building at_client for nb-iot on nrf9160-dk
select at_client folder
west build -b nrf9160dk_nrf9160ns -p
shows this warning
warning: The choice symbol LTE_NETWORK_MODE_NBIOT (defined at
/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/lib/lte_link_control/Kconfig:152) was selected (set =y),
but no symbol ended up as the choice selection. See
docs.zephyrproject.org/.../CONFIG_LTE_NETWORK_MODE_NBIOT.html and/or
look up LTE_NETWORK_MODE_NBIOT in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.```
paul_tanner@iMac at_client % ls
CMakeLists.txt build_nrf9160dk_nrf9160
README.rst build_nrf9160dk_nrf9160ns
at_client.hex prj.conf
at_client_nbiot.hex sample.yaml
build src
note there is no Kconfig file here
when running the resulting binary
AT%XSYSTEMMODE?
%XSYSTEMMODE: 1,0,1,0
Not surprisingly it does not connect to any NB-IOT access point.
My questions are:
1. do I need a Kconfig for NB-IOT?
2. can I use the same firmware versions for this and LTE/M?
Thx.
  • Sorry, forgot to say that LTE_NETWORK_MODE_NBIOT=y is set in prj.conf
    The CONFIG_LTE_NETWORK_MODE_* Kconfig symbols are for the lte_link_control library.
    As the lte_link_control library is used for configuring the modem (specifically the LTE link) from an application running on the application core, and the purpose of the at_client is that you can configure the modem manually, the at_client does not use the lte_link_control library.
    As the lte_link_control library is not enabled, the Kconfig symbols it uses will not be defined. That is the reason for the build warning (in general, I recommend that you treat Kconfig warnings as errors).
    Instead, when you use the at_client sample, you must configure the modem manually. To set the system mode to NB-IoT, you can use AT%XSYSTEMMODE=0,1,x,0, where x is 1 if you also want GPS, 0 otherwise. Note that the modem must be offline (CFUN=4 or 0) when you set the system mode.
    You can then use AT+CFUN=0 to store the configuration in permanent memory.
     Only when using the lte_link_control library.
     You can use the same modem firmware for both modes. If you do not set the mode, LTE-M is the default.
    If you are using the lte_link_control library, the default is controlled by the Kconfig options. But, the system mode can also be changed at run-time by the application.
    And, again, to be clear: The at_client sample does not use the lte_link_control library, and requires you to configure the modem manually.
    Didrik
  • OK.  I think the problem was that we were out of range.
    The next test was from somewhere nearer to a mast.
    Now we get:
    +CEREG: 5,"1BE8","0029FF0B",9,,,"11100000","00101000"
    [00:02:01.235,626] [0m<inf> asset_tracker: Connected to LTE network.[0m
    [00:02:01.242,523] [0m<inf> asset_tracker: Network registration status: Connected - roaming[0m
    [00:02:01.251,220] [0m<inf> asset_tracker: PSM parameter update: TAU: 28800, Active time: -1[0m
    [00:02:01.479,919] [1;33m<wrn> [0m
    [00:02:01.719,909] [1;33m<wrn> date_time: getaddrinfo, error: -11[0m
    [00:02:01.928,924] [1;33m<wrn> date_time: getaddrinfo, error: -11[0m
    [00:02:02.151,916] [1;33m<wrn> date_time: getaddrinfo, error: -11[0m
    [00:02:02.408,935] [1;33m<wrn> date_time: getaddrinfo, error: -11[0m
    [00:02:02.415,344] [1;33m<wrn> date_time: Not getting time from any NTP server[0m
    [00:02:02.422,851] [0m<inf> asset_tracker: DATE_TIME_NOT_OBTAINED[0m
    [00:02:02.429,290] [0m<inf> asset_tracker: Connecting to cloud, attempt 1 of 8[0m
    [00:02:02.436,859] [0m<inf> asset_tracker: Cloud connection request sent.[0m
    [00:02:02.443,939] [0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.[0m
    [00:02:02.452,789] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
    [00:02:03.655,975] [0m<dbg> nrf_cloud_transport.nct_connect: getaddrinfo failed -11[0m
    [00:02:03.663,970] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
    [00:02:03.670,166] [1;31m<err> asset_tracker: Failed to connect to cloud, error -3[0m
    [00:02:03.678,070] [1;31m<err> asset_tracker: Network error, check cloud configuration[0m
    [00:02:03.686,279] [1;31m<err> asset_tracker: Device will reboot in 300 seconds[0m
    I think we got a connection but there was another config issue.
    could it be that setting the APN
    CONFIG_LTE_PDP_CONTEXT="0,\"IP\",\"lpwa.vodafone.iot\""
    Did not work.
    I tried
    AT+CGDCONT?
    OK
    This suggests that it is not set.  In that case any call requiring a connection would likely fail.
  • I have not tried to set the APN manually lately, the modem usually figures that out automatically based on the network, so my memory there is a bit rusty. I will run some tests tomorrow and come back to you then.
    But, it could also be that the network does not support ePCO.
    Could you try to add CONFIG_LTE_LEGACY_PCO_MODE=y to the prj.conf?
    And are you building with SES? If so, you must re-open the project, or use 'Project -> Run CMake...' for changes to prj.conf (or other configuration files) to take effect.
  • Looks like there is a dependency where you need
    CONFIG_LTE_PDP_CMD=y
    for
    CONFIG_LTE_PDP_CONTEXT=...
    to be allowed.
    It's still not working but at lease now AT+CGDCONT? produces the right result.
    Some other issue is causing it to give up after only one connection attempt.
  • From your last log, it looks like you are able to connect:
    Although the DNS lookup failes:
    It might be that the network does not support ePCO. At least, that has been the case in other NB-IoT networks with DNS problems.
    You can use "legacy" PCO instead by setting CONFIG_LTE_LEGACY_PCO_MODE=y
  • Thanks. That certainly moved things forward.  So now it does get data/ time.
    We then found a whole lot of other issues which I have posted separately.
    devzone.nordicsemi.com/.../initiation-problem-on-vodafone-with-nb-iot-from-nrf9160-dk
