Softdevice event handler continuously called with NRF_EVT_RADIO_BLOCKED
I've got another question concerning a timeslot application.
In our timeslot application which is based on the nRF Mesh SDK timeslot.c implementation I noticed that if a BLE connection is active with a connection interval of 7.5ms, the softdevice did not grant any timeslots. I noticed that the cause of this was that the requested timeslot length requested at the end of a timeslot was 14000us and therefore too long to fit into the 7.5ms connection interval. This resultd in the timeslot being canceled via invocation of the softdevice event handler with NRF_EVT_RADIO_CANCELED.
The handling of this event was a call to sd_radio_request() but using the same parameters that were canceled. This resulted in the softdevice event handler being called repeatedly with NRF_EVT_RADIO_CANCELED until either the BLE connection parameters were changed or the central disconnected.
To avert this behaviour I changed the request parameters to the values that were used in case of a NRF_EVT_RADIO_BLOCKED:
m_radio_request_earliest.request_type               = NRF_RADIO_REQ_TYPE_EARLIEST;
m_radio_request_earliest.params.earliest.hfclk      = NRF_RADIO_HFCLK_CFG_NO_GUARANTEE;
m_radio_request_earliest.params.earliest.priority   = NRF_RADIO_PRIORITY_NORMAL;
m_radio_request_earliest.params.earliest.length_us  = 3800;
m_radio_request_earliest.params.earliest.timeout_us = 15000;
This resulted in the timeslot being granted again after NRF_EVT_RADIO_CANCELED occurred.
I then realised that after changing the connection interval to 50ms with a slave latency of 2, timeslots get repeatedly blocked for a duration of 5ms (during the connection event) and only then are they being granted again. See the following chart:
I thought this behaviour looks odd and inefficient. Ideally, I expect the softdevice to not invoke the BLOCKED event, since the timeout - from my understanding - should only occur after 15000us? Invoking sd_radio_request() when handling the BLOCKED event with a length_us of 3800 and a timeout_us of 14000, I definitely don't expect the event handler to be invoked every ~50us!
So I tried to play around with the timeout_us parameter of the nrf_radio_request_t structure, but did not find a viable solution, in fact I only made it worse. When increasing the timeout_us e.g. to 50000, I noticed that the described behaviour occurs for a bit and then disappears, but the timeslot is only started after a total downtime of about 50ms! This drastically reduces the availability of our proprietary radio protocol.
  • Is there a clean way to avert these continuous BLOCKED events while still maximising timeslot duration?
  • Can you elaborate on the difference between the BLOCKED and CANCELED events?
  • What implications does/should changing the timeout of a radio request have?
By the way, this is all on an nRF52832 running S132 7.2.0.
  • Hi Michael,
    If you have a look at the documentation of the softdevice (SDS) you can find this scheduling properties:
    According to this if you request the timeslot at NORMAL priority it will have lower priority than the connection activity, meaning that if the timeslot doesn't fit entirely inside a period when there is no connection event (calculated by the event length reserved) it will get cancelled.
    Please try to test again with the priority set to HIGH.
    However, I couldn't explain why you get the event every 50us. We may need to look into your code to see why.
    You can have a look at my example code here.
    I attached the logic trace in my test here when the device first advertised, then entered a connection with interval = 7.5ms after 5 seconds the interval changed to 750ms. You can find the timeslot got cancelled multiple times, but still it get some slots in between.
    1 MHz, 20 M Samples [9].logicdata
  • Hi Hung Bui,
    Thank you for your response.
    I was aware of the above table, thanks. I think you helped me understand the difference between BLOCKED and CANCELED better, still, could you confirm that I got this right:
    • BLOCKED: the request with sd_radio_request() or via return value of the signal callback could not be granted within the provided timeout?
    • CANCELED: the softdevice originally intended to grant the requested timeslot - i.e. but at the point where it should have started, it could not grant it because an event of higher priority (e.g. BLE event when timeslot priority is normal) needs to be served during the timeslot.
    So that means from the callers perspective what happens is actually similar, but the two events are raised at different "stages" in the softdevice's scheduling.
    Is this right?
    This does not change the observed behaviour.
    "My code" for the timeslot implementation is actually the timeslot.c implementation from nRF SDK for Mesh 4.2.0.
    I did just play around with examples\sdk_coexist\ble_app_proximity_coexist in the nRF SDK for Mesh 4.2.0 and stumbled upon one change that I made that seems to be the cause of all my issues:
    Because we usually have the HFCLK running, I changed the hfclk parameter in the radio request to NRF_RADIO_HFCLK_CFG_NO_GUARANTEE. The change was prompted because I was afraid, that we could run into the issue described here. Therefore I implemented this as a temporary workaround.
    With the hfclk parameter set to NRF_RADIO_HFCLK_CFG_NO_GUARANTEE, the softdevice stops granting me timeslots when the connection interval is only 7.5ms. This is the behaviour I observed and described above and I followed this by changing the requests. But I could not reproduce the behaviour with the continuous calls of the softdevice event handler - even when updating to S132 7.2.0.
