zigbee mesh cli command cannot work with a device behind a router.
hi,
I have following setup test cases .
Case 1    DK2  ,  DK1   Initialized with CLI directly
         1a  DK2  ,  DK1   Directly connected to CLI    Every Thing Works
         1b  DK2-to-DK1-to-CLI                                     Reporting works if had been set during 1a ,  bind subscribe cmd cannot work for DK2
Case 2  DK1   Initialized with CLI directly  , DK2  Initialized from DK1.
         2b  DK2-to-DK1-to-CLI                                     DK2 bind subscribe cmd cannot work from CLI
         2a  DK2 ,  DK1   Directly connected to CLI      Every Thing Works
         2c  DK2-to-DK1-to-CLI                                     Dk2 bind subscribe cmd cannot work from CLI,Reporting works if had been set during 2a .
=====Device setup ==================================================================
H/W long addr        short  Remarks
Dgl f4ce3665b527c4ca 0x0000 cli_agent_router (bdb role zc)
DK1 f4ce363c8e341e82 0xB1B6 ZR+Simplesensor  (based on Light Bulb)  (Linked with external\zboss\lib\debug\gcc\libzboss.a )
DK2 f4ce36ec7343be67 0xAC93 SimpleSensor     (based on Multisensor) (Linked with external\zboss\lib\debug\gcc\libzboss.ed.a )
both end device work as expected when both are connected directly to the coordinator ED device
[idx] ext_pan_id      ext_addr         short_addr flags permit_join depth lqi
[ 0] f4ce3665b527c4ca f4ce363c8e341e82 0xB1B6     0x27  0           1     136
[ 1] f4ce3665b527c4ca f4ce36ec7343be67 0xAC93     0x16  0           1     204
all is well, binding and reporting every thing works ok.
Reporting also works during  DK2 in roaming i-e connected to DK1 instead of CLI  , commands from CLI  fails for DK2.
> zdo mgmt_lqi 0x0000
[ 0]  f4ce3665b527c4ca f4ce363c8e341e82 0xB1B6     0x27  0           1     172
ZDO request 71 complete
Done
> zdo mgmt_lqi 0xB1B6
[ 0] f4ce3665b527c4ca f4ce3665b527c4ca 0x0000     0x84  1           0     168
[ 1] f4ce3665b527c4ca f4ce36ec7343be67 0xAC93     0x16  0           2     255
ZDO request 72 complete
Done
==========Bind and subscribe ==================================================
> zdo bind on f4ce363c8e341e82 10 f4ce3665b527c4ca 64 0x000F 0xB1B6
> Done
> zcl subscribe on f4ce363c8e341e82 10 0x000F 0x0104 55 16 0 0
> Done
> zdo mgmt_bind 0xB1B6
[idx] src_address src_endp cluster_id dst_addr_mode dst_addr dst_endp
[ 0] f4ce363c8e341e82 10 0x000F 3 f4ce3665b527c4ca 64
Total entries for the binding table: 1
Done
> log enable info zigbee.report
<info> zigbee.report: Received value updates from the remote node 0xB1B6
<info> zigbee.report: Profile: 0x0104 Cluster: 0x000F Attribute: 0x0055 Type: 16 Value: True
<info> zigbee.report: Profile: 0x0104 Cluster: 0x000F Attribute: 0x0055 Type: 16 Value: False
> log disable zigbee.report
Done
> zdo bind on f4ce36ec7343be67 10 f4ce3665b527c4ca 64 0x000F 0xB1B6
> Done
> zcl subscribe on f4ce36ec7343be67 10 0x000F 0x0104 55 16 0 0
> Done
> zdo mgmt_bind 0xAC93
[ 0] f4ce36ec7343be67 10 0x000F 3 f4ce3665b527c4ca 64
Done
<info> zigbee.report: Received value updates from the remote node 0xAC93
Done
Device behind the Router
> zdo bind on f4ce36ec7343be67 10 f4ce3665b527c4ca 64 0x000F 0xAC93
Error: Bind/unbind request timed out
Error: Unable to get binding table. Status: 255
Source code of binary sensor  main.c
 * Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup zigbee_examples_simple_sensor main.c
 * @ingroup zigbee_examples
 * @brief Zigbee Pressure and Temperature sensor
#include "zboss_api.h"
#include "zb_mem_config_med.h"
#include "zb_error_handler.h"
#include "zigbee_helpers.h"
#include "app_timer.h"
#include "bsp.h"
#include "boards.h"
#include "sensorsim.h"
#include "nrf_802154.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "zb_binary_sensor.h"
#include "zboss_api_zcl.h"
#if defined (DEBUG)
  #warning ****** DEBUG Compiling!******
#define MAX_CHILDREN                       10
#define IEEE_CHANNEL_MASK                  (1l << ZIGBEE_CHANNEL)               /**< Scan only one, predefined channel to find the coordinator. */
#define ERASE_PERSISTENT_CONFIG            ZB_FALSE                             /**< Do not erase NVRAM to save the network parameters after device reboot or power-off. */
#define ZIGBEE_NETWORK_STATE_LED           BSP_BOARD_LED_2                      /**< LED indicating that light switch successfully joind Zigbee network. */
#define SLEEPY_DEVICE_BUTTON               /* _BUTTON, _ENABLE, _DISABLE */
#define SLEEPY_ON_BUTTON                   BSP_BOARD_BUTTON_3
#define SLEEPY_ON_LED                      BSP_BOARD_LED_3
// Only End Device Only, No routing support!
