Programming Nordic Thingy 91 with Segger Embedded Studio.
Hello Nordic team,
I am following up the tutorial (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/include/net/azure_iot_hub.html#lib-azure-iot-hub) conencting nordic thingy 91 to azure iot hub.
I have already obtained the certificates and key for azure iot hub.
This step tells me to  .
But following the above, in the last step of this link (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/gs_programming.html#gs-programming) "Build and Debug" I get an error "J link cannot find any emulator".
I have the following questions.
01.  Do I need a nRF9160 DK to program nordic thingy 91? or is there a work around?
02. Is there any tutorial link on how to program his application "samples/nrf9160/at_client" ?
03. When I connect the nordic thingy 91 to the multi port USB hub, the other connected devices to the same multi port aren't functioning any more. Is that a common one?
PS: I am a new bie to nordic thingy 91. I bought a nordic thingy 91 to connect it to the Azure IoT HUB.
Thanks and Regards,
Raj
  • Hello Raj,
    When working with the Thingy:91 please see our documentation on Programming Nordic Thingy:91 and Working with Thingy:91.
    As the Thingy:91 does not have a Segger OB debugger device as the nRF9160 DK, you can only program the Thingy:91 using either the nRF9160 DK with a 10 pin external debug cable or a Segger JLink programmer with support for Arm Cortex M33, or as a workaround you can program the device using MCUboot which lets you program the Thingy:91 through your USB.
    On the top of Building and programming a sample application it also states the following:
    Can you please elaborate on what happens? What kind of multi port USB hub are you using?
    Øyvind
  • Hello Øyvind,
    Thanks for the links they were helpful.
    I went through them and I have a question.
    To make the Nordic Thingy 91 communicate with the IoT Hub; I need to Build and Install the ""samples/nrf9160/at_client"" which has a main.c file.
    In the tutorials it was mentioned that to drag and drop the .HEX file.
    Could you please inform me how can I program this samples/nrf9160/at_client/main.c to Nordic thingy 91?
    Regarding the USB Multiport, when I connect the nordic things 91 the connection to my PC is established. But the existing usb connections to my wireless mouse and keyboard is lost. It was weird, But I shall look more on it and fix them.
    Raj
