How can I find source of problem?
Hi !
I'm trying to debug. I followed this video : https://www.youtube.com/watch?v=uP8RYgYGRvI&list=PLx_tBuQ_KSqGHmzdEL2GWEOeix-S5rgTV&index=7 .  But I can't completely.
the program stop at NRF_BREAKPOINT_COND in app_error_weak.c.
I used breakpoint to understand which function the error occurred after.  I guess there is a problem when setting Uart. What should I do to better interpret the problem? What can be the problem ?
The program enters the following functions respectively:
1- nrf_drv_uart_init(...);
2- nrfx_uart_init(....);
3- interrupts_enable(....)
4- NRFX_IRQ_PRIORITY_SET(nrfx_get_irq_number((void *)p_instance->p_reg), interrupt_priority);
5- nrfx_get_irq_number(.....)
I added the 5 step's photos to explain better
1)
2)
3)
4)
5)
after step 5, the program stop at at NRF_BREAKPOINT_COND in app_error_weak.c
  • Hi !
    Are you seeing anything show up in your comparison, when compared with the original example?
    Changes here would be in the sdk_config file.
    As a result of my review, I realized that the project I was working on was developed on a "ble_app_template" project. I compared the sdk_config.h file of the project I am working with and the sdk_config.h files of the "ble_app_template" project. The comparison program I use has generated a report in html format. You can find it attached.
    In this way, I think we will reach a better solution.
    report.htm
    I am happy to hear that the comparisons are revealing these details, and proving tangible results.
    This is very helpful information.
    Have you been able to confirm that no changes have been made within the drivers of the SDK?
    Thank you - is there anything in particular you would like me to take a closer look at?
    I must once again emphasize that I think it would be better to have the output of the comparison only contain the differences - this will make the work of manually tracking differences much easier for you - I am certain that this must be an option in the comparison tool you are using.
    I also see from the generated report that your project's path includes 'space'/empty characters. I recommend that you replace these, to avoid future compatibility issues with applications and tools not originally developed on/for windows.
    So, we are back to the original issue?
    Are you still getting the same 'unknown error' printed to your RTT terminal when the program is run?
    Karl
  • Hi !
    Yes, unfortunately. it gives the same error again. I also set up for the comparator. i just created a report showing the only differences. Do you think there is a difference that causes our problem?
    By the way, I fixed the spaces in the folder names as you said. Thank you for your warning. Slight smile
  • Hello again,
    The error points towards the 107th line of nrfx_glue.h which is an assert that triggers if an invalid priority level is attempted used.
    Did you ever check whether any of the peripherals you are using in your project attempt to set a priority that conflicts with the priority levels reserved for the SoftDevice that I mentioned earlier?
    Those top priority levels are only available when the SoftDevice is not present.
    I do not suspect that a change has been made to the SDK, but it is still good for you and the future development to be aware of any changes the previous developer might have made, if any. So, it is still good that you have taken the time to verify the integrity of the SDK you have been handed from the previous developer.
    Great, I am happy to hear that you found it helpful!
    Karl
  • I forgot to share this. I am so sorry.
