ble_app_uart not showing characteristics
I have seen other post on this issue but they are not helping.   I am using the bmd 330 to run ble_app_uart.   It compiles and advertises correctly but does not send the tx and rx characteristics to nRF connect.   I am using SDK 17.0.2.  When I use nRF toolkit on the uart app it tells me that the service is not supported.
  • Hi
    I see that you're using a module that doesn't have an external 32.768 kHz crystal, which our SDK examples are configured to use. This is a very common issue when using third party modules and our BLE example projects, so please make sure that you've configured your application to use the internal LFRC oscillator instead. You can do so by setting the following defines to these values in your sdk_config.h header file.
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    Simon
    PS: The Holiday season is upon us, which will leave the Nordic support team understaffed until January 4th, 2021. This means that delayed replies will occur during this time. Sorry about the inconvenience and happy Holidays!
  • I completed those with no change and happy holidays back at yah.
  • Hi
    Which ble_app_uart example are you using? The BMD 330includes the nRF52810, which does not have a project for the nRF52810 hardware by default. I assume you're using the pca10040e (emulated nRF52832DK as nRF52810) project. To transfer this emulated project to work on nRF52810 HW you need to remove the DEVELOP_IN_NRF52832 and NRF_COREDEP_DELAY_US_LOOP_CYCLES defines from compile flags. You can see more on Developing for the nRF52810 on our Infocenter page.
    Simon
  • I did do that but the NUS services don't appear.   They do appear on the BMD 300.   Is it possible to get the NUS services to work on the BMD 330, I need to do that.   Otherwise moving to the BMD 300 is an option.
    Regards
  • Yes, using the Nordic UART Service should be compatible for the nRF52810 as well. You use the BMD 330 as a peripheral device I assume (the nRF52810 does not support acting as a central)? Also, please make sure you use the S112 SoftDevice which is the one we recommend alongside the nRF52810.
    Simon
