Zigbee and Serial communication issue
Hello Nordic!
I have been developing a Zigbee application and now, I need to connect via Serial communication with another device. I just need to listen to the port, not send any data. Unfortunately I don't have that device so I am simulating it with an Arduino Uno. It is configured as the original device at 19200baud, 8bit, 1 stop bit. First of al, is there any other better way to read data through RX/TX? Any other libraries instead of libuarte?
I found the libuarte example which I modified and make it work for my needs. It reads my Arduino via Serial communication correctly and I obtain the characters nicely. My problem occurs when I try to implement the libuarte code into mine. I have had several problems with the sdk_config file. But once the errors have faded out and the code have compiled, I have flashed it into the nrf52840DK board but the Zigbee and Serial communication suddenly stopped working. Could it be that they share some timer or some other peripheral?
I have tried changing the timer for the serial communication but achieved nothing. What may be causing this issue?
The modified code of the libuarte's example is as follows:
 * Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup libuarte_example_main main.c
 * @ingroup libuarte_example
 * @brief Libuarte Example Application main file.
 * This file contains the source code for a sample application using libuarte.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "nrf_libuarte_async.h"
#include "nrf_drv_clock.h"
#include <bsp.h>
#include "nrf_log_ctrl.h"
#include "nrf_queue.h"
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
static uint8_t text[] = "UART example started.\r\n Loopback:\r\n";
static uint8_t text_size = sizeof(text);
static volatile bool m_loopback_phase;
typedef struct {
    uint8_t * p_data;
    uint32_t length;
} buffer_t;
NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
    nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
    ret_code_t ret;
    switch (p_evt->type)
        case NRF_LIBUARTE_ASYNC_EVT_ERROR:
            bsp_board_led_invert(0);
        case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
            ret = nrf_libuarte_async_tx(p_libuarte,p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
            if (ret == NRF_ERROR_BUSY)
                buffer_t buf = {
                    .p_data = p_evt->data.rxtx.p_data,
                    .length = p_evt->data.rxtx.length,
                ret = nrf_queue_push(&m_buf_queue, &buf);
                APP_ERROR_CHECK(ret);
            bsp_board_led_invert(1);
            m_loopback_phase = true;
        case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
            if (m_loopback_phase)
                nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
                if (!nrf_queue_is_empty(&m_buf_queue))
                    buffer_t buf;
                    ret = nrf_queue_pop(&m_buf_queue, &buf);
                    UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
            bsp_board_led_invert(2);
    ret_code_t ret = nrf_drv_clock_init();
    ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
            .tx_pin     = TX_PIN_NUMBER,
            .rx_pin     = RX_PIN_NUMBER,
            .baudrate   = NRF_UARTE_BAUDRATE_19200,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 100,
            .int_prio   = APP_IRQ_PRIORITY_LOW
    err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    nrf_libuarte_async_enable(&libuarte);
    err_code = nrf_libuarte_async_tx(&libuarte, text, text_size);
    while (true)
        NRF_LOG_FLUSH();
Thanks to all in advance!
Cheers!
  • Hello Susheel,
    Right now I am working in different features of the code so I couldn't try what you said. As soon as possible, I will try what you told me.
    Meanwhile, the question I was referring was the following
    I have tried to follow the path why BLE and UART are not compatible and I have found that they can be compatible, but once some time has passed, the UART communication ends and BLE and Zigbee start working as usual.
  • I have asked the Zigbee expert to shed some light on the BLE, Zigbee and UART compatibility. She is on holiday today but will respond most likely on Tuesday as Monday is also holiday (Norwegian National Day)
  • I am now talked to the Zigbee developer in support and she says that she does not see any reason that UART will have any compatibility issues when used with BLE and Zigbee. There is also a BLE UART/Zigbee doorlock, that uses uart gor logging.
    there is also a template you should follow if you wants to run both BLE and Zigbee, adding UART peripheral to this example and then the rest of his application will be much easier for you than adding BLE to an existing Zigbee project:
  • Hello Susheel!
    I think the example you said is the same example I am using as a guide for my project. In fact, what I am trying to make is a Zigbee doorlock but with a lot of features. That example uses NUS for sending data over BLE, could that be my problem?
     I've been trying unsuccesfully to add uart communication to the template you mention but I am not able to do it. I am using the same code that is working in my current board (with BLE and Zigbee deactivated) but it refuses to work. Below I show yo the code I am using (it is written in spanish, sorry):
        static uint8_t buffer[LONGITUD_MAX_MENSAJE];
        static uint8_t index = 0;
        uint32_t err_code;
        switch (p_event->evt_type)
            case APP_UART_FIFO_ERROR:
                //APP_ERROR_HANDLER(p_event->data.error_code);
            case APP_UART_DATA:
                UNUSED_VARIABLE(app_uart_get(&buffer[index]));
                if ((buffer[index] == 0x0a) || (buffer[index] == 0x0d) || index >= LONGITUD_MAX_MENSAJE)
                    // Do something
                    index = 0;
                    index++;
    static void uart_init(void)
        uint32_t err_code;
            .rx_pin_no    = RX_PIN,
            .tx_pin_no    = TX_PIN,
            .rts_pin_no   = RTS_PIN,
            .cts_pin_no   = CTS_PIN,
            .flow_control = FLOW_CONTROL,
            .use_parity   = USE_PARITY,
            .baud_rate    = BAUDRATE
        APP_UART_INIT(&comm_params,
                      uart_event_handle,
                      APP_IRQ_PRIORITY_HIGH,
                      err_code);
    I also modified the sdk_config file to define UART_ENABLED to 1 and used the APP_UART_DRIVER_INSTANCE 0, the sdk_donfig file is pretty similar to mine. But I don't discard that the error may be in that file.
    Cheers!
    EDIT: I realised that the problem was having both the log and the uart, so I commented out the initialisation function for the log and everything seems to work. I have yet to test the full functionality, but it looks promising.
  • Hello Susheel!
    I have continued and realised the cause of the error. I am posting the info in case someone else has the same problem in the future.
    After a week of debugging, I find out that the library "libzboss.ed.a" located in "external/zboss/lib/gcc/" was causing the code to fail. If I use the "libzboss.a" library instead of the "libzboss.ed.a" (note the difference between .ed.a and just .a) it works like a charm.
    In fact, as Susheel told me, there is no incompatibilities between Zigbee and UART. And I simply changed that library and everything started working. There is also one little thing to modify, and that is to remove the "ZB_ED_ROLE" from the Preprocessor definitions, but if you don't do that, Segger (or whatever you use) will throw an error.
    To close the thread, I just want to know why was happening this error. I would appreciate it if someone could explain a bit more about why this problem is occurring.
    Cheers!
