Unsupported device. The detected device could not be recognized as neither JLink device nor Nordic USB device
My PC is Windows 7 64-bit and my tool is J-Link V9. The CPU at my target board is nrf52840. I use nRF connect desktop version 3.60 and it works fine.
I got the upgrade information today and upgraded it to nRF connect desktop version 3.61. It caused an error message "Unsupported device. The detected device could not be recognized as neither JLink device nor Nordic USB device"
My nRF connect desktop cannot connect with my target through J-Link V9. The log file is 2020-12-10T08_50_27.009Z-log.txt.
I try to downgrade Segger J-Link driver V6.54c or V6.84c or V6.80a and nRF connect desktop version 3.60. It caused an error message "ERROR Error while getting readback protection".
The log file is 2020-12-10T09_18_05.227Z-log.txt.
I run the Dos command "nrfjprog --family NRF52 --recover".
and I got the message as follows.
Recovering device. This operation might take 30s.
Erasing user code and UICR flash areas.
But the problem still exists. How to fix it? Could anyone help me?
    My Windows 7 PC work fine on nRF connect desktop version 3.60. It causes the issue on upgrading to nRF connect desktop version 3.61. I just want to know how to solve the problem. How to make my PC work fine? It makes mine can not work. Please help me how to fix it.
    2020-12-10T09:18:05.806Z INFO Application data folder: D:\Users\tedwu\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
    2020-12-10T09:18:05.889Z DEBUG App pc-nrfconnect-programmer v1.4.8 official
    2020-12-10T09:18:05.889Z DEBUG App path: D:\Users\tedwu\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
    2020-12-10T09:18:05.890Z DEBUG nRFConnect 3.6.0 is supported by the app (^3.6.0)
    2020-12-10T09:18:05.890Z DEBUG nRFConnect path: D:\Users\tedwu\AppData\Local\Programs\nrfconnect\resources\app.asar
    2020-12-10T09:18:05.890Z DEBUG HomeDir: D:\Users\tedwu
    2020-12-10T09:18:05.891Z DEBUG TmpDir: D:\Users\tedwu\AppData\Local\Temp
    2020-12-10T09:18:05.961Z INFO Using nrfjprog library 10.9.0, pc-nrfjprog-js 1.7.3
    2020-12-10T09:18:09.954Z INFO Using nrfjprog to communicate with target
    2020-12-10T09:18:11.160Z INFO Using J-Link Software version 6.80
    2020-12-10T09:18:13.209Z INFO Segger serial:  59404841
    2020-12-10T09:18:13.209Z INFO Segger speed:  2000  kHz
    2020-12-10T09:18:13.209Z INFO Segger version:  J-Link V9 compiled Dec 13 2019 11:14:50
    2020-12-10T09:18:13.227Z INFO Core probed: 59404841
    2020-12-10T09:18:13.228Z INFO Core RAM: 256KiB
    2020-12-10T09:18:13.228Z INFO Core ROM: 1024KiB in pages of 4KiB
    2020-12-10T09:18:13.410Z INFO Model: NRF52840_xxAA_REV2.
    2020-12-10T09:18:13.412Z ERROR Error while getting readback protection
    2020-12-10T08:50:27.507Z INFO Application data folder: D:\Users\tedwu\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
    2020-12-10T08:50:27.583Z DEBUG App pc-nrfconnect-programmer v1.4.8 official
    2020-12-10T08:50:27.583Z DEBUG App path: D:\Users\tedwu\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
    2020-12-10T08:50:27.583Z DEBUG nRFConnect 3.6.1 is supported by the app (^3.6.0)
    2020-12-10T08:50:27.583Z DEBUG nRFConnect path: D:\Users\tedwu\AppData\Local\Programs\nrfconnect\resources\app.asar
    2020-12-10T08:50:27.583Z DEBUG HomeDir: D:\Users\tedwu
    2020-12-10T08:50:27.584Z DEBUG TmpDir: D:\Users\tedwu\AppData\Local\Temp
    2020-12-10T08:50:27.604Z INFO Using nrfjprog library 10.12.1, pc-nrfjprog-js 1.7.6
    2020-12-10T08:50:34.468Z ERROR Unsupported device. The detected device could not be recognized as neither JLink device nor Nordic USB device.
  • You may choose to install nRF Connect v3.6.0 (instead of v3.6.1):
    https://www.nordicsemi.com/Software-and-tools/Development-Tools/nRF-Connect-for-desktop/Download#infotabs
    Then after installing v3.6.0 you may choose to install the Programmer app manually by following this description:
    https://nordicsemiconductor.github.io/pc-nrfconnect-docs/local_app_installation
    Direct download to v1.4.7 of the Programmer app that you can download to your computer:
    https://developer.nordicsemi.com/.pc-tools/nrfconnect-apps/pc-nrfconnect-programmer-1.4.7.tgz
  • Hi Kenneth,
    I downloaded pc-nrfconnect-programmer-1.4.7.tgz and replaced 1.4.8 and it worked fine. Thank you very much.