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
    	"http://www.w3.org/TR/html4/loose.dtd">
    <html>
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
    <title>WinMerge File Compare Report</title>
    <style type="text/css">
    table {margin: 0; border: 1px solid #a0a0a0; box-shadow: 1px 1px 2px rgba(0, 0, 0, 0.15);}
    td,th {word-break: break-all; font-size: 12pt;padding: 0 3px;}
    tr { vertical-align: top; }
    .title {color: white; background-color: blue; vertical-align: top; padding: 4px 4px; background: linear-gradient(mediumblue, darkblue);}
    .sf3b2 {color: #000000; background-color: #ffffff; }
    .sf3b5 {color: #000000; background-color: #0078d7; }
    .sf3b14 {color: #000000; background-color: #ffa0a0; }
    .sf3b16 {color: #000000; background-color: #f1e2ad; }
    .sf3b18 {color: #000000; background-color: #ffaa82; }
    .sf3b19 {color: #000000; background-color: #c8816c; }
    .sf6b2 {color: #ffffff; background-color: #ffffff; }
    .sf6b5 {color: #ffffff; background-color: #0078d7; }
    .sf6b14 {color: #ffffff; background-color: #ffa0a0; }
    .sf6b16 {color: #ffffff; background-color: #f1e2ad; }
    .sf6b18 {color: #ffffff; background-color: #ffaa82; }
    .sf6b19 {color: #ffffff; background-color: #c8816c; }
    .sf7b2 {color: #0000ff; background-color: #ffffff; font-weight: bold; }
    .sf7b5 {color: #0000ff; background-color: #0078d7; font-weight: bold; }
    .sf7b14 {color: #0000ff; background-color: #ffa0a0; font-weight: bold; }
    .sf7b16 {color: #0000ff; background-color: #f1e2ad; font-weight: bold; }
    .sf7b18 {color: #0000ff; background-color: #ffaa82; font-weight: bold; }
    .sf7b19 {color: #0000ff; background-color: #c8816c; font-weight: bold; }
    .sf8b2 {color: #800080; background-color: #ffffff; }
    .sf8b5 {color: #800080; background-color: #0078d7; }
    .sf8b14 {color: #800080; background-color: #ffa0a0; }
    .sf8b16 {color: #800080; background-color: #f1e2ad; }
    .sf8b18 {color: #800080; background-color: #ffaa82; }
    .sf8b19 {color: #800080; background-color: #c8816c; }
    .sf9b2 {color: #008000; background-color: #ffffff; }
    .sf9b5 {color: #008000; background-color: #0078d7; }
    .sf9b14 {color: #008000; background-color: #ffa0a0; }
    .sf9b16 {color: #008000; background-color: #f1e2ad; }
    .sf9b18 {color: #008000; background-color: #ffaa82; }
    .sf9b19 {color: #008000; background-color: #c8816c; }
    .sf10b2 {color: #ff0000; background-color: #ffffff; }
    .sf10b5 {color: #ff0000; background-color: #0078d7; }
    .sf10b14 {color: #ff0000; background-color: #ffa0a0; }
    .sf10b16 {color: #ff0000; background-color: #f1e2ad; }
    .sf10b18 {color: #ff0000; background-color: #ffaa82; }
    .sf10b19 {color: #ff0000; background-color: #c8816c; }
    .sf11b2 {color: #606060; background-color: #ffffff; }
    .sf11b5 {color: #606060; background-color: #0078d7; }
    .sf11b14 {color: #606060; background-color: #ffa0a0; }
    .sf11b16 {color: #606060; background-color: #f1e2ad; }
    .sf11b18 {color: #606060; background-color: #ffaa82; }
    .sf11b19 {color: #606060; background-color: #c8816c; }
    .sf12b2 {color: #800000; background-color: #ffffff; }
    .sf12b5 {color: #800000; background-color: #0078d7; }
    .sf12b14 {color: #800000; background-color: #ffa0a0; }
    .sf12b16 {color: #800000; background-color: #f1e2ad; }
    .sf12b18 {color: #800000; background-color: #ffaa82; }
    .sf12b19 {color: #800000; background-color: #c8816c; }
    .sf13b2 {color: #0080c0; background-color: #ffffff; }
    .sf13b5 {color: #0080c0; background-color: #0078d7; }
    .sf13b14 {color: #0080c0; background-color: #ffa0a0; }
    .sf13b16 {color: #0080c0; background-color: #f1e2ad; }
    .sf13b18 {color: #0080c0; background-color: #ffaa82; }
    .sf13b19 {color: #0080c0; background-color: #c8816c; }
    .sf15b2 {color: #000000; background-color: #ffffff; }
    .sf15b5 {color: #000000; background-color: #0078d7; }
    .sf15b14 {color: #000000; background-color: #ffa0a0; }
    .sf15b16 {color: #000000; background-color: #f1e2ad; }
    .sf15b18 {color: #000000; background-color: #ffaa82; }
    .sf15b19 {color: #000000; background-color: #c8816c; }
    .sf17b2 {color: #000000; background-color: #ffffff; }
    .sf17b5 {color: #000000; background-color: #0078d7; }
    .sf17b14 {color: #000000; background-color: #ffa0a0; }
    .sf17b16 {color: #000000; background-color: #f1e2ad; }
    .sf17b18 {color: #000000; background-color: #ffaa82; }
    .sf17b19 {color: #000000; background-color: #c8816c; }
    .sf20b2 {color: #000080; background-color: #ffffff; }
    .sf20b5 {color: #000080; background-color: #0078d7; }
    .sf20b14 {color: #000080; background-color: #ffa0a0; }
    .sf20b16 {color: #000080; background-color: #f1e2ad; }
    .sf20b18 {color: #000080; background-color: #ffaa82; }
    .sf20b19 {color: #000080; background-color: #c8816c; }
    .sf21b2 {color: #0080c0; background-color: #ffffff; }
    .sf21b5 {color: #0080c0; background-color: #0078d7; }
    .sf21b14 {color: #0080c0; background-color: #ffa0a0; }
    .sf21b16 {color: #0080c0; background-color: #f1e2ad; }
    .sf21b18 {color: #0080c0; background-color: #ffaa82; }
    .sf21b19 {color: #0080c0; background-color: #c8816c; }
    .ln {text-align: right; word-break: normal; color: #000000; background-color: #f0f0f0;}
    </style>
    </head>
    <body>
    <table cellspacing="0" cellpadding="0" style="width:100%;">
    <thead>
    <tr>
    <th colspan="2" class="title" style="width:50.000000%">D:\1_2_btc_nordic_dokuman\DeviceDownload\nRF5SDK153059ac345\nRF5_SDK_15.3.0_59ac345\examples\ble_peripheral\ble_app_template\pca10040\s132\config\sdk_config.h</th>
    <th colspan="2" class="title" style="width:50.000000%">D:\1_1_kale_kilit_yazilim\V.1.5.9_CML\V1.5.9\V1.5.9\examples\btc_ble_peripheral\BTC_Project\pca10040\s132\config\sdk_config.h</th>
    </tr>
    </thead>
    <tbody>
    <tr>
    <td class="ln">879</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d1" href="#d1">880</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">880</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">881</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr height=1><td style="background-color: black"></td><td style="background-color: black"></td><td style="background-color: black"></td><td style="background-color: black"></td></tr>
    <tr>
