Initialising peripheral fails NRFX_DRV_STATE_UNINITIALIZED and program hangs with Invalid State hardfault
Hello, I am stuck initalising both TWIM and UARTE. I am focusing on the TWI Scanner example but using TWIM instead of TWI. No matter what I do I cannot get past the initalisation. The problem is that for both peripherals they fail the condition p_cb->state != NRFX_DRV_STATE_UNINITIALIZED.
I am seeing consistantly p_cb->state = 0x28 for UARTE and 0x10 for TWIM.
To simplify the reproduction I've now removed TWIM from my code and am only focusing on UARTE. I am really stuck at the moment and could use some advice.
My setup
  • Development Software:
    • nRF52 SDK v17.0.2
    • No software device
    • IDE: Visual Studio Code v1.53.2
  • Hardware: nRF52 DK (nRF52832) It says 2.0.0 on the sticker, I'm guessing that's the version?
  • Computer Platform: Ubuntu 20.10
Code
extern "C" {
    #include <stdio.h>
    #include "boards.h"
    #include "app_error.h"
    #include "sdk_config.h"
    #include "nrf.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
int main() {
    NRF_LOG_DEFAULT_BACKENDS_INIT(); // Hangs here
    while (true)
        NRF_LOG_INFO("TWI scanner started.");
        NRF_LOG_FLUSH();
    return 0;
Preprocessor definitions
  • BOARD_PCA10040
  • NRF52832_XXAA
  • ENABLE_SWO
  • ENABLE_TRACE
  • DEBUG
  • DEBUG_NRF
Screenshots
You can see on the left that state is assigned 0x28. Where does that value come from? Perhaps the variable is uninitalised and random?
SDK Source files
  • /components/libraries/util/app_util_platform.c
  • /components/libraries/util/app_error.c
  • /components/libraries/util/app_error_handler_gcc.c
  • /components/serialization/connectivity/ser_conn_error_handling.c
  • /components/libraries/ringbuf/nrf_ringbuf.c
  • /components/libraries/memobj/nrf_memobj.c
  • /components/libraries/balloc/nrf_balloc.c
  • /components/libraries/atomic/nrf_atomic.c
  • /components/libraries/log/src/nrf_log_frontend.c
  • /components/libraries/log/src/nrf_log_default_backends.c
  • /components/libraries/log/src/nrf_log_backend_uart.c
  • /components/libraries/log/src/nrf_log_backend_serial.c
  • /components/libraries/log/src/nrf_log_str_formatter.c
  • /external/fprintf/nrf_fprintf.c
  • /external/fprintf/nrf_fprintf_format.c
  • /modules/nrfx/drivers/src/nrfx_uart.c
  • /modules/nrfx/drivers/src/nrfx_uarte.c
  • /modules/nrfx/drivers/src/prs/nrfx_prs.c
  • /integration/nrfx/legacy/nrf_drv_uart.c
  • I've added more information in my post. Please let me know if there's more info you need.
    Looking at your code I do not see anything that should not work if you use a supported toolchain. I notice the extern "C" part, so perhaps you are using a C++ compiler? If so note that it is not tested and not supported (and we know some SDK modules will not work). I do not immediately see the issue here though. Can you let me know which toolchain you use and share your Makefile or project file or similar? Note that the list of supported toolchains is listed in the SDK release notes (that does not mean that other cannot work, but I would strongly recommend using a supported toolchain if you have issues).
  • Hi Einar,
    > I was using gcc-arm-none-eabi-10-2020-q4-major and I have now switched to the compiler the SDK release notes mention: gcc-arm-none-eabi-9-2019-q4-major. I am using CMake for this.
    There was no change. But I did eventually resolve the issue.
    I have one big target_source in CMake and was able to resolve the issue by making nrfx_uarte.c appear in the list before nrf_log_frontend.c. Then I had another issue and that was resolve by making nrfx_prs.c appear in the list before nrfx_uarte.c .
    For both of the issues I noticed that static typedef structs were not being zero-initalised which made me think that something was wrong with the linking process.
    target_sources(twim PUBLIC
        "${NRF5_SDK_PATH}/modules/nrfx/drivers/src/prs/nrfx_prs.c" # needs to come before nrfx_uarte.c
        "${NRF5_SDK_PATH}/modules/nrfx/drivers/src/nrfx_uarte.c" # needs to come before nrf_log_frontend.c
        "${NRF5_SDK_PATH}/integration/nrfx/legacy/nrf_drv_uart.c"
        "${NRF5_SDK_PATH}/modules/nrfx/drivers/src/nrfx_uart.c"
        "${NRF5_SDK_PATH}/components/libraries/log/src/nrf_log_frontend.c"
    But now I face another issue. I spent almost 6 hours on this today and am left feeling a bit frustrated.
    The problem is here in nrf_log_backend_interface.h :
    __STATIC_INLINE bool nrf_log_backend_is_enabled(nrf_log_backend_t const * const p_backend)
        return p_backend->p_cb->enabled;
    I even changed my project from C++ to C to have things just like the TWI Scanner example. But there was no difference.
    My debugger reads this expression p_backend->p_cb->enabled as false, which matches the bool type. But just executing the expression p_backend->p_cb->enabled triggers a Hard fault. The return is not at fault here.
  • --specs=nano.specs ... my problem went away when I added this linker flag. Noticed the example used it.
  • Never mind, there are still errors. I think its best not to use the NRF log library... the problem seems to be that m_log_data in nrf_log_frontend.c does not zero initalise.
