nRF connect SDK vs nRF5 SDK
 I am developing a project related to transferring audio in low energy Bluetooth. I came across nrf connect sdk is the best one for LE Audio transmission
But I am familiar in nrf5 SDK to do custom services, DFU, custom bootloader.
My question is
1. How nRF connect SDK is differ from nRF5 SDK?
2. Is nRF5340 DK  work with nrf5 SDK?
3. For LE Audio transmission in Bluetooth nrf5 sdk is best or nrf connect sdk is best?
  • Hi
    Please check out this case which describes how to create a custom board file in the NCS/Zephyr/boards. The error you're seeing is likely caused by trying to open the project for a not supported board, and if so you need to add the board to the directory yourself.
    Simon
  • Hi Simonr,
       I have done changes in board.cmake file
    board_runner_args(nrfjprog "--nrf-family=NRF52")
    board_runner_args(jlink "--device=nrf52" "--speed=4000")
    board_runner_args(pyocd "--target=nrf52" "--frequency=4000000")
    include(${ZEPHYR_BASE}/boards/common/nrfjprog.board.cmake)
    include(${ZEPHYR_BASE}/boards/common/jlink.board.cmake)
    include(${ZEPHYR_BASE}/boards/common/pyocd.board.cmake)
    Previously it was
    include(${ZEPHYR_BASE}/boards/common/openocd-nrf5.board.cmake)
    only deleting this line
    NCS project is getting created and Build
    is this the correct one ?
    Is that need to create SOC folder for custom boards ?
  • Hi
    It should be fine to leave out the openocd.cmake file indeed. It is only required for USB I think, which the nRF52832 doesn't have either way.
    Simon
  • Hi Simon,
      Is it possible to change the multiple boards in the NCS project file
    like i have created the NCS project file nrf52dk_nrf52832
    and also i have created a custom board BC832
    but i can't able to change the boards as like nrf5 SDK in NCS
    How to change the multiple board configuration in the same build project file?
  • I'm not sure what you mean about "multiple board configuration". Either way, this case is no longer on the topic of "nRFConnect SDK versus nRF5 SDK" so I would suggest that you create a new ticket where you describe what you're trying to do and what you're having trouble with in detail. That will make cases for other DevZone users easier to navigate as well.
    Simon
