Disabling SPI on Thingy91
Hey Nordic Team,
I am trying to disable the SPI module to optimize my project and reduce flash usage. The Zephyr optimization guide refers to disabling unused peripherals so I attempted to set CONFIG_SPI=n in my project configuration (prj.conf). From my research, this should be possible because SPI is only used to control the two accelerometers and if I am not taking advantage of them in my project it follows that I should be able to disable to SPI module completely.
Unfortunately, after setting CONFIG_SPI to n in my project, the board no longer boots when the resulting firmware is flashed.
Is it Nordics understanding that I should be able to disable SPI on the Thingy91 and if so is there any other configuration then CONFIG_SPI=n in my project configuration that I might be missing?
Cody
