example test problem
hi support team,
i was testing this this example "http://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.4.0/nrf/samples/nrf5340/netboot/README.html#nc-bootloader"
 i have recovered flash using below command
after west flash in step 4, still there will be one problem as below, testing process is not as testing instructions described.
how to disable lock function after program? is there any config?
regards,
William.
  • It seems like readback protection is enabled automatically when programming the network and app core, therefore you won't be able to execute step 4-->program to the secondary slot of the application core.
    I confirmed this was the case by checking the content of the nRF53 Memory (using the nRF Connect fD. Programmer app) after executing step 3:
    I will investigate why this is and how to work around it. I'll get back to you
    Simon
  • I was able to complete the 4 steps in  doc/1.5.0/nrf/samples/nrf5340/netboot/README.html#nc-bootloader using NCS v1.5.0, an nRF5340 DK (v0.11.0) and the board selection nrf5340dk_nrf5340_cpuapp. I got the following output:
    I: Turned off network core
    I: Done updating network core
    I: Bootloader chainload address offset: 0xc000
    I: Jumping to the first image slot
    *** Booting Zephyr OS build v2.4.99-ncs1  ***
    Starting Nordic UART service example
    The JLink and nrfjprog versions are the following:
    $ nrfjprog -v
    nrfjprog version: 10.12.1
    JLinkARM.dll version: 6.96
    In step 2 I used the following commands below. There has been some issues regarding path length due to Windows limitations, therefore I used the name "bld" for the build folder
    cd <ncs location>nrf/samples/bluetooth/peripheral_uart
    west build -b nrf5340dk_nrf5340_cpuapp -d bld -f -- -DCONFIG_BOOTLOADER_MCUBOOT=y -Dmcuboot_CONFIG_PCD=y
    If you encounter issues could you try the command below, to see if approtect is enabled on the network core
    nrfjprog --memrd 0x01FF8000 --coprocessor CP_NETWORK
    It should read the network core approtect register, and it should return 50FA50FA (unprotected).
    Simon
