touch screen and media button can not work at same time?
add touchscreen hid can worked  use hids, media button (consumer) can worked, but it can not work at same time, some one help me !!!
            // Report ID 1: digitizer touch
            0x05, 0x0D,                    // USAGE_PAGE(Digitizers)
            0x09, 0x04,                    // USAGE     (Touch Screen)
            0xA1, 0x01,                    // COLLECTION(Application)
            0x85, 0x01,                             //   REPORT_ID
            /* Touch one */
            0x09, 0x22,                    //   USAGE (Finger)
            0xA1, 0x02,                    //   COLLECTION (Logical)
            0x09, 0x42,                    //     USAGE (Tip Switch)
            0x15, 0x00,                    //     LOGICAL_MINIMUM (0)
            0x25, 0x01,                    //     LOGICAL_MAXIMUM (1)
            0x75, 0x01,                    //     REPORT_SIZE (1)
            0x95, 0x01,                    //     REPORT_COUNT(1)
            0x81, 0x02,                    //     INPUT (Data,Var,Abs)
            0x95, 0x07,                    //     REPORT_COUNT (7)
            0x81, 0x03,                    //     INPUT (Cnst,Ary,Abs)
            0x09, 0x51,                    //     USAGE (Contact Identifier)
            0x75, 0x08,                    //     REPORT_SIZE (8)
            0x95, 0x01,                    //     REPORT_COUNT (1)
            0x05, 0x01,                    //     USAGE_PAGE (Generic Desktop)
            0x09, 0x30,                    //     Usage (X)
            0x09, 0x31,                    //     Usage (Y)
            0x16, 0x00, 0x00,              //     Logical Minimum (0)
            0x26, 0xff, 0x7f,              //     Logical Maximum (32767)
            0x36, 0x00, 0x00,              //     Physical Minimum (0)
            0x46, 0xff, 0x7f,              //     Physical Maximum (32767)
            0x65, 0x11,                    //     Unit (Centimeter, SI-Linear)
            0x75, 0x10,                    //     Report Size (16),
            0x95, 0x02,                    //     Report Count (2),
            0x81, 0x02,                    //     Input (Data,Var,Abs)
            0xC0,                          //   END_COLLECTION
            /* Contact count */
            0x09, 0x54,                    //   USAGE (Contact count)
            0x25, 0x0A,                    //   LOGICAL_MAXIMUM (10)
      // Report ID 2: Advanced buttons
            0x05, 0x0C,       // Usage Page (Consumer)
            0x09, 0x01,       // Usage (Consumer Control)
            0xA1, 0x01,       // Collection (Application)
            0x85, 0x02,       // Report Id (2)
            0x15, 0x00,       // Logical minimum (0)
            0x25, 0x01,       // Logical maximum (1)
            0x75, 0x01,       // Report Size (1)
            0x95, 0x01,       // Report Count (1)
            0x09, 0xCD,       // Usage (Play/Pause)
            0x81, 0x06,       // Input (Data,Value,Relative,Bit Field)
            0x0A, 0x83, 0x01, // Usage (AL Consumer Control Configuration)
            0x09, 0xB5,       // Usage (Scan Next Track)
            0x09, 0xB6,       // Usage (Scan Previous Track)
            0x09, 0xEA,       // Usage (Volume Down)
            0x09, 0xE9,       // Usage (Volume Up)
            0x0A, 0x25, 0x02, // Usage (AC Forward)
            0x0A, 0x24, 0x02, // Usage (AC Back)
            0xC0,             // End Collection
    Sorry, I am not sure I understand your issue correctly. Do I understand it correctly that you had a media button set up correctly and working, and a separate project with a touchscreen HID device working correctly, but when you merged the projects together they both stopped working?
    If so, please provide more information about the behavior you are seeing, how you proceeded to merge the projects, and what you have done to debug the issue.
    I see from your comment that you have shared your HID commands, but without any other context what so ever it is hard for me to do any type of debugging. Is there a particular command/input that is failing(if so, which?), or do you get any error messages? Is the project compiling even?
    Please provide more information to make your issue clear.
    Karl
