Serial rx interrupt problem
I am trying to use nrf_serial with IRQ. Tx operations just fine but, i can not get any interrupt when a data comes from uart. I am  using sdk 14.2 and not using ble.
static void sleep_handler(void);
static void serial_event_handler(struct nrf_serial_s const *p_serial, nrf_serial_event_t event);
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config,
                      8, 15,
                      RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                      NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                      NRF_UART_BAUDRATE_115200,
                      UART_DEFAULT_CONFIG_IRQ_PRIORITY);
#define SERIAL_FIFO_TX_SIZE 32
#define SERIAL_FIFO_RX_SIZE 32
NRF_SERIAL_QUEUES_DEF(serial_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 1
#define MAX_RX_BUFFER_SIZE  100
NRF_SERIAL_BUFFERS_DEF(serial_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_CONFIG_DEF(serial_config, NRF_SERIAL_MODE_IRQ, &serial_queues, &serial_buffs, serial_event_handler, sleep_handler);
NRF_SERIAL_UART_DEF(serial_uart, 0);
uint32_t uart_init(void)
  return nrf_serial_init(&serial_uart, &m_uart0_drv_config, &serial_config);
uint32_t send_uart(uint8_t *tx_message)
  uint32_t error_code;
  error_code = nrf_serial_write(&serial_uart, tx_message, strlen(tx_message), NULL, 0);
  nrf_serial_flush(&serial_uart, 0);
  return error_code;
  static uint8_t buffer[MAX_RX_BUFFER_SIZE] = {0};
  static uint8_t length = 0;
  switch (event)
    case NRF_SERIAL_EVENT_TX_DONE:
    case NRF_SERIAL_EVENT_RX_DATA:
        nrf_queue_read(p_serial->p_ctx->p_config->p_queues->p_rxq, &buffer[length], 1);
        if (buffer[length] == '\n')
          uart_callback(buffer, length);
          memset(buffer, 0, MAX_RX_BUFFER_SIZE);
          length = 0;
          length++;
    case NRF_SERIAL_EVENT_DRV_ERR:
    case NRF_SERIAL_EVENT_FIFO_ERR:
