mqtts reported an error when creating a socket: Operation not supported on socket.
I want nRF9160 to do mqtts connection without certificate.
Modem FW:1.2.3
Here is my mqtt client_init:
static int client_init(struct mqtt_client *client)
	int err;
	mqtt_client_init(client);
	err = broker_init();
	if (err) {
		LOG_ERR("Failed to initialize broker connection");
		return err;
	/* MQTT client configuration */
	client->broker = &broker;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = (uint8_t *)CONFIG_MQTT_CLIENT_ID;
	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
	client->password = NULL;
	client->user_name = NULL;
	client->protocol_version = MQTT_VERSION_3_1_1;
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	/* MQTT transport configuration */
	struct mqtt_sec_config *tls_cfg = &(client->transport).tls.config;
	static sec_tag_t sec_tag_list[] = { CONFIG_MQTT_TLS_SEC_TAG };
	LOG_INF("TLS enabled");
	client->transport.type = MQTT_TRANSPORT_SECURE;
	tls_cfg->peer_verify = TLS_PEER_VERIFY_NONE;
	tls_cfg->cipher_count = 0;
	tls_cfg->cipher_list = NULL;
	tls_cfg->sec_tag_count = 0;
	tls_cfg->sec_tag_list = NULL;
	tls_cfg->hostname = CONFIG_MQTT_BROKER_HOSTNAME;
	tls_cfg->session_cache = IS_ENABLED(CONFIG_MQTT_TLS_SESSION_CACHING) ?
					    TLS_SESSION_CACHE_ENABLED :
					    TLS_SESSION_CACHE_DISABLED;
	return err;
When I use 9160DK, mqtts is connected normally. But when using the 9160 chip, there is an error in the connection. Here is my log:
[00:00:00.243,316] <inf> main: Connecting to LTE network.
[00:00:00.243,316] <inf> main: This may take several minutes.
[00:00:00.243,377] <inf> flash_control: No apn found, use default apn
[00:00:00.249,908] <inf> main: Set to the default APN CMNBIOT2.
[00:00:00.258,087] <inf> lte_lc: Using legacy LTE PCO mode...
[00:00:02.258,117] <inf> main: CSCON : 1
[18:48:50.833]收←◆[00:00:04.283,386] <inf> main: Connected to LTE network.
[00:00:04.286,163] <inf> mqtt_engine: IPv4 Address found 47.106.164.80
[00:00:04.286,193] <inf> mqtt_engine: TLS enabled
[00:00:04.286,468] <dbg> net_mqtt_sock_tls.mqtt_client_tls_connect: (0x20015220): Created socket 1
[00:00:04.660,552] <err> mqtt_engine: mqtt_connect -45
[00:00:04.660,583] <err> mqtt_engine: ERROR: mqtt_disconnect -57
-45 is EOPNOTSUPP, and typically indicates that you have written wrong certificates to the device. But I had peer_verify set to 0. Why is there a -45 error?
  • All certificates present in the DK board:
    [15:16:11.422]收←◆*** Booting Zephyr OS build v2.4.99-ncs1  ***
    The AT host sample started
    [15:16:17.557]发→◇AT%CMNG=1
    [15:16:17.572]收←◆%CMNG: 0,3,"0303030303030303030303030303030303030303030303030303030303030303"
    %CMNG: 0,4,"0404040404040404040404040404040404040404040404040404040404040404"
    %CMNG: 24,0,"0000000000000000000000000000000000000000000000000000000000000000"
    %CMNG: 6123,4,"0404040404040404040404040404040404040404040404040404040404040404"
    %CMNG: 123456,3,"0303030303030303030303030303030303030303030303030303030303030303"
    %CMNG: 123456,4,"0404040404040404040404040404040404040404040404040404040404040404"
    %CMNG: 16842753,0,"0000000000000000000000000000000000000000000000000000000000000000"
    %CMNG: 16842753,1,"0101010101010101010101010101010101010101010101010101010101010101"
    %CMNG: 16842753,2,"0202020202020202020202020202020202020202020202020202020202020202"
    %CMNG: 35724861,3,"0303030303030303030303030303030303030303030303030303030303030303"
    %CMNG: 35724861,4,"0404040404040404040404040404040404040404040404040404040404040404"
    OK
    Demo is in the attachment. mqtt_simple_test.rar
  • I found through a breakpoint test that the return value of nrf_connect() on the eleventh line is -1.
    static int nrf91_socket_offload_connect(void *obj, const struct sockaddr *addr,
    					socklen_t addrlen)
    	int sd = OBJ_TO_SD(obj);
    	int retval;
    	if (addr->sa_family == AF_INET) {
    		struct nrf_sockaddr_in ipv4;
    		z_to_nrf_ipv4(addr, &ipv4);
    		retval = nrf_connect(sd, (const struct nrf_sockaddr_in *)&ipv4,
    				     sizeof(struct nrf_sockaddr_in));
    	} else if (addr->sa_family == AF_INET6) {
    		struct nrf_sockaddr_in6 ipv6;
    		z_to_nrf_ipv6(addr, &ipv6);
    		retval = nrf_connect(sd, (const struct nrf_sockaddr *)&ipv6,
    				  sizeof(struct nrf_sockaddr_in6));
    	} else {
    		/* Pass in raw to library as it is non-IP address. */
    		retval = nrf_connect(sd, (void *)addr, addrlen);
    		if (retval < 0) {
    			/* Not supported by library. */
    			goto error;
    	return retval;
    error:
    	retval = -1;
    	errno = ENOTSUP;
    	return retval;
  • Hi!
    I'm unfortunately not able to reproduce the issue you're seeing, so I'm not sure where to go from here.
    The application you attached works fine on my DK. The only changes I made were changing the configurations to connect with LTE-M instead of NB-IoT because that's what I have available.
    Your modem trace was possibly missing some information. Perhaps you can try to generate a new one?
  • This is the modem information I re-crawled. Can you analyze what went wrong?1348.trace-2021-04-28T02-21-08.402Z.bin
  • Hi!
    From the modem trace and the return of %CMNG it looks like there is a Root CA stored in sec_tag 24 and sec_tag 16842753 but the TLS connection is trying to be establishing using sec_tag 1, where there is no root certificate.
    Try using the correct sec_tag in your application, and the modem should be able to find the root certificate.
    Heidi