#if !defined ZB_ED_ROLE
  //#error Define ZB_ED_ROLE to compile End Device source code.
  #warning Compiling for End Device and Router!
#else
  #define MY_ZED_ONLY
  #warning ****** Compiling for End Device ONLY! ******
static sensor_device_ctx_t m_dev_ctx;
ZB_ZCL_DECLARE_IDENTIFY_ATTRIB_LIST(identify_attr_list, &m_dev_ctx.identify_attr.identify_time);
ZB_ZCL_DECLARE_BASIC_ATTRIB_LIST_EXT(basic_attr_list,
                                     &m_dev_ctx.basic_attr.zcl_version,
                                     &m_dev_ctx.basic_attr.app_version,
                                     &m_dev_ctx.basic_attr.stack_version,
                                     &m_dev_ctx.basic_attr.hw_version,
                                     m_dev_ctx.basic_attr.mf_name,
                                     m_dev_ctx.basic_attr.model_id,
                                     m_dev_ctx.basic_attr.date_code,
                                     &m_dev_ctx.basic_attr.power_source,
                                     m_dev_ctx.basic_attr.location_id,
                                     &m_dev_ctx.basic_attr.ph_env,
                                     m_dev_ctx.basic_attr.sw_ver);
ZB_ZCL_DECLARE_BINARY_INPUT_ATTRIB_LIST(binary_attr_list,
                                        &m_dev_ctx.binary_attr.out_of_service_value,
                                        &m_dev_ctx.binary_attr.present_value,
                                        &m_dev_ctx.binary_attr.status_flag);
ZB_DECLARE_SIMPLE_SENSOR_CLUSTER_LIST(simple_sensor_clusters,
                                     basic_attr_list,
                                     identify_attr_list,
                                     binary_attr_list );
ZB_ZCL_DECLARE_SIMPLE_SENSOR_EP(simple_sensor_ep,
                               SIMPLE_SENSOR_ENDPOINT,
                               simple_sensor_clusters);
ZBOSS_DECLARE_DEVICE_CTX_1_EP(simple_sensor_ctx, simple_sensor_ep);
APP_TIMER_DEF(zb_app_timer);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    ret_code_t err_code;
    // Initialize timer module.
    err_code = app_timer_init();
static void log_init(void)
    //ret_code_t err_code = NRF_LOG_INIT(NULL);
    ret_code_t err_code = NRF_LOG_INIT( app_timer_cnt_get );
    //ret_code_t err_code = NRF_LOG_INIT( rtc1_counter_get ); // app_timer_cnt_get
/**@brief Function for initializing all clusters attributes.
static void simple_sensor_clusters_attr_init(void)
    /* Basic cluster attributes data */
    m_dev_ctx.basic_attr.zcl_version   = ZB_ZCL_VERSION;
    m_dev_ctx.basic_attr.app_version   = SENSOR_INIT_BASIC_APP_VERSION;
    m_dev_ctx.basic_attr.stack_version = SENSOR_INIT_BASIC_STACK_VERSION;
    m_dev_ctx.basic_attr.hw_version    = SENSOR_INIT_BASIC_HW_VERSION;
    /* Use ZB_ZCL_SET_STRING_VAL to set strings, because the first byte should
     * contain string length without trailing zero.
