Use of NCP in Zigbee
I am using nRF52833, nRF Connect SDK  v1.5.0.
In v1.5.0 there is one new example i.e Zigbee NCP. ( Zigbee: NCP — nRF Connect SDK 1.5.0 documentation (nordicsemi.com)..)
In the above link, NCP and coordinator are both used for testing.
I'm not understanding what is the use of NCP.  I am confused between the use of coordinator and NCP.
Can you please explain to me why and in which case NCP required?
What is the difference between NCP and coordinator?
Thank you,
Pranav.
    Thank you for your reply. I think I may not have explained you properly. Sorry for that.
    I have attached some screenshots for proper understanding.
    In the first step, I have imported/selected the light_switch example(under zigbee - light_switch)from SDK v1.4.2.
    In this the path of the example is - C:/Users/Pranav/ncs/v1.4.2/nrf/samples/zigbee/light_switch/build_nrf52833dk_nrf52833
    In the second step, I have followed the same for SDK v1.5.0.
    - C:/Users/Pranav/ncs/v1.5.0/nrf/samples/bluetooth/mesh/light_switch/build_nrf52833dk_nrf52833
    I have also tried to enter the path manually in v1.5.0. But it also redirects to Bluetooth/mesh.
    I also confirmed this issue with my colleague and the same issue occurred on his pc.
    1. About the NCP example
    I am running the light_control application and NCP connected to my Linux pc. Also tried the same step with my colleague but encountered the same issue.
    Can you please suggest to me some solution by trying it out on your side?
    Thank you,
    Pranav.
  • Oh, I see. When you select zigbee: Light_switch, then the project generator in SES uses the Mesh light switch example:
    Yes. That looks like a bug. Thank you for reporting. I will forward this bug to our developers.
    As a workaround, you can select the project folder manually, using the 3 dots to the right of the projects selecter:
    and select the folder "v1.5.0\nrf\samples\zigbee\light_switch"
    Edvin
  • Hello Edvin,
    Thank you for your quick reply. I tried what you suggested here.
    But facing another problem after imported(imported same as you mentioned) the light_switch project.
    nus_cmd.c file is missing in the project.
    Also, After building and running the same project. There is no advertisement on the nRF Toolbox application and also it is not joining the network
    In the previous SDK i.e 1.4.2 the nus_cmd file is present and it also visible on the nRF Toolbox i.e working properly to both protocol (BLE + Zigbee)
    Pranav
  • Hello Pranav,
    I am not sure what you are trying to point to in your screenshot here.
     But is it used in the project at all? Have you compared the project config the same way as in 1.4.2? I see that CONFIG_BT_NUS is not enabled by default.
    Try to set:
    And:
    BR,
    Edvin
  • Hello Edvin,
    Thank you for your reply. I tried what you suggested. It worked but In the light_switch board only LED 3: (On and solid when the device is connected to a Zigbee network.) is ON.
    LED 4 i.e. (On and solid when the light switch has found a light bulb to control) is not glowing/OFF.
    I am not able to control the light_bulb from boards as well as a mobile application
    I am not able to understand what's wrong. In SDK v1.4.2 it's worked easily and seamlessly ( also setup part) without any additional steps.
    Can you please help to resolve this issue?
    Is your NCP connected to anything physically? What is running the application?
    Also still I am facing this issue.
    Can you please also help me to resolve this issue?
    Thank you,
    Pranav.
