I'm using the <TWI Scanner> example. I use an oscilloscope to measure the signal of SCL (see image)
According to the datasheet, I'm connecting a 4.7K resistor to connect "SDA & V_DD" and "SCL & V_DD" respectively, where V_DD = 3.22V by measurement.
I have disabled the internal pull-up resistor for SDA and SCL.
#define SCL_PIN_INIT_CONF \ ( (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos) \ | (GPIO_PIN_CNF_DRIVE_S0D1 << GPIO_PIN_CNF_DRIVE_Pos) \ | (GPIO_PIN_CNF_PULL_Pullup << GPIO_PIN_CNF_PULL_Disabled) \ | (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) \ | (GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos)) #define SDA_PIN_INIT_CONF SCL_PIN_INIT_CONF #define SDA_PIN_UNINIT_CONF \ ( (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos) \ | (GPIO_PIN_CNF_DRIVE_H0H1 << GPIO_PIN_CNF_DRIVE_Pos) \ | (GPIO_PIN_CNF_PULL_Pullup << GPIO_PIN_CNF_PULL_Disabled) \ | (GPIO_PIN_CNF_INPUT_Disconnect << GPIO_PIN_CNF_INPUT_Pos) \ | (GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos)) #define SCL_PIN_UNINIT_CONF SDA_PIN_UNINIT_CONF #define SCL_PIN_INIT_CONF_CLR \ ( (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos) \ | (GPIO_PIN_CNF_DRIVE_S0D1 << GPIO_PIN_CNF_DRIVE_Pos) \ | (GPIO_PIN_CNF_PULL_Pullup << GPIO_PIN_CNF_PULL_Disabled) \ | (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) \ | (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos)) #define SDA_PIN_INIT_CONF_CLR SCL_PIN_INIT_CONF_CLR
Question:
1) Why SCL signal amplitude is up and down periodically?
2) Why SCL signal is not 0V and V_DD=3.22V? It's actually 0.25--2.7V.
Problem solved!
It's due to my circuit had a bad connection. Some circuits are shorted.
I'm using nRF52 DK (nRF52832)