     * For example "test" string wil be encoded as:
     *   [(0x4), 't', 'e', 's', 't']
    ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.mf_name,
                          SENSOR_INIT_BASIC_MANUF_NAME,
                          ZB_ZCL_STRING_CONST_SIZE(SENSOR_INIT_BASIC_MANUF_NAME));
    ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.model_id,
                          SENSOR_INIT_BASIC_MODEL_ID,
                          ZB_ZCL_STRING_CONST_SIZE(SENSOR_INIT_BASIC_MODEL_ID));
    ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.date_code,
                          SENSOR_INIT_BASIC_DATE_CODE,
                          ZB_ZCL_STRING_CONST_SIZE(SENSOR_INIT_BASIC_DATE_CODE));
    m_dev_ctx.basic_attr.power_source = SENSOR_INIT_BASIC_POWER_SOURCE;
    ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.location_id,
                          SENSOR_INIT_BASIC_LOCATION_DESC,
                          ZB_ZCL_STRING_CONST_SIZE(SENSOR_INIT_BASIC_LOCATION_DESC));
    m_dev_ctx.basic_attr.ph_env = SENSOR_INIT_BASIC_PH_ENV;
    /* Identify cluster attributes data */
    m_dev_ctx.identify_attr.identify_time        = ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE;
    /* Binary Input cluster atributes data */
    m_dev_ctx.binary_attr.out_of_service_value   =  0 ; // False
    m_dev_ctx.binary_attr.present_value          =  0 ; // 0
    m_dev_ctx.binary_attr.status_flag            =  ZB_ZCL_BINARY_INPUT_STATUS_FLAG_DEFAULT_VALUE ; // 0-Normal
/**@brief Function for Buttons.
void my_button_event_handler(bsp_event_t bsp_evt)
    zb_zcl_status_t zcl_status;
    uint8_t button_pressed = bsp_evt - BSP_EVENT_KEY_0;
    NRF_LOG_INFO("button %d pressed", button_pressed);
    static zb_int8_t  new_binary_value = 0;
    if      (button_pressed == 0)
    else if (button_pressed == 1)
        new_binary_value = 1;
    else if (button_pressed == 2)
        new_binary_value = 0 ;
    else if (button_pressed == 3)
        new_binary_value = 1 ;
    zcl_status = zb_zcl_set_attr_val(SIMPLE_SENSOR_ENDPOINT,
                                     ZB_ZCL_CLUSTER_ID_BINARY_INPUT,
                                     ZB_ZCL_CLUSTER_SERVER_ROLE,
                                     ZB_ZCL_ATTR_BINARY_INPUT_PRESENT_VALUE_ID,
                                     (zb_uint8_t *)&new_binary_value,
                                     ZB_FALSE);
    if(zcl_status != ZB_ZCL_STATUS_SUCCESS)
        NRF_LOG_INFO("Set binary input value fail. zcl_status: %d", zcl_status);
/**@brief Function for initializing LEDs.
static zb_void_t leds_init(void)
    ret_code_t error_code;
    /* Initialize LEDs and buttons - use BSP to control them. */
    // MBP
    //error_code = bsp_init(BSP_INIT_LEDS, NULL);
    error_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, my_button_event_handler);
    APP_ERROR_CHECK(error_code);
    bsp_board_leds_off();
/**@brief Function to set the Sleeping Mode according to the SLEEPY_ON_BUTTON state.
static zb_void_t sleepy_device_setup(void)
    zb_set_rx_on_when_idle(bsp_button_is_pressed(SLEEPY_ON_BUTTON) ? ZB_FALSE : ZB_TRUE);
#if ! defined DISABLE_POWER_CONSUMPTION_OPTIMIZATION
    /* If sleepy behaviour is enabled, power off unused RAM to save maximum energy */
    if (ZB_PIBCACHE_RX_ON_WHEN_IDLE() == ZB_FALSE)
        zigbee_power_down_unused_ram();
#endif /* ! defined DISABLE_POWER_CONSUMPTION_OPTIMIZATION */
/**@brief Function for handling nrf app timer.
 * @param[IN]   context   Void pointer to context function is called with.