    <td class="ln">952</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224R<wbr>1_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d2" href="#d2">953</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224R<wbr>1_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">953</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224R<wbr>1_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">954</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">961</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256R<wbr>1_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d3" href="#d3">962</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256R<wbr>1_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">962</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256R<wbr>1_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">963</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">970</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP384R<wbr>1_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d4" href="#d4">971</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP384R<wbr>1_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">971</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP384R<wbr>1_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">972</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">979</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP521R<wbr>1_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d5" href="#d5">980</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP521R<wbr>1_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">980</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP521R<wbr>1_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">981</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">988</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP192K<wbr>1_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d6" href="#d6">989</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP192K<wbr>1_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">989</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP192K<wbr>1_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">990</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">997</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224K<wbr>1_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d7" href="#d7">998</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224K<wbr>1_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">998</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224K<wbr>1_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">999</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1006</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256K<wbr>1_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d8" href="#d8">1007</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256K<wbr>1_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">1007</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256K<wbr>1_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">1008</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1015</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP256R1_<wbr>ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d9" href="#d9">1016</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP256R1_<wbr>ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">1016</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP256R1_<wbr>ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">1017</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1024</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP384R1_<wbr>ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d10" href="#d10">1025</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP384R1_<wbr>ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">1025</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP384R1_<wbr>ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">1026</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1033</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP512R1_<wbr>ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d11" href="#d11">1034</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP512R1_<wbr>ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">1034</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP512R1_<wbr>ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">1035</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1042</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_CURVE255<wbr>19_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d12" href="#d12">1043</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_CURVE255<wbr>19_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">1043</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_CURVE255<wbr>19_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">1044</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1060</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_HASH_SHA512_<wbr>ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d13" href="#d13">1061</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_HASH_SHA512_<wbr>ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">1061</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_HASH_SHA512_<wbr>ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">1062</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1078</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_HMAC_SHA512_<wbr>ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d14" href="#d14">1079</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_HMAC_SHA512_<wbr>ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">1079</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_MBEDTLS_HMAC_SHA512_<wbr>ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">1080</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1131</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_CRYPTO_BACKEND_NRF_HW_RNG_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d15" href="#d15">1132</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_NRF_HW_RNG_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">1132</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_BACKEND_NRF_HW_RNG_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">1133</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1239</td><td class="sf3b2"><code>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d16" href="#d16">.</a></td><td style="color: #000000; background-color: #c0c0c0; "><code>&nbsp;</code></td>
    <td class="ln">1240</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#ifndef NRF_CRYPTO_RNG_STATIC_MEMORY_BUFFERS_EN<wbr>ABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"></td><td style="color: #000000; background-color: #c0c0c0; "><code>&nbsp;</code></td>
    <td class="ln">1241</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_RNG_STATIC_MEMORY_BUFFERS_EN<wbr>ABLED 1</span></code></td>
    </tr>
    <tr>
