Firmware Update over UART Interface
Background: I have a custom board that contains nRF52832 module and exposes UART pins (RX, TX, RTS, CTS). I have developed an application using nRF5 SDK v17.0.2. The application does not use any so -called SoftDevice.
Objective: I want to develop a mechanism to update the application firmware of on the nRF52832 module over the UART interface from another micro-controller.
Seeking Help: After searching through the SDK and the forum, it looks like I have to use libraries under Bootloader and DFU modules But I am still confused which components to use and in what order. On the nRF52832 module, do I need to program, as part of my application, routines to receive and process DFU commands/data packets. I am also using the same UART port to exchange application data (from sensors attached sensors )  with the other micro-controller.
I would appreciate any help that can get me started on the right path to achieve the objective.
  • Thanks for the correction. I am wondering why with the Rx pin, such an error is thrown.
  • You need to test with a simple UART example, to check if you can communicate normally with the external MCU via the TX and RX pin you defined.
    Having a floating RX pin will cause such error.
  • Hi Hung,
    After quite a bit of struggle I found a way out of the UART problem. I am able to run the same code (with UART RX Pin 11) on another sample of the same board. So somehow pin 11 on the previous samples was malfunctioning.   The bootloader works fine, enabling the uart transport layer, and enters 'loop_forever' function waiting for the DFU trigger event.
    Now in the next step I attempted following tasks:
    - While following your tutorial, I was trying to .zip file from my app.hex. With the command  'nrfutil pkg generate'  argument  '--sd-req' is required. However I am not using any softdvice in my application. But looks like I have to provide some value to this argument but which one?
    - I generated bootloader setting hex file
    nrfutil settings generate --family NRF52 --application app.hex --application-version 0 --bootloader-version 0 --bl-settings-version 2 bld_setting.hex
    Then with 'mergehex --merge' command merged the setting hex file with bootloader and app hex files. But when I tried to program the resulting merged file (using Programmer tool in nRF Connect app) I get error "Overlapping data around address 0x7d12c". Any way out?
    - Using command 'nrfjprog --reset --program mergd.hex --family NRF52 --sectoranduicrerase',   the programming of the merged hex file is successful. Howerever, he bootloader does not entered when the application program sets NRF_POWER->GPREGRET and does softreset of the device.
  • Hi Jalata,
    I would suggest to try testing with BLE DFU as well just to get familiar with the process.
    If you have a look at the documentation of the nrfutil here you can find that if you don't use softdevice you can use any --sd-req value, it will be ignored when doing DFU. ( I suggest to use  0xFF)
    Please send the full log when you do mergehex, as well as the bootloader, application, and bootloader setting. Please try testing with one of our application example before testing with your own example.
  • Hi Hung,
    See files (bootloader, bootloader setting, application, and merged) in attachment 7384.bootloader.hex. , 5241.bootloader_setting.hex, 4645.app.hex, allmerged.hex
    Here is output log from relevant commands :
    >  nrfutil settings generate --family NRF52 --application app.hex --application-version 0 --bootloader-version 0 --bl-settings-version 2 bootloader_setting.hex
    Note: Generating a DFU settings page with backup page included.
    This is only required for bootloaders from nRF5 SDK 15.1 and newer.
    If you want to skip backup page generation, use --no-backup option.
    Generated Bootloader DFU settings .hex file and stored it in: bootloader_setting.hex
    Bootloader DFU Settings:
    * File:                     bootloader_setting.hex
    * Family:                   nRF52
    * Start Address:            0x0007F000
    * CRC:                      0x00197635
    * Settings Version:         0x00000002 (2)
    * App Version:              0x00000000 (0)
    * Bootloader Version:       0x00000000 (0)
    * Bank Layout:              0x00000000
    * Current Bank:             0x00000000
    * Application Size:         0x000045EC (17900 bytes)
    * Application CRC:          0x3ACE56BA
    * Bank0 Bank Code:          0x00000001
    * Softdevice Size:          0x00000000 (0 bytes)
    * Boot Validation CRC:      0xE04E9893
    * SD Boot Validation Type:  0x00000000 (0)
    * App Boot Validation Type: 0x00000001 (1)
    > mergehex --merge bootloader_setting.hex bootloader.hex app.hex --output allmerged.hex
    Parsing input files.
    Merging file "bootloader_setting.hex" into output.
    Merging file "bootloader.hex" into output.
    Merging file "app.hex" into output.
    Storing merged file.
    > nrfjprog --reset --program allmerged.hex --family NRF52 --sectoranduicrerase
    Parsing image file.
    Erasing page at address 0x0.
    Erasing page at address 0x1000.
    Erasing page at address 0x2000.
    Erasing page at address 0x3000.
    Erasing page at address 0x4000.
    Erasing page at address 0x5000.
    Erasing page at address 0x78000.
    Erasing page at address 0x79000.
    Erasing page at address 0x7A000.
    Erasing page at address 0x7B000.
    Erasing page at address 0x7C000.
    Erasing page at address 0x7D000.
    Erasing page at address 0x7E000.
    Erasing page at address 0x7F000.
    Erasing UICR flash area.
    Applying system reset.
    Checking that the area to write is not protected.
    Programming device.
    Run.
    > nRF52832 device memory map after flashing the allmerged.hex file
    > When tried to open allmerged.hex file with Programmer tool in nRF Connect app, got error message "Overlapping data around address ....".
