nRF52840 Internal temperature sensor accuracy
As per nRF52840 datasheet, the accuracy of internal temperature sensor is ±5°C. We want our device to be operational between 5°C to 40°C.
When we tested this extreme temperature range(1°C to 45°C), we found that the Internal temperature sensor were accurate. Hence we assume that this ±5°C accuracy applies to extreme temperatures mentioned in the micro datasheet(40 and +85).
Can you please confirm the same? Or can you let us know what would be the accuracy of the internal temperature sensor with different ambient temperature range?
Please note that we are not running any high throughput code/commands, hence we believe that the internal temperature sensor is not effected by the heat generated by the micro controller.
GT
