Zephyr BLE static passkey between central and peripheral on two nrf52840s
Hi!
I am trying to develop a way for a Bluetooth Central and Bluetooth Peripheral using Secure Connections (security mode 1 level 2 if I'm not mistaken) using a static passkey. Both the Central and the Peripheral are nrf52840s, using the Connect SDK/Zephyr on both.
I have managed to get the Zephyr Heart Rate samples running on both devices (central_hr and peripheral_hr), however I am somewhat at a loss of how to change the code to enable static passkeys. Both devices will operate without any IO capability, such that the wanted feature is for the central and peripheral to pair only if they share the same (permanently stored) static passkey.
My understanding is that in order to achieve this, both devices has to communicate their IO capabilities are NoInputNoOutput with the MITM flag set high and CONFIG_BT_FIXED_PASSKEY to be enabled. I would like to build upon the Heart Rate example to test this features success. My questions are:
1) Where in the code should bt_passkey_set(unsigned in passkey) be placed, both for central and peripheral example?
2) How/where do I communicate the Centrals IO capabilities? I've found explanations with regards to the Peripheral, but haven't found this for the Central and don't quite get it from the example code.
3) Is there a possibility to be guided with instructions in order to move from the central_hr + peripheral_hr example to a working "central_hr_static_passkey" + "peripheral_hr_static_passkey"-example?
Code for the central_hr: https://github.com/zephyrproject-rtos/zephyr/blob/master/samples/bluetooth/central_hr/src/main.c
Code fir the peripheral_hr: https://github.com/zephyrproject-rtos/zephyr/blob/master/samples/bluetooth/peripheral_hr/src/main.c
Please do tell if more information is needed or if I in any way can aid in this inquery.
Thanks a lot in advance,
Jonas
