Problem using monitor mode debugging with the nrf connect sdk
Hello
I'm having some issues setting up monitor mode debugging  with the nrf connect sdk v1.4.99.
I've roughly followed the steps outlined in this guide, the exact steps I have taken are
1) Included the three monitor mode files in our project (JLINK_MONITOR.c, JLINK_MONITOR.h, JLINK_MONITOR_ISR_SES.s)
Sidenote: I have contacted segger support in order to get a hold of the JLINK_MONITOR_ISR_GCC.s file as instructed in the MMD link above, but am still awaiting a response. I am uncertain what if any difference there is between them and whether the GCC file is the correct one to use.
2) Added the following line to my main function "NVIC_SetPriority(DebugMonitor_IRQn, 7UL);" (I have also tried with lower priorities like e.g 16)
3) Ran the below gdb commands, I choose 0x26000 as I'm using a v17 softdevice and that's what seems to be used in the example ld files for that device.
mon exec SetMonModeDebug=1
mon exec SetMonModeVTableAddr=0x26000
Despite this whenever I stop at a breakpoint I still get a crash.
If I use the nordic softdevice link layer (BT_LL_SOFTDEVICE) the crash message is:
[00:00:03.690,948] <err> mpsl_init: MPSL ASSERT: 112, 2147
[00:00:03.690,979] <err> os: ***** HARD FAULT *****
[00:00:03.690,979] <err> os:   Fault escalation (see below)
[00:00:03.691,009] <err> os: r0/a1:  0x00000003  r1/a2:  0x20002778  r2/a3:  0x20002778
[00:00:03.691,009] <err> os: r3/a4:  0x00000000 r12/ip:  0x4000b000 r14/lr:  0x00029759
[00:00:03.691,009] <err> os:  xpsr:  0x61000018
[00:00:03.691,009] <err> os: Faulting instruction address (r15/pc): 0x00025fdc
[00:00:03.691,040] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
[00:00:03.691,040] <err> os: Fault during interrupt handling
[00:00:03.691,040] <err> os: Current thread: 0x20002778 (unknown)
[00:00:03.964,294] <err> fatal_error: Resetting system
If I instead use the zephyr software link layer (BT_LL_SW_SPLIT) I get the error message
ASSERTION FAIL [(ret == 0) || (ret == 2)] @ /home/<censored username>/.local/opt/ncs/zephyr/subsys/bluetooth/controller/ll_sw/ull_adv.c:1641
[00:00:13.674,804] <err> os: r0/a1:  0x00000003  r1/a2:  0x200011b8  r2/a3:  0x200011b8
[00:00:13.674,835] <err> os: r3/a4:  0x00000000 r12/ip:  0x00000000 r14/lr:  0x00017fcb
[00:00:13.674,835] <err> os:  xpsr:  0x6100001b
[00:00:13.674,835] <err> os: Faulting instruction address (r15/pc): 0x00017fd6
[00:00:13.674,835] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:13.674,835] <err> os: Fault during interrupt handling
[00:00:13.674,865] <err> os: Current thread: 0x200011b8 (unknown)
[00:00:13.922,454] <err> fatal_error: Resetting system
Looking in that ull_adv.c the offending line is:
		LL_ASSERT((ret == TICKER_STATUS_SUCCESS) ||
			  (ret == TICKER_STATUS_BUSY));
I'm guessing that means that the softdevice, and therefor the ticker, still gets stopped when ever I hit a breakpoint. Is that correct?
Any ideas about what I am doing wrong?
Are there any tutorials about how to implement monitor mode debugging with the nrf connect sdk and/or zephyr?
