DFU thread Server nrfutil ncp connectivity issue
I've been trying any way I can think of to work around an issue "51" returned by nrfjprog executed from nrfutil when trying to run serwer from the steps in tutorial:
https://devzone.nordicsemi.com/nordic/short-range-guides/b/mesh-networks/posts/thread-tutorial-practical-guide-for-device-upgrade-ota
It ends up with:
File "subprocess.py", line 512, in run
subprocess.CalledProcessError: Command '['nrfjprog', '--snr', '683191406', '--verify', '/tmp/_MEI0grNYG/nordicsemi/thread/hex/ncp.hex', '--family', 'NRF52']' returned non-zero exit status 51.
I had tried to program ncp.hex from source package of the same nrfutil version and next I tried to use nrfutil without '--flash_connectivity' but then I get:
2020-12-17 09:48:42,784 Failed to reset NCP. Please flash connectivity firmware.
I tried doing it on Linux and Windows machine. I tried different relese( v5.2.0 ). All gives nothing but errors.
  • I got some progress: second try using manually programmeg ncp succeeded. I lost a lot of my time because I didn't try twice I tried different methods instead.
    pawp@DESKTOP031 MINGW32 ~/Downloads
    $ ./nrfutil_v5_2.exe --verbose dfu thread -snr 683741244 --panid 1234 --masterkey [my key] -pkg update_candidates/app_dfu_package.zip
    Address not specified. Using ff03::1 (all Thread nodes)
    Using connectivity board at serial port: COM6
    2020-12-17 11:10:50,441 Failed to reset NCP. Please flash connectivity firmware.
      File "nordicsemi\__main__.py", line 1382, in thread
      File "nordicsemi\thread\tncp.py", line 224, in open
    Exception: Failed to reset NCP. Please flash connectivity firmware.
    Waiting for NCP to promote to a router...
    Thread DFU server is running... Press <Ctrl + D> to stop.
    Can someone confirm/explain this bug?
    Have you verified that the file (ncp.hex) is present in the path?
    Did you download one of the prebuilt releases? I have only tested with nrfutil installed through pip, and I'm not able to reproduce this issue. I do however see a similar error when the chip is erased (verify failed with exit status 55). If I manually flash the ncp.hex file first, the nrfutil command works as expected, even with --flash_connectivity argument set.
    Jørgen
    thank you for your reply.
    Yes, I did all operation with prebuild ncp.hex. I didn't build anything else other than dfu app.
    Can you help me to find error codes for nrfjprog? Finding meaning of '51' error code could help in this case.
    I checked multiple runs on newer 6.1.0 version windows/linux but it didn't work.
    Only working solution is still v5.2.0 on Windows and it is no ideal either: I have to run it twice and when I want to close it, it usually crashes my cmd.exe window.
    Error 51 means that the file was not found:
    $ nrfjprog --program code.hex
    Parsing image file.
    ERROR: The file specified could not be found.
    51: command not found
    Could you try to install nrfutil through pip?
    Jørgen
  • Hi, it installing it through pip does help though it would be good to take care of issue with native linux/windows version of nrfutil so people could avoid wasting a lot of time like I just did. Thank you for your help
