How to measure Battery state using VDDH on NRF52840?
I am new user for the Nordic NRF528400 microcontroller.
I am working on a project that is using the 8 channels of ADCs to get data from sensors. The system is powered by an external battery and it is necessary to know its status at all times in order to control the system to be powered by the battery or it is necessary to connect the charger.
I searched in the microcontroller datasheet and on Nordic dev zone; I found that even if the 8 channels of the ADC are used, we can use the VDDH pin of the µC (capture diagram_block)
My concern is how I can set the reference voltage? Can I connect VDDH directly to the battery and do I need to add elements like resistors or capacitors?
Cordially.
