Button events are not triggered on NRF52840 Dongle
The single button in the Dongle does not generate any events.  I have made all the relevant changes for the preprocessor for the usage with Dongle. Kindly let me know what to be modifed?
The buttons_handler in the below program does not get called
#include "zboss_api.h"
#include "zb_mem_config_custom.h"
#include "zb_error_handler.h"
#include "zigbee_helpers.h"
#include "app_timer.h"
#include "bsp.h"
#include "boards.h"
#include "nordic_common.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
static void buttons_handler(bsp_event_t evt)
    zb_ret_t zb_err_code;
    zb_uint32_t button;
    bsp_board_led_invert(BSP_BOARD_LED_1);
/**@brief Function for initializing LEDs and buttons.
static zb_void_t leds_buttons_init(void)
    ret_code_t error_code;
    /* Initialize LEDs and buttons - use BSP to control them. */
    bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, buttons_handler);
    /* Initialize timers, loging system and GPIOs. */
    timers_init();
    log_init();
    leds_buttons_init();
    /* Set Zigbee stack logging level and traffic dump subsystem. */
    ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
    ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
    ZB_SET_TRAF_DUMP_OFF();
    /* Initialize Zigbee stack. */
    ZB_INIT("light_switch");
    /* Set device address to the value read from FICR registers. */
    zb_osif_get_ieee_eui64(ieee_addr);
    zb_set_long_address(ieee_addr);
    zb_set_network_ed_role(IEEE_CHANNEL_MASK);
    zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
    zb_set_ed_timeout(ED_AGING_TIMEOUT_64MIN);
    zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
    // sleepy_device_setup();
    /* Initialize application context structure. */
    UNUSED_RETURN_VALUE(ZB_MEMSET(&m_device_ctx, 0, sizeof(light_switch_ctx_t)));
    /* Set default bulb short_addr. */
    m_device_ctx.bulb_params.short_addr = 0xFFFF;
    /* Register dimmer switch device context (endpoints). */
    ZB_AF_REGISTER_DEVICE_CTX(&dimmer_switch_ctx);
    /** Start Zigbee Stack. */
    zb_err_code = zboss_start_no_autostart();
    ZB_ERROR_CHECK(zb_err_code);
    while(1)
        zboss_main_loop_iteration();
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
