Error in building project using segger for nrf9160
HI
I had setup the toolchain as described but on building the blinky project and other projects i got the following error.
Creating solution blinky.emProject
cmake -GNinja -DBOARD=nrf9160dk_nrf9160 -DBOARD_DIR=C:\nordic_semi\ncs\zephyr\boards\arm\nrf9160dk_nrf9160 -BC:\nordic_semi\ncs\zephyr\samples\basic\blinky\build_nrf9160dk_nrf9160 -SC:\nordic_semi\ncs\zephyr\samples\basic\blinky -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:\nordic_semi\v1.4.0\toolchain\opt -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\nordic_semi\arm_segger_embedded_studio_v520b_win_x64_nordic/html/configure_nordic_project_menuconfig.py
-- Application: C:/nordic_semi/ncs/zephyr/samples/basic/blinky
-- Zephyr version: 2.4.0 (C:/nordic_semi/ncs/zephyr)
-- Found Python3: C:/Python39/python.exe (found suitable exact version "3.9.0") found components: Interpreter
-- Found west (found suitable version "0.8.0", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160
-- Cache files will be written to: C:/nordic_semi/ncs/zephyr/.cache
-- Found dtc: C:/ProgramData/chocolatey/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/nordic_semi/v1.4.0/toolchain/opt)
-- Found BOARD.dts: C:/nordic_semi/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Generated zephyr.dts: C:/nordic_semi/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/nordic_semi/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160/zephyr/include/generated/devicetree_unfixed.h
Parsing C:/nordic_semi/ncs/zephyr/Kconfig
Loaded configuration 'C:/nordic_semi/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'C:/nordic_semi/ncs/zephyr/samples/basic/blinky/prj.conf'
Configuration saved to 'C:/nordic_semi/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160/zephyr/.config'
Kconfig header saved to 'C:/nordic_semi/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/nordic_semi/v1.4.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
See also "C:/nordic_semi/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160/CMakeFiles/CMakeOutput.log".
See also "C:/nordic_semi/ncs/zephyr/samples/basic/blinky/build_nrf9160dk_nrf9160/CMakeFiles/CMakeError.log".
Including boilerplate (Zephyr base): C:/nordic_semi/ncs/zephyr/cmake/app/boilerplate.cmake
CMake Error at ../../../cmake/extensions.cmake:1557 (message):
Assertion failed: The toolchain is unable to build a dummy C file. See
CMakeError.log.
../../../CMakeLists.txt:42 (assert)
error: cmake failed
create_nordic_project.py failed (1)
Kindly help me out to solve the issue as soon as possible.
