What is the used coding scheme in nRF Connect for Mobile when advertising on Coded PHY? Is it S2 or S8?
Should be clarified in the screen below
Lukas
Lukas
Hi
It appears as the Android stack doesn't specify which mode is being used, when setting the primary PHY, see the Android developer forum here and here for details. An educated guess is that it's using the S=8, but I don't have a phone supporting Coded PHY at my disposal as of now as I'm restricted to home office due to the COVID-19 situation in Trondheim. You should be able to see this by taking a sniffer trace of the advertisement if you're able to. If not, I'll see what I can do to take a sniffer trace myself and get back to you when I know for certain.
Simon
Hi, I tried to use a sniffer to see if it is S2 or S8. However, I was not able to see it using Sniffle sniffer. Maybe some more sophisticated one will be able to check it (e.g., Ellisys)
Hi, I'm not familiar with the Sniffle sniffer. But you should be able to see the (S=X) "mode" using the nRF Sniffer for instance. In this case you only need an nRF52 DK to and the nRF Sniffer firmware for Wireshark.
Simon
But nRF Sniffer supports neither AE nor Coded PHY
Hi again
You're right, of course. Very sorry about that. I wasn't thinking straight when providing that answer it seems. I will try to get someone in the office to do a sniffer trace with an Ellisys Sniffer using Coded PHY on an Android device. Alternatively, I'll have to go into office myself to get it done. Thank you for your patience!
Simon
