Zigbee and Serial communication issue
Hello Nordic!
I have been developing a Zigbee application and now, I need to connect via Serial communication with another device. I just need to listen to the port, not send any data. Unfortunately I don't have that device so I am simulating it with an Arduino Uno. It is configured as the original device at 19200baud, 8bit, 1 stop bit. First of al, is there any other better way to read data through RX/TX? Any other libraries instead of libuarte?
I found the libuarte example which I modified and make it work for my needs. It reads my Arduino via Serial communication correctly and I obtain the characters nicely. My problem occurs when I try to implement the libuarte code into mine. I have had several problems with the sdk_config file. But once the errors have faded out and the code have compiled, I have flashed it into the nrf52840DK board but the Zigbee and Serial communication suddenly stopped working. Could it be that they share some timer or some other peripheral?
I have tried changing the timer for the serial communication but achieved nothing. What may be causing this issue?
The modified code of the libuarte's example is as follows:
 * Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup libuarte_example_main main.c
 * @ingroup libuarte_example
 * @brief Libuarte Example Application main file.
 * This file contains the source code for a sample application using libuarte.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "nrf_libuarte_async.h"
#include "nrf_drv_clock.h"
#include <bsp.h>
#include "nrf_log_ctrl.h"
#include "nrf_queue.h"
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
static uint8_t text[] = "UART example started.\r\n Loopback:\r\n";
static uint8_t text_size = sizeof(text);
static volatile bool m_loopback_phase;
typedef struct {
    uint8_t * p_data;
    uint32_t length;
} buffer_t;
NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
    nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
    ret_code_t ret;
    switch (p_evt->type)
        case NRF_LIBUARTE_ASYNC_EVT_ERROR:
            bsp_board_led_invert(0);
        case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
            ret = nrf_libuarte_async_tx(p_libuarte,p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
            if (ret == NRF_ERROR_BUSY)
                buffer_t buf = {
                    .p_data = p_evt->data.rxtx.p_data,
                    .length = p_evt->data.rxtx.length,
                ret = nrf_queue_push(&m_buf_queue, &buf);
                APP_ERROR_CHECK(ret);
            bsp_board_led_invert(1);
            m_loopback_phase = true;
        case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
            if (m_loopback_phase)
                nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
                if (!nrf_queue_is_empty(&m_buf_queue))
                    buffer_t buf;
                    ret = nrf_queue_pop(&m_buf_queue, &buf);
                    UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
            bsp_board_led_invert(2);
    ret_code_t ret = nrf_drv_clock_init();
    ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
            .tx_pin     = TX_PIN_NUMBER,
            .rx_pin     = RX_PIN_NUMBER,
            .baudrate   = NRF_UARTE_BAUDRATE_19200,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 100,
            .int_prio   = APP_IRQ_PRIORITY_LOW
    err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    nrf_libuarte_async_enable(&libuarte);
    err_code = nrf_libuarte_async_tx(&libuarte, text, text_size);
    while (true)
        NRF_LOG_FLUSH();
Thanks to all in advance!
Cheers!
  • Hello again!
    I have been experiencing some problems with Serial and Zigbee communication. The previous solution I found about "libzboss.a" library is not suitable, that library is not used on Zigbee End Devices (I need to use libzboss.ed.a) so when I try to reconnect to my Coordinator it connects as a device with GreenPower cluster only (when I don't use it).
    Please, I need to fix this issue as soon as possible, it's been 3 months since the beginning of the question and I still have the UART working.
    Regards.
  • Hi Alejandro,
    I have taken over this case from Susheel. I don't think you should delete the ZBOSS libraries provided. Could it be that you are having problems adding a new UART instance since the Zigbee examples also use UART for nrf log output?
    Have you tried changing APP_UART_DRIVER_INSTANCE to 1 in sdk_config.h and set UART1_ENABLED?
    nRF logging module in the examples will use UART0 as default.
    Marjeris