    <td class="ln">1242</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1243</td><td style="color: #000000; background-color: #efcb05; "><code>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">1244</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#ifndef NRF_CRYPTO_RNG_AUTO_INIT_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln">1245</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_CRYPTO_RNG_AUTO_INIT_ENABLED 1</span></code></td>
    </tr>
    <tr>
    <td class="ln">1246</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">1240</td><td class="sf3b2"><code><span class="sf9b2">// &lt;/e&gt;</span></code></td>
    <td class="ln">1247</td><td class="sf3b2"><code><span class="sf9b2">// &lt;/e&gt;</span></code></td>
    </tr>
    <tr>
    <td class="ln">2986</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRFX_RNG_ENABLED</span></code></td>
    <td class="ln">2993</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRFX_RNG_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d17" href="#d17">2987</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRFX_RNG_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">2994</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRFX_RNG_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">2988</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">2995</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">4363</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRFX_UART0_ENABLED</span></code></td>
    <td class="ln">4370</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRFX_UART0_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d18" href="#d18">4364</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRFX_UART0_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">4371</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRFX_UART0_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">4365</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">4372</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">4480</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRFX_WDT_ENABLED</span></code></td>
    <td class="ln">4487</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRFX_WDT_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d19" href="#d19">4481</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRFX_WDT_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">4488</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRFX_WDT_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">4482</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">4489</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">4497</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRFX_WDT_CONFIG_RELOAD_VALUE</span></code></td>
    <td class="ln">4504</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRFX_WDT_CONFIG_RELOAD_VALUE</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d20" href="#d20">4498</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRFX_WDT_CONFIG_RELOAD_VALUE </span><span class="sf17b16">2</span><span style="color: #000000; background-color: #efcb05; ">000</span></code></td>
    <td class="ln">4505</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRFX_WDT_CONFIG_RELOAD_VALUE </span><span class="sf17b16">3000</span><span style="color: #000000; background-color: #efcb05; ">000</span></code></td>
    </tr>
    <tr>
    <td class="ln">4499</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">4506</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">5107</td><td class="sf3b2"><code><span class="sf13b2">#ifndef RNG_ENABLED</span></code></td>
    <td class="ln">5114</td><td class="sf3b2"><code><span class="sf13b2">#ifndef RNG_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d21" href="#d21">5108</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define RNG_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">5115</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define RNG_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">5109</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">5116</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">5783</td><td class="sf3b2"><code><span class="sf13b2">#ifndef UART_EASY_DMA_SUPPORT</span></code></td>
    <td class="ln">5790</td><td class="sf3b2"><code><span class="sf13b2">#ifndef UART_EASY_DMA_SUPPORT</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d22" href="#d22">5784</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define UART_EASY_DMA_SUPPORT </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">5791</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define UART_EASY_DMA_SUPPORT </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">5785</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">5792</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">5868</td><td class="sf3b2"><code><span class="sf13b2">#ifndef WDT_ENABLED</span></code></td>
    <td class="ln">5875</td><td class="sf3b2"><code><span class="sf13b2">#ifndef WDT_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d23" href="#d23">5869</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define WDT_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">5876</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define WDT_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">5870</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">5877</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">5885</td><td class="sf3b2"><code><span class="sf13b2">#ifndef WDT_CONFIG_RELOAD_VALUE</span></code></td>
    <td class="ln">5892</td><td class="sf3b2"><code><span class="sf13b2">#ifndef WDT_CONFIG_RELOAD_VALUE</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d24" href="#d24">5886</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define WDT_CONFIG_RELOAD_VALUE </span><span class="sf17b16">2</span><span style="color: #000000; background-color: #efcb05; ">000</span></code></td>
    <td class="ln">5893</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define WDT_CONFIG_RELOAD_VALUE </span><span class="sf17b16">3000</span><span style="color: #000000; background-color: #efcb05; ">000</span></code></td>
    </tr>
    <tr>
    <td class="ln">5887</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">5894</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">6693</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEM_MANAGER_ENABLED</span></code></td>
    <td class="ln">6700</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEM_MANAGER_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d25" href="#d25">6694</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEM_MANAGER_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">6701</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEM_MANAGER_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">6695</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">6702</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">6699</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_SMALL_BLOCK_COUNT</span></code></td>