 * @details Function is called with pointer to sensor_device_ep_ctx_t as argument.
static void zb_app_timer_handler(void * context)
/**@brief Zigbee stack event handler.
 * @param[in]   bufid   Reference to the Zigbee stack buffer used to pass signal.
void zboss_signal_handler(zb_bufid_t bufid)
    zb_zdo_app_signal_hdr_t  * p_sg_p      = NULL;
    zb_zdo_app_signal_type_t   sig         = zb_get_app_signal(bufid, &p_sg_p);
    zb_ret_t                   status      = ZB_GET_APP_SIGNAL_STATUS(bufid);
    /* Update network status LED */
    zigbee_led_status_update(bufid, ZIGBEE_NETWORK_STATE_LED);
    switch (sig)
        case ZB_BDB_SIGNAL_DEVICE_REBOOT:
            /* fall-through */
        case ZB_BDB_SIGNAL_STEERING:
            /* Call default signal handler. */
            ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
            if (status == RET_OK)
                ret_code_t err_code = app_timer_start(zb_app_timer, APP_TIMER_TICKS(1000), NULL);
    if (bufid)
        zb_buf_free(bufid);
#if !(defined ZB_ZCL_DISABLE_REPORTING)
void configure_reporting_locally(void)
  zb_zcl_reporting_info_t rep_info;
  memset(&rep_info, 0, sizeof(rep_info));
  rep_info.direction      = ZB_ZCL_CONFIGURE_REPORTING_SEND_REPORT;
  rep_info.ep             = SIMPLE_SENSOR_ENDPOINT;
  rep_info.cluster_id     = ZB_ZCL_CLUSTER_ID_BINARY_INPUT;
  rep_info.cluster_role   = ZB_ZCL_CLUSTER_SERVER_ROLE;
  rep_info.attr_id        = ZB_ZCL_ATTR_BINARY_INPUT_PRESENT_VALUE_ID;
  rep_info.dst.profile_id = ZB_AF_HA_PROFILE_ID;
  rep_info.u.send_info.min_interval = 0;   //
  rep_info.u.send_info.max_interval = 0;   //
  rep_info.u.send_info.delta.u8     = 1;   //
  /* Cordinators discription
     src_addr=0x0000 ep=64 profile_id=0x0104
     app_dev_id=0x5 app_dev_ver=0x0
     in_clusters=0x0000, 0x0003 out_clusters=0x0000, 0x0003, 0x0004 .
  rep_info.dst.short_addr = 0x0000 ;
  rep_info.dst.endpoint   = 64 ;
  rep_info.dst.profile_id = ZB_AF_HA_PROFILE_ID ;
  // ******linker error*******
  //zb_zcl_put_default_reporting_info(&rep_info);
  zb_zcl_put_reporting_info(&rep_info,ZB_TRUE);
// CLI:
/**@brief Function for application main entry.
    zb_ret_t       zb_err_code;
    zb_ieee_addr_t ieee_addr;
    /* Initialize loging system and GPIOs. */
    timers_init();
    log_init();
    leds_init();
    /* Create Timer for reporting attribute */
    err_code = app_timer_create(&zb_app_timer, APP_TIMER_MODE_REPEATED, zb_app_timer_handler);
    /* Set Zigbee stack logging level and traffic dump subsystem. */
    ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
    ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
    ZB_SET_TRAF_DUMP_OFF();
    /* Initialize Zigbee stack. */
    ZB_INIT("simple_binary_sensor");
    /* Set device address to the value read from FICR registers. */
    zb_osif_get_ieee_eui64(ieee_addr);
    zb_set_long_address(ieee_addr);
    /* Set static long IEEE address. */
#ifdef MY_ZED_ONLY
    zb_set_network_ed_role(IEEE_CHANNEL_MASK);
    zb_set_ed_timeout(ED_AGING_TIMEOUT_64MIN);
    zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
#ifdef SLEEPY_DEVICE_BUTTON
    sleepy_device_setup();
    #warning ****** Configured for SLEEPY_DEVICE_BUTTON ! ******
#else
    #ifdef SLEEPY_DEVICE_ENABLE
      zb_set_rx_on_when_idle(ZB_FALSE);  // sleppy enabled
      NRF_LOG_INFO("Zigbee Sleepy Device !");
    #else
      zb_set_rx_on_when_idle(ZB_TRUE);  // sleepy disabled (default)
      NRF_LOG_INFO("Zigbee NonSleepy Device !");
#else //MY_ZED_ROUTER
    zb_set_network_router_role(IEEE_CHANNEL_MASK);//MBP
    zb_set_max_children(MAX_CHILDREN);            //MBP
    zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
     /* Bind to cordinator for reporting */
