[ZIGBEE] Doesn't receive "Transport Key" in rejoining.
SDK: 4.1.0
CHIP: nRF52840
ROLE: sleepy zed
GATEWAY: third party ember stack
old question
old story:
- Issue: Doesn't update network key - 4.6.3.4 Network Key Update in zigbee spec.
- The current procedure of updating network key:
1) The gateway periodically changes the network key.
2) After changing the network key, The gateway doesn't receive the message encrypted with old key from the zed.
3) The zed doesn't receive APS ACK to the period request.
4) Since zed does not receive a response, it assumes that the network key has changed.
5) The zed request the rejoin message without encryption.
6) The gateway accepts unsecured rejoin .
7) The gateway send "Transport Key" encrypted with ZB_STANDARD_TC_KEY which is the same as when joining.
8) The zed processes this message and updates the network key.
It is the procedure of updating the network key has the gateway.
I has succeed until "5) requesting unsecured rejoining".
so, I received "Transport Key" encrypted with ZB_STANDARD_TC_KEY.
However, the zed does nothing. It doesn't even seem to be decryption of "Transport Key" message.
I watched the functions "nrf_802154_received_timestamp_raw" it was called and "hw_aes128" it wasn't called.
7140.pairing.pcapng
this is pairing procedure.
5722.0303-4.pcapng
this is rejoining procedure.
there are keys for pcap.
ZB_STANDARD_TC_KEY
5A:69:67:42:65:65:41:6C:6C:69:61:6E:63:65:30:39
Current Gateway key - not necessary
7F:94:FE:28:95:41:48:83:F9:16:F2:2D:8D:4B:78:97
How can I reach the goal?
1) If I terminate the old key, Does the zed receive "Transport Key" message?
2) How can I get or delete the network keys? I can't find the related api.
I already use "zb_bdb_reset_via_local_action" function to erase all parameter. I wants to terminate only network key to rejoining the network.
3) I uses IAS zone cluster. Is it related on this issue? I found the post.
"The reason the Elko PIR sensor does not retrieve the key is because it uses a cluster called IAS Zone, which gives extra security for the device, and has an extra step in the commissioning process." what is meaning? Why is IAS ZONE CLUSTER related to zigbee network security?
4) I found zigbee spec "4.7.3.10.2 Sleepy Devices" of rejoining procedure in sleepy device.
It is correct that i understood the procedure of rejoining. Is this legacy role? or not?
if yes, should I call "zb_set_network_ed_role_legacy" instead of "zb_set_network_ed_role"?
currently, I started rejoining procedure below the code inside the function "zigbee_default_signal_handler".
case ZB_ZDO_SIGNAL_SKIP_STARTUP: {
    /* At this point Zigbee stack:
     *  - Initialized the scheduler.
     *  - Initialized and read NVRAM configuration.
     *  - Initialized all stack-related global variables.
     * Next step: perform BDB initialization procedure (see BDB specification section 7.1).
    m_stack_initialised = ZB_TRUE;
    zb_disable_nwk_security();
    DEBUG_PRINTF("Zigbee stack initialized\n");
    DEBUG_PRINTF("bdb_start_top_level_commissioning\n");
    zb_secur_set_tc_rejoin_enabled(ZB_TRUE);
    comm_status = bdb_start_top_level_commissioning(
        // ZB_BDB_INITIALIZATION | ZB_BDB_TOUCHLINK_TARGET | ZB_BDB_REJOIN
    DEBUG_PRINTF("initialized zb_bdb_is_factory_new(): %d\r\n", zb_bdb_is_factory_new());
    /* WORKAROUND for the ZOI-297: unlock the device's address on ZEDs to fix assertion upon leave request. */
    zb_address_ieee_ref_t addr_ref;
    /* Unlock our address: it will be locked at rejoin confirm */
    if (zb_address_by_short(ZB_PIBCACHE_NETWORK_ADDRESS(), ZB_FALSE, ZB_FALSE, &addr_ref) == RET_OK) {
        zb_address_unlock(addr_ref);
} break;
without calling "zb_disable_nwk_security" function, the zed doesn't success rejoining the network.
  • Edvin,
    It has already been a month since I started asking questions on this issue.
    However, I am not getting a single satisfactory answer to this question. I don't even know if it's covered by your Zigbee team.
    Please let me know how it is going.
    I will upload the sniffer logs. Both are light switch examples, one is sdk 3.2.0 and the other is sdk 4.1.0.
    nrfcli-lightswitch-sdk3_2-nwkkeychange3times-failed-rejoin.pcapng
    nrfcli-lightswitch-sdk4_1-nwkkeychange1times-failed-rejoin.pcapng
    sdk 4.1.0 only sends request rejoin to the previous key after switch key and does not do any other action, but sdk 3.2.0 sends request rejoin to the previous key and receives the APS of the updated key sequence and performs unsecure rejoin.
    I checked this and downgraded the sdk in the project, but it seems that the execution condition of unsecure rejoin should receive the APS or Rejoin-Response of the updated key sequence. If the coordinator fails to APS or Rejoin-Response response to the previous key after several key updates, even this cannot be performed.
    I don't know if you have checked the previous logs, but try adding them again. You may be busy, I hope that good communication does not lead to misunderstandings.
    Our project has been delayed a lot. and We are considering silicon labs chips as well. But we don't want to add silicon labs chip as an additional communication module just because of this software problem. Please tell me your milestone. Please let me know if it is possible to modify it or not.
    I have forwarded this to our zigbee team, but I have not received a reply yet. I'll ping them.
    Trust me, if I knew what was wrong I would tell you.
    Let me try to get some input from our Zigbee team and get back to you rather quickly.
    FYI: Your ticket has had the status "open" all the time, so the intention is to solve this issue before we close this ticket.
    Edvin
  • Okay. Thank you for a reply. I'm not glaring at you, but it's painful because of my pressure on the project. I hope your zigbee team will get an answer as soon as possible. :(
  • Any update on this? Anything they say is good, so please forward it.
  • I received a reply from our Zigbee team today:
    "Our investigation showed that this seems to be an unhandled case in the stack. We have taken it for further investigation. Unfortunately, the only workaround at the moment is to join the network again, when the key is lost."
    I would also think that another workaround would be to wake up more often, so that the parent has the chance to transmit the key change before it is too late. Does your device wake up regularly? If so, on what interval?
    BR,
    Edvin
