in any thing other than non-secure mode (ns).
get the same error with that board. Also tried to build blinky. same error.
create_nordic_project.py failed (1).
Hm, then I am not sure... Can you show the log form SES? (you will be able to see it in the lower part of the SES window after you click OK on the error message).
ok. after a couple of tries I got the log:
Creating solution blinky.emProject
/usr/local/bin/cmake -GNinja -DBOARD=nrf9160dk_nrf9160ns -DBOARD_DIR=/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/boards/arm/nrf9160dk_nrf9160 -B/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns -S/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/Applications/ARM -DPYTHON_EXECUTABLE=/usr/local/bin/python3 -DCMAKE_MAKE_PROGRAM=/usr/local/bin/ninja -DDTC=/usr/local/bin/dtc -D WEST=/usr/local/bin/west -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/Applications/arm_segger_embedded_studio_v510d_macos_x64_nordic/html/configure_nordic_project_menuconfig.py
-- Application: /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky
-- Zephyr version: 2.4.0 (/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr)
-- Found west (found suitable version "0.7.2", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160ns
-- Cache files will be written to: /Users/paul_tanner/Library/Caches/zephyr
-- Found dtc: /usr/local/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/Applications/ARM)
-- Found BOARD.dts: /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
-- Generated zephyr.dts: /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/zephyr/include/generated/devicetree_unfixed.h
Parsing /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/Kconfig
Loaded configuration '/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/zephyr/.config'
No change to configuration in '/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/zephyr/.config'
No change to Kconfig header in '/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/zephyr/include/generated/autoconf.h'
-- Application: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/spm
-- Found BOARD.dts: /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/spm/nrf9160dk_nrf9160.overlay
-- Generated zephyr.dts: /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/spm/zephyr/include/generated/devicetree_unfixed.h
Loaded configuration '/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/spm/zephyr/.config'
No change to configuration in '/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/spm/zephyr/.config'
No change to Kconfig header in '/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/spm/zephyr/include/generated/autoconf.h'
See also "/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/spm/CMakeFiles/CMakeOutput.log".
See also "/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/CMakeFiles/CMakeOutput.log".
See also "/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160ns/CMakeFiles/CMakeError.log".
Including boilerplate (Zephyr base (cached)): /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/cmake/app/boilerplate.cmake
nrf9160dk_nrf9160ns.dts.pre.tmp:357.32-361.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property
nrf9160dk_nrf9160ns.dts.pre.tmp:56.42-68.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
nrf9160dk_nrf9160ns.dts.pre.tmp:305.19-311.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image spm - begin ===
CMake Error: CMake was unable to find a build program corresponding to "Ninja". CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error at /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/cmake/multi_image.cmake:214 (message):
CMake generation for spm failed, aborting. Command: 1
/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/cmake/multi_image.cmake:75 (add_child_image_from_source)
/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/CMakeLists.txt:22 (add_child_image)
error: cmake failed
Not sure how to fix it tho'