    So, maybe there is still something in our application that somehow interferes. Unfortunately I can't publicly share the application's source code here.
  • In the meantime, I was able to reproduce the issue with the ble_app_proximity example from the nRF SDK for Mesh 4.2.0.
    I've attached the diff to the nRF SDK for Mesh 4.2.0 folder. The modifications I made were:
    • Modified nRF5 SDK related paths in project file to point to folder nRF5_SDK at same level as the mesh SDK folder is.
    • Enabled and configured timeslot debug pins (default configuration for timeslot debugging in mesh/core):
      • P0.03: high while in timeslot
      • P0.04: high while in signal handler
      • P0.28: high while trying to extend timeslot
      • P0.29: high when serving TIMER0 IRQ
      • P0.30: high while in softdevice event handler (the culprit here!)
      • P0.31: High when timeslot end is reached
      • P0.24: High if high priority timeslot was requested
      • P0.25: High if extension succeeded.
    • Set APP_TIMER_CONFIG_RTC_FREQUENCY to 0 (only way the example runs)
    • Set NRF_SDH_BLE_GAP_EVENT_LENGTH to 320 --> this triggers the issue!
    timeslot-sd-event-loop.patch
    So I've touched on two issues here:
    1. The weird behaviour (described in the initial post) that occurs during a BLE connection where the SD event handler is invoked repeatedly. This seems to happen in the suppleid exemple when settting NRF_SDH_BLE_GAP_EVENT_LENGTH to 320. We set this to a high value to be able to achieve higher BLE throughput when needed.
      Do you have any explanation as to why this behaviour occurs and how it can be avoided?
    2. When setting the hfclk parameter to NRF_RADIO_HFCLK_CFG_NO_GUARANTEE, no timeslots can be served if the connection interval is only 7.5ms. The idea was to configure the hfclk that way because we are able to have it continuously running, as we do not have any battery constraints. Additionally, there seems to be a connection issue that seems to be avoidable if NRF_RADIO_HFCLK_CFG_NO_GUARANTEE is chosen.
      So why can no timeslots be served with a 7.5ms connection interval and NRF_RADIO_HFCLK_CFG_NO_GUARANTEE even though the HFCLK is running?
    Looking forward to your responses!
    Thank you & best regards,
    -mike
  • Hi Michael,
    I tried this configuration:
    #define TS_LEN_US                   (5000UL)                /**< Length of timeslot to be requested. */
    #define TX_LEN_EXTENSION_US         (5000UL)                /**< Length of timeslot to be extended. */
    #define TS_SAFETY_MARGIN_US         (700UL)                 /**< The timeslot activity should be finished with this much to spare. */
    #define TS_EXTEND_MARGIN_US         (2000UL)                /**< Margin reserved for extension processing. */
    uint32_t request_next_event_earliest(void)
        m_timeslot_request.request_type                = NRF_RADIO_REQ_TYPE_EARLIEST;
        m_timeslot_request.params.earliest.hfclk       = NRF_RADIO_HFCLK_CFG_NO_GUARANTEE;
        m_timeslot_request.params.earliest.priority    = NRF_RADIO_PRIORITY_HIGH;
        m_timeslot_request.params.earliest.length_us   = TS_LEN_US;
        m_timeslot_request.params.earliest.timeout_us  = 500000;
        return sd_radio_request(&m_timeslot_request);
    /**@brief Configure next timeslot event in earliest configuration.
    void configure_next_event_earliest(void)
    And it doesn't seem to get any problem with 7.5ms. The timeslot is granted every other connection event.
    You can try my code here. please update with the above configuration.
    When you use NRF_RADIO_HFCLK_CFG_NO_GUARANTEE, you have the responsibility to disable the crystal before the timeslot end. And the softdevice would need to start it again when it get back to BLE activity. So it may take longer time for the softdevice to ramp up the radio before it can handle the BLE activity. But in my case this anyway doesn't seem to affect the timeslot request. You can find attached trace which i used the NRF_RADIO_HFCLK_CFG_NO_GUARANTEE with 7.5ms interval.
    10Feb.zip
    Regarding issue #1 if you can find away to reproduce with my example code on github above, I can try to test here.
  • Hi Hung Bui,
    I'm not sure it would be of much use to try our application with your example, since we use the entire timeslot extension algorithm from Nordic's Mesh stack - which apart from these few open issues I have - works really well and allows us to absolutely maximise timeslot use...
    Why would I need to disable it? Can't I leave it running for the entire run time of my application?
    Would be great if you could take a look at the mesh example I provided above. It's almost out of the box, the only modifications I did were the required path adaptations and setting NRF_SDH_BLE_GAP_EVENT_LENGTH to 320.
    I'll see if I manage to reproduce it with your example, though.
    Thanks & regards,
    -mike
