Long Range + Direction finding
Hello
Trying to get the idea of whether the Long Range and Direction finding could be used simultaneously with the devices capable of both features.
Googling Long Range I realize that it requires a Special Coded PHY to be utilized at both ends and also the longer range is achieved by lowering the speed to 125kb/sec.  On the other hand, the direction finding requires extended advertisement (besides antenna switching at the respective side). Apparently, the extended advertisement does require a higher bit rate which to fit into transmission slots, and that defies the possibility of low rates such as 125kb/sec
Is my understanding correct or I'm wrong? Can both features be used simultaneously on enabled devices?
Thank you
Alex
