nRF Connect (v3.6.1) error message: ""Failed to setup device: No serial port available for device with serial number xxxxxxxx""
I was using nRF Connect (v3.6.1) to communicate to Segger J-link Base (version 11.0) but it failed. The error message was: ""Failed to setup device: No serial port available for device with serial number xxxxxxxx"". Anyone has an idea how to fix this issue? Thanks!
  • Hi
    What nRFConnect app are you trying to connect the J-Link device to? The Bluetooth Low Energy app for instance, is only compatible with Nordic Semiconductor DKs for example. How is the nRF you're using connected to the J-Link Base?
    Are you able to detect the SEGGER J-Link Base in your device manager at all?
    Simon
  • Thanks for quick response! I was using Bluetooth Low Energy App and nRF52 chip was connected to J-Link. The app detected the J-Link Base but when I clicked it the error message showed up.
  • Hi
    nRFConnect communicates with nRF devices over the Virtual COM port in J-Link. Does your J-Link devices support this functionality? If not, I'm afraid you won't be able to use it with nRFConnect for Desktop.
    Additionally, the nRFConnect Bluetooth Low Energy app has stored a specific range of SEGGER IDs that are reserved for Nordics Development Kit debugger chips, so it will know if it is a supported device that is connected. Only our Development Kits and Dongles can be used with this particular app. If your J-Link device support acting as a Virtual COM link, you should be able to use nRFConnect apps like the Programmer though.
    Simon
  • The SEGGER J-Link Base I used does have virtual COM, but it was disabled by default. Today I was able to enable it using J-Link Config tool. It still failed but had different error messages. Here is the log file for your reference:
     23T01:16:14.690Z INFO Device setup completed
    2021-03-23T01:16:14.691Z INFO The device is not in the list of supported devices. Attempting to open as a custom device.
    2021-03-23T01:16:14.691Z INFO Opening custom device
    2021-03-23T01:16:14.691Z INFO Note: firmware must be compatible with connectivity firmware version: 4.1.2, SoftDevice API version: 5 and baud rate: 1000000.
    2021-03-23T01:16:14.697Z INFO Opening adapter connected to COM8
    2021-03-23T01:16:15.668Z INFO Reset performed on adapter COM8
    2021-03-23T01:16:15.677Z INFO Successfully opened COM8. Baud rate: 1000000. Flow control: none. Parity: none.
    2021-03-23T01:16:15.677Z DEBUG State change: STATE_START -> STATE_RESET
    2021-03-23T01:16:15.677Z DEBUG 1 -> [N/A] type: RESERVED_5 reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0
    2021-03-23T01:16:15.982Z DEBUG State change: STATE_RESET -> STATE_UNINITIALIZED
    2021-03-23T01:16:15.983Z DEBUG 2 -> [01 7e ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC]
    2021-03-23T01:16:16.231Z DEBUG 3 -> [01 7e ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC]
    2021-03-23T01:16:16.490Z DEBUG 4 -> [01 7e ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC]
    2021-03-23T01:16:16.738Z DEBUG 5 -> [01 7e ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC]
    2021-03-23T01:16:16.989Z DEBUG 6 -> [01 7e ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC]
    2021-03-23T01:16:17.236Z DEBUG 7 -> [01 7e ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC]
    2021-03-23T01:16:17.486Z DEBUG State change: STATE_UNINITIALIZED -> STATE_NO_RESPONSE
    2021-03-23T01:16:17.486Z ERROR Received status with code 0 PKT_SEND_MAX_RETRIES_REACHED, message: 'No response from device. Tried to send packet 6 times.'
    2021-03-23T01:16:18.382Z ERROR serial port write operation on port COM8 failed. Error: A device attached to the system is not functioning.[31]
    2021-03-23T01:16:18.382Z DEBUG serial port read on port COM8 aborted.
    2021-03-23T01:16:18.725Z ERROR Error occured when opening port. Errorcode: NRF_ERROR_TIMEOUT (0xd)
  • Hi
    As I mentioned in my last reply, the BLE app in nRFConnect for Desktop is restricted to use with Nordic DKs, so you won't be able to use it successfully with a J-Link Base (we can see this from the line "2021-03-23T01:16:14.691Z INFO The device is not in the list of supported devices. Attempting to open as a custom device.." in the log).
    You should however be able to make use of I.E. the Programmer app in nRFConnect for Desktop, as this doesn't have that restriction.
    Simon
