Hi -
In reading through the data sheets for the Nordic chips that support the low-rate (125 kbps) BT 5 PHY, I'm seeing Rx sensitivity numbers around -103 dBm. For the 1 Mbps PHY, it's around -96 dBm. I would expect the Rx sensitivity for 125 kbps to be 12 dB lower than 1 Mbps, i.e., -96 - 12 = -108 dBm. 9 of the 12 dB comes from reducing the bit rate by 8x, the other 3 dB comes from coding gain added to the low rate S=8 PHY. Why are you guys leaving 5 dB on the table? This is a big miss, in my opinion, since 5 dB amounts to almost a 2x range increase outdoors!
Do you have any plans in the future to improve the PHY performance to make up for the 5 dB shortfall?
Gary Sugar
