How can I find source of problem?
Hi !
I'm trying to debug. I followed this video : https://www.youtube.com/watch?v=uP8RYgYGRvI&list=PLx_tBuQ_KSqGHmzdEL2GWEOeix-S5rgTV&index=7 .  But I can't completely.
the program stop at NRF_BREAKPOINT_COND in app_error_weak.c.
I used breakpoint to understand which function the error occurred after.  I guess there is a problem when setting Uart. What should I do to better interpret the problem? What can be the problem ?
The program enters the following functions respectively:
1- nrf_drv_uart_init(...);
2- nrfx_uart_init(....);
3- interrupts_enable(....)
4- NRFX_IRQ_PRIORITY_SET(nrfx_get_irq_number((void *)p_instance->p_reg), interrupt_priority);
5- nrfx_get_irq_number(.....)
I added the 5 step's photos to explain better
1)
2)
3)
4)
5)
after step 5, the program stop at at NRF_BREAKPOINT_COND in app_error_weak.c
  • cemalb said:
    I've never been changes to the libraries or drivers. But the person who worked on this project before may have done it. I do not know that, Because unfortunately I cannot reach him. I have no information about the past of the project.
    Aha, I see. That makes it harder, but not impossible to root out.
    Just to make sure, are you saying that you were just handed the application code as part of an SDK folder, with all its contents?
    If so, I recommend that you do a full check of the SDK, to root out any changes that might have been made to the drivers and libraries provided with the SDK. This might save your tremendous amounts of debugging headaches later on, and if left unchecked can cripple your ability to migrate SDK versions later on.
    You could do this by downloading a mint condition SDK of the same version that you are using now, and then using any kind of directory-and-file comparison tool on the two.
    Are you developing on Widows, Linux or iOS?
    cemalb said:
    If there is a suspicious place, I can look there and make the necessary corrections. Or if you can help migrate the project to the new SDK I can also try doing that.
    Which SDK version are you working with, and how long has it been used for development?
    Is it only a single person that has developed on this project prior?
    Migrating to a mint SDK might break the product's code, if the application code relies on changes to certain drivers and libraries.
    Modifying the provided drivers and libraries in place is very bad coding practice, and hopefully, the difference check I recommended above will reveal that the prior developer did not modify the SDK libraries or drivers, but it is a big uncertainty to leave unchecked, in my opinion.
    The error you posted earlier does not necessarily indicate that drivers and/or libraries have been modified, so checking whether the SDK has been modified or not is more of a sidetrack to that particular debugging, but as mentioned it could save you a great deal of debugging and frustration down the line, if it turns out that modifications have been made in places you are not aware of.
    Regarding the error message you shared in your previous comment, I would still like to know what priorities you are using for your peripherals. Could you also please tell me which SDK version you are working with?
    Karl
    I'm sorry that I haven't been able to write for a few days. I was busy.
    I did this. I compared the sdk folder where my project is with the sdk folder I downloaded from nordicsemi.com. Unfortunately, the folders is not exactly the same. there are some differences.
    i'm working with windows10
    sdk 15.3.0 was used in the project. The project was unfortunately organized by different developers at different times.
    sorry, I did not understand exactly.
    No worries at all - we continue whenever you are ready and have the time :)
    Great, this is very good, well done!
    I am curious as to what is changed in each of these files also. I do not know what or why he possibly would make changes in the softdevice folder, for instance. Does the tool you are using also do file-content comparisons?
    I assume you downloaded the exact SDK version the project was using originally, could you confirm this?
    I understand, thank you for clarifying. When this happens, it is paramount to learn what the previous developers were doing, and how they worked to achieve it. I feel we are on the right path here, since we now have a clearer view how they have worked with the SDK.
    Still, it would be good to see file-content comparisons, to see exactly which changes have been made.
    In my earlier comment I asked if you could ensure that you were not trying to use any of the priority levels reserved for the SoftDevice:
    Karl Ylvisaker said:
    Are you attempting to use any of the priority levels reserved for the SoftDevice in your application?
    Could you take a look, verify that this is not the case?
    Karl
  • I assume you downloaded the exact SDK version the project was using originally, could you confirm this?
    Yes, I downloaded sdk 15.3.0 from https://www.nordicsemi.com/
    Yes it also compares the contents of the files. I also compared the contents of files. however, when I examined the contents of the files, I could not see any difference.
    but when I wanted to do this it gave a warning like this:
    I don't know exactly what that means.
    I did not add anything related to priority level to the program. Or I haven't made any changes to the current settings. However, developers before me may have made a change.
    uart is used in the project. There may be a priority level setting for its interrupt function. but I don't know how to find out.
    Great, thank you for confirming.
    Does the program not generate a file, which contains all the differences between the files?
    I am not familiar with the particular program you are using/showing screenshots from, but that is how the comparison programs usually work, in my experience.
    Carrier Return is a character used to delineate the end of a line. I am not aware of any changes we have made to the used carriage return type in our SDK's, so I am not sure why this would throw an error, if nothing is changed in the SDK files by the previous developer.
    I suppose you could do as the warning suggests, and treat them as equal for the purpose of the comparison. This is not really the changes we are looking for, we are primarily concerned with changes to the functionality.
    Are you seeing anything show up in your comparison, when compared with the original example?
    Changes here would be in the sdk_config file.
    This is usually defined in the sdk_config file. For example, if you are using the nrfx_uart driver, it would in the sdk examples be named NRFX_UART_CONFIG_IRQ_PRIORITY. The priority to use is passed to the peripheral during its initialization, so you may look there too, if the previous developer has not defined the IRQ_PRIORITY in the sdk_config.
    Karl