    <td class="ln">6706</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_SMALL_BLOCK_COUNT</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d26" href="#d26">6700</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_SMALL_BLOCK_COUNT 1</span>&nbsp;</code></td>
    <td class="ln">6707</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_SMALL_BLOCK_COUNT 1</span><span class="sf17b18">28</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">6701</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">6708</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">6713</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_MEDIUM_BLOCK_COUNT</span></code></td>
    <td class="ln">6720</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_MEDIUM_BLOCK_COUNT</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d27" href="#d27">6714</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_MEDIUM_BLOCK_COUNT </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">6721</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_MEDIUM_BLOCK_COUNT </span><span class="sf17b16">64</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">6715</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">6722</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">6720</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_MEDIUM_BLOCK_SIZE</span></code></td>
    <td class="ln">6727</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_MEDIUM_BLOCK_SIZE</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d28" href="#d28">6721</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_MEDIUM_BLOCK_SIZE </span><span class="sf17b16">256</span>&nbsp;</code></td>
    <td class="ln">6728</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_MEDIUM_BLOCK_SIZE </span><span class="sf17b16">64</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">6729</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">6727</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_LARGE_BLOCK_COUNT</span></code></td>
    <td class="ln">6734</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_LARGE_BLOCK_COUNT</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d29" href="#d29">6728</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_LARGE_BLOCK_COUNT </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">6735</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_LARGE_BLOCK_COUNT </span><span class="sf17b16">32</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">6736</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">6734</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_LARGE_BLOCK_SIZE</span></code></td>
    <td class="ln">6741</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_LARGE_BLOCK_SIZE</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d30" href="#d30">6735</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_LARGE_BLOCK_SIZE </span><span class="sf17b16">256</span>&nbsp;</code></td>
    <td class="ln">6742</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_LARGE_BLOCK_SIZE </span><span class="sf17b16">128</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">6743</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">6741</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_XLARGE_BLOCK_COUNT</span></code></td>
    <td class="ln">6748</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_XLARGE_BLOCK_COUNT</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d31" href="#d31">6742</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_XLARGE_BLOCK_COUNT </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">6749</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_XLARGE_BLOCK_COUNT </span><span class="sf17b16">8</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">6750</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">6748</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_XLARGE_BLOCK_SIZE</span></code></td>
    <td class="ln">6755</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_XLARGE_BLOCK_SIZE</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d32" href="#d32">6749</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_XLARGE_BLOCK_SIZE </span><span class="sf17b16">1320</span>&nbsp;</code></td>
    <td class="ln">6756</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_XLARGE_BLOCK_SIZE </span><span class="sf17b16">256</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">6757</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">6755</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_XXLARGE_BLOCK_COUNT</span></code></td>
    <td class="ln">6762</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_XXLARGE_BLOCK_COUNT</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d33" href="#d33">6756</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_XXLARGE_BLOCK_COUNT </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">6763</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_XXLARGE_BLOCK_COUNT </span><span class="sf17b16">4</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">6764</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">6762</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_XXLARGE_BLOCK_SIZE</span></code></td>
    <td class="ln">6769</td><td class="sf3b2"><code><span class="sf13b2">#ifndef MEMORY_MANAGER_XXLARGE_BLOCK_SIZE</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d34" href="#d34">6763</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_XXLARGE_BLOCK_SIZE </span><span class="sf17b16">3444</span>&nbsp;</code></td>
    <td class="ln">6770</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define MEMORY_MANAGER_XXLARGE_BLOCK_SIZE </span><span class="sf17b16">2048</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">6771</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">7164</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_QUEUE_ENABLED</span></code></td>
    <td class="ln">7171</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_QUEUE_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d35" href="#d35">7165</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_QUEUE_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">7172</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_QUEUE_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">7166</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">7173</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">7434</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_LOG_BACKEND_RTT_ENABLED</span></code></td>