    configure_reporting_locally();
    zb_int8_t mypower = 0 ;
    zb_bool_t mysleepy = false;
     if(zb_get_rx_on_when_idle() == ZB_FALSE ) //return ZB_TRUE if ZED is not sleepy ZED, ZB_FALSE if ZED is a sleepy ZED
      bsp_board_led_on(SLEEPY_ON_LED); // ZB_FALSE if ZED is a sleepy ZED
      mysleepy = ZB_TRUE ;
      bsp_board_led_off(SLEEPY_ON_LED); //  ZB_TRUE if ZED is not sleepy ZED
      mysleepy = ZB_FALSE ;
    /* Initialize application context structure. */
    UNUSED_RETURN_VALUE(ZB_MEMSET(&m_dev_ctx, 0, sizeof(m_dev_ctx)));
    /* Register callback for handling ZCL commands. */
    //MBP: TODO ZB_ZCL_REGISTER_DEVICE_CB(zcl_device_cb);
    /* Register temperature sensor device context (endpoints). */
    ZB_AF_REGISTER_DEVICE_CTX(&simple_sensor_ctx);
    /* Initialize sensor device attibutes */
    simple_sensor_clusters_attr_init();
    /** Start Zigbee Stack. */
    zb_err_code = zboss_start_no_autostart();
    ZB_ERROR_CHECK(zb_err_code);
    zb_int32_t i =0;
    zb_nwk_device_type_t role = zb_get_network_role();
    NRF_LOG_INFO("Zigbee role = %d ", role);
    while(1)
        zboss_main_loop_iteration();
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        i--;
        if(i<=0)
          mypower=nrf_802154_tx_power_get();
          NRF_LOG_INFO("Zigbee Txpower %d !", mypower);
          i=10000*4;
          if(mypower >0 ) // suppose 8
            mypower = 4;
            nrf_802154_tx_power_set(mypower);
Thanks and regards
    I am sorry for the late reply.
     I am not sure I have understood your setup. Please correct me if I am wrong, you have 3 DKs in total:
    DK-a: router, based on light bulb example.
    DK-b: router, based on multisensor example.
    DK-c: runs CLI example as coordinator (bdb role zc).
    Case 1:
    What do you mean with DK-a, DK-b "directly connected to CLI"? Do you mean both DK-a and DK-b join the network?
    What do you mean by "reporting works if had been set during 1a"? How do you set bind and subscribe in this step?
    Do you have sniffer traces showing how DK-a and DK-b join the network and how you set bind and subscribe for both?
    Case 2:
    What do you mean with "DK2 initialized from DK1"?
    I need more information and to make sure I understand both your setup and your problem before I can help further.
    Marjeris
  • hi ,
    Placement
    Case 1 :  CLI-----8 meters----DK1----8 meters----DK2 (16 meters to CLI).  in single direction
    Case 2:   DK2------ 5 meters ---- CLI ----- 8 meters----DK1   ( CLI in center position)
    1a  DK2  ,  DK1   Directly connected to CLI , Means both the device are near to the coordinator(CLI).
    as the cli bind and subscribe was failing when it was in position as case 1,
    I moved DK2 to position case 2, and issued bind and subscribe commands, then moved them back to position case 1 .
    Sorry I don't have an extra DK or dongle for sniffer log during this episode , I have ordered one dongle to use as sniffer.
    will retest again with sniffer logging,
    Also I read the communicating with ZED sleepy device will be very tricky !.
    I dont see any examples of configuring and using sleepy devices in the SDK.
    Do have any guides, best practices or  helpful hints and tricks to design and setup ZED-sleepy devices.
    Thanks and  regards
    Are you still struggling with this issue?
     The Light switch example inside the Zigbee light control example demonstrates the Zigbee End Device role and can be configured as a sleepy end device: https://infocenter.nordicsemi.com/topic/sdk_tz_v4.1.0/zigbee_example_light_control.html
    Have you recieve the dongle and are you now able to provide a sniffer trace?
    BR,
    Marjeris
