I'm writing custom boot loaders. One of the capabilities is to update the network processor from code running on the application processor. The PCD subsystem looks like it has what I need to do this nicely. However, the PCD subsystem has a single configuration option that brings in code for both the network and application processor. Thus when using PCD on the application side the function pcd_fw_copy is compiled - even though that function is only for the network processor. That in turn requires FLASH_PAGE_LAYOUT, STREAM_FLASH, and STREAM_ERASE. The application code that I'm writing does not want those (unused) requirements. It would be great if the Kconfig for PCD had two different config options. For example, PCD_APP and PCD_NET, so that you can bring in only the code (and dependencies) needed for the application processor or the network processor. [A PCD configuration could select both for backwards compatibility if desired.]
Is this forum the place to post such things? If so any thoughts on this? If not where should it be posted?