    <td class="ln">7441</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_LOG_BACKEND_RTT_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d36" href="#d36">7435</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_LOG_BACKEND_RTT_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    <td class="ln">7442</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_LOG_BACKEND_RTT_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">7436</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">7443</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">7467</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_LOG_BACKEND_UART_ENABLED</span></code></td>
    <td class="ln">7474</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_LOG_BACKEND_UART_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d37" href="#d37">7468</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_LOG_BACKEND_UART_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">7475</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_LOG_BACKEND_UART_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">7469</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">7476</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">7593</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_LOG_DEFERRED</span></code></td>
    <td class="ln">7600</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_LOG_DEFERRED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d38" href="#d38">7594</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_LOG_DEFERRED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">7601</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_LOG_DEFERRED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">7595</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">7602</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">10064</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_SDH_LOG_ENABLED</span></code></td>
    <td class="ln">10071</td><td class="sf3b2"><code><span class="sf13b2">#ifndef NRF_SDH_LOG_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d39" href="#d39">10065</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_SDH_LOG_ENABLED </span><span class="sf17b16">1</span>&nbsp;</code></td>
    <td class="ln">10072</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define NRF_SDH_LOG_ENABLED </span><span class="sf17b16">0</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">10066</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    <td class="ln">10073</td><td class="sf3b2"><code><span class="sf13b2">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">11757</td><td class="sf3b2"><code>&nbsp;</code></td>
    <td class="ln">11764</td><td class="sf3b2"><code>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d40" href="#d40">11758</a></td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">// &lt;</span><span class="sf17b16">/h</span><span style="color: #000000; background-color: #efcb05; ">&gt;</span><span class="sf17b16">&nbsp;</span>&nbsp;</code></td>
    <td class="ln">11765</td><td style="color: #000000; background-color: #efcb05; "><code><span class="sf17b18">#ifndef APP_FIFO_ENABLED</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">11766</td><td style="color: #000000; background-color: #efcb05; "><code><span class="sf17b18">#define APP_FIFO_ENABLED 1</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">11767</td><td style="color: #000000; background-color: #efcb05; "><code><span class="sf17b18">#endif</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">11768</td><td style="color: #000000; background-color: #efcb05; "><code>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">11769</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">// &lt;</span><span class="sf17b16">e</span><span style="color: #000000; background-color: #efcb05; ">&gt;</span><span class="sf17b16">&nbsp;APP_UART_ENABLED - app_uart - UART driver</span>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">11759</td><td class="sf3b2"><code><span class="sf9b2">//=====================================<wbr>=====================</span></code></td>
    <td class="ln">11770</td><td class="sf3b2"><code><span class="sf9b2">//=====================================<wbr>=====================</span></code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d41" href="#d41">.</a></td><td style="color: #000000; background-color: #c0c0c0; "><code>&nbsp;</code></td>
    <td class="ln">11771</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#ifndef APP_UART_ENABLED</span></code></td>
    </tr>
    <tr>
    <td class="ln">11772</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define APP_UART_ENABLED 1</span></code></td>
    </tr>
    <tr>
    <td class="ln">11773</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">11774</td><td style="color: #000000; background-color: #efcb05; "><code>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">11775</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#ifndef APP_UART_DRIVER_INSTANCE</span></code></td>
    </tr>
    <tr>
    <td class="ln">11776</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#define APP_UART_DRIVER_INSTANCE 0</span></code></td>
    </tr>
    <tr>
    <td class="ln">11777</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">#endif</span></code></td>
    </tr>
    <tr>
    <td class="ln">11778</td><td style="color: #000000; background-color: #efcb05; "><code>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">11779</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">// &lt;/e&gt;</span></code></td>
    </tr>
    <tr>
    <td class="ln">11760</td><td class="sf3b2"><code>&nbsp;</code></td>
    <td class="ln">11780</td><td class="sf3b2"><code>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln">11763</td><td class="sf3b2"><code>&nbsp;</code></td>
    <td class="ln">11783</td><td class="sf3b2"><code>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln"><a name="d42" href="#d42">.</a></td><td style="color: #000000; background-color: #c0c0c0; "><code>&nbsp;</code></td>
    <td class="ln">11784</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">// &lt;/h&gt; </span></code></td>
    </tr>
    <tr>
    <td class="ln">11785</td><td style="color: #000000; background-color: #efcb05; "><code><span style="color: #000000; background-color: #efcb05; ">//=====================================<wbr>=====================</span></code></td>
    </tr>
    <tr>
    <td class="ln">11786</td><td class="sf3b2"><code>&nbsp;</code></td>
    </tr>
    <tr>
    <td class="ln"></td><td></td>
    </tr>
    </tbody>
    </table>
    </body>
    </html>
    I will check it out.
